- Timestamp:
02/07/13 11:02:02 (11 years ago)
- Author:
C Rempel
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v26
v27
4 | 4 | ''Chris: This is the start of documenting building the tool RPM packages.'' |
5 | 5 | ''Gedare: This is outdated.'' |
| 6 | ''Cindy: Could we add wget ting the source/patches into the RPM packages tool?''' |
6 | 7 | |
7 | 8 | RTEMS provides binary tool packages in the RPM format. If you wish to build binary tools for RTEMS you can use the method used to produce the binary RPM packages. Building tools from source is a complicated and sometimes fragile operation. To help keep the procedure simple all RPM files are built in Linux including the Windows versions. The RPM tools is used as it provided a excellent tools designed for building large packages from source. |
