- Timestamp:
01/14/20 21:25:39 (4 years ago)
- Author:
Joel Sherrill
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v476
v477
92 | 92 | * [wiki:Projects/Open/PyGDB Python GDB Support (Python)] - Add Python Script support for debugging RTEMS with GDB. |
93 | 93 | * ''[wiki:Projects/Open/StackAnalysis Static Analysis of Stack Usage]'' - Develop a tool for static analysis of stack usage. |
94 | | * ''[wiki:Projects/Open/PythonCoverageReporting Python Coverage Reporting (Python)]'' - Convert coverage reporting to Python and integrate into RTEMS Tools. |
95 | | * [wiki:Projects/Open/GCovReports GCov Reports] - Use gcov output as generated by covoar to generate useful reports. |
96 | | * [wiki:Projects/Open/GProfReports GProf Reports] - Use gprof output as generated by covoar to generate useful reports. |
97 | | * [wiki:Projects/Open/AddCoverageToGDBSimulators GDB Coverage] - Add execution coverage logging to the GDB simulators used by RTEMS. |
| 94 | |
98 | 95 | * [wiki:Projects/Open/ImproveEclipsePlugin Improve Eclipse Plugin] - Improvements in the [wiki:Developer/Eclipse/Information RTEMS Eclipse Integration]. |
99 | 96 | * [wiki:Projects/Open/UsingClang Using clang] - Compiling RTEMS with [wiki:Projects/CLANG CLANG]. |
145 | 142 | * Tools |
146 | 143 | * [wiki:Projects/GSoC/ApplicationConfigurationGUI Application Configuration GUI]. |
| 144 | * ''[wiki:Projects/Open/PythonCoverageReporting Python Coverage Reporting (Python)]'' - Convert coverage reporting to Python and integrate into RTEMS Tools. |
| 145 | * [wiki:Projects/Open/GCovReports GCov Reports] - Use gcov output as generated by covoar to generate useful reports. |
| 146 | * [wiki:Projects/Open/GProfReports GProf Reports] - Use gprof output as generated by covoar to generate useful reports. |
| 147 | * [wiki:Projects/Open/AddCoverageToGDBSimulators GDB Coverage] - Add execution coverage logging to the GDB simulators used by RTEMS. |
147 | 148 | * Runtime |
148 | 149 | * [wiki:Projects/Open/AtomicAPI Classic API Atomic API] |
