- Timestamp:
12/07/05 13:36:27 (19 years ago)
- Author:
ChrisJohns
- Comment:
/* Build Machine */
Legend:
- Unmodified
- Added
- Removed
- Modified
v2
v3
8 | 8 | |
9 | 9 | |
10 | | The current tool sets are build on Linux PC based machines. Joel uses a RedHat 7.3 machine to give the resulting executables the a wide range of machines to run on. Ralf and Chris use Fedora Core 4 machines. The page is written while building on a Fedora Core 4 machine. |
| 10 | The current tool sets are build on Linux PC based machines. Joel uses a RedHat 7.3 machine to give the resulting executables a wide range of machines to run on. Ralf and Chris use Fedora Core 4 machines. The page is written while building on a Fedora Core 4 machine. |
11 | 11 | |
12 | 12 | The host machine needs to be a software development machine. You need to make sure you have a working GNU compile suite. If you intend to build all possible packages you will need a large amount of disk space. You need to install perl and help2man. On Fedora Core 4 you can find a help2man RPM package in the [http://download.fedora.redhat.com/pub/fedora/linux/extras Extras RPM repository standard packages may require patches]. |
