Changes between Version 471 and Version 472 of Developer/OpenProjects
Ignore:
Timestamp:
Feb 28, 2019, 8:52:59 PM (9 months ago)
Author:
Gedare Bloom
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Developer/OpenProjects
    v471 v472
    2424 * If this is a SoC Project one of the mentors of the project should be mentioned in the Owner field and you should CC the rest of the mentors. If no mentors are mentioned, keep the fields blank.
    2525 * The Keywords field should be set to "SoC" denoting any projects that can participate in the Summer of Code. The keyword is case sensitive.
    26  * We might want to use some other Keywords e.g. to define the project type (e.g. one of: testing, ecosystem, kernel, statistics, BSP, API, libbsd, languages, libraries). Please ask on the mailing before adding new keywords.
     26 * You also need to set one of the following as a Keyword (comma-delimited) to define the project type, one of: testing, ecosystem, kernel, statistics, BSP, API, libbsd, languages, libraries. Please ask on the mailing before adding new keywords, as they are used to create the tables below.
    2727 * Select an appropriate component for the Component field.
    2828
