- Timestamp:
12/08/05 07:41:31 (19 years ago)
- Author:
ChrisJohns
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v12
v13
4 | 4 | ''Chris: This is the start of documenting building the tool RPM packages.'' |
5 | 5 | |
6 | | RTEMS provides binary tool packages in the RPM format. You need to build the packages from source so will need the RTEMS source tree, plus the source for GCC, binutils, newlib and GDB. The [wiki:StandardPackagePatches standard packages may require patches]. |
| 6 | RTEMS provides binary tool packages in the RPM format. You need to build the packages from source so will need the RTEMS source tree, plus the source for GCC, binutils, newlib and GDB. The [wiki:TBR/UserManual/Standard_Package_Patches standard packages may require patches]. |
7 | 7 | = Build Machine = |
8 | 8 | |
