- Timestamp:
02/14/19 15:03:04 (5 years ago)
- Author:
Gedare Bloom
- Comment:
Flatten old project descriptions. Add "executive" project section generated from tickets.
Legend:
- Unmodified
- Added
- Removed
- Modified
v469
v470
44 | 44 | |
45 | 45 | === Testing Projects === |
| 46 | Testing a large body of software like RTEMS is in a continual state of improvement. There is always a need for more test cases and easier ways to run them all and decode the results. In addition, we want to be able to run all tests on as many hardware and simulator configurations as possible. Testing doesn't sound exciting to most people but when you combine the breadth of what we need to test with our desire for 100% instruction and branch path coverage, you get some very interesting and challenging work. |
| 47 | |
46 | 48 | [[TicketQuery(status!=closed, keywords~=SoC testing, format=table, col=summary|owner, order=priority|id)]] |
47 | 49 | |
48 | 50 | |
49 | 51 | === Development Ecosystem Projects === |
| 52 | RTEMS applications are cross-compiled on a development host to produce executables that are transferred to and executed on target systems. The projects in this section focus on the host side of that equation. This means they will run on a developer's computer and possibly communicate with embedded hardware. |
| 53 | |
50 | 54 | [[TicketQuery(status!=closed, keywords~=SoC ecosystem, format=table, col=summary|owner, order=priority|id)]] |
51 | 55 | |
53 | 57 | [[TicketQuery(status!=closed, keywords~=SoC API, format=table, col=summary|owner, order=priority|id)]] |
54 | 58 | |
| 59 | === Executive (!SuperCore, SuperCoreCPU, libcpu) a.k.a. kernel === |
| 60 | |
| 61 | [[TicketQuery(status!=closed, keywords~=SoC executive, format=table, col=summary|owner, order=priority|id)]] |
| 62 | |
55 | 63 | === Runtime Statistics Projects === |
| 64 | |
56 | 65 | [[TicketQuery(status!=closed, keywords~=SoC statistics, format=table, col=summary|owner, order=priority|id)]] |
57 | 66 | |
58 | 67 | === rtems-libbsd === |
59 | 68 | [[TicketQuery(status!=closed, keywords~=SoC libbsd, format=table, col=summary|owner, order=priority|id)]] |
| 69 | |
60 | 70 | |
61 | 71 | == Wiki Listed Open Projects == |
70 | 80 | ---- |
71 | 81 | |
72 | | = Converting Projects To Tickets = |
| 82 | = Old Project Descriptions = |
73 | 83 | |
74 | | We have started converting each of the projects listed here to tickets. Any help in the process is appreciated. |
| 84 | We used to describe open projects using a link to the project page and a short text description, but now we use tickets to describe open project ideas. Most of the projects that have interest from a mentor or the community have been converted. The remaining project descriptions in this section have not been converted yet, and may or may not be of interest. Please ask on the devel@rtems.org mailing list if you have interest in any of these projects. Project descriptions that are determined interesting to RTEMS Project should be converted to a Trac Ticket, while the descriptions deemed uninteresting should be moved to the Obsolete Projects section at the bottom of this page. |
75 | 85 | |
76 | | Projects that have the 'strike-through' font have been moved to Trac Tickets. |
77 | | |
78 | | = Testing = |
79 | | |
80 | | Testing a large body of software like RTEMS is in a continual state of improvement. There is always a need for more test cases and easier ways to run them all and decode the results. In addition, we want to be able to run all tests on as many hardware and simulator configurations as possible. Testing doesn't sound exciting to most people but when you combine the breadth of what we need to test with our desire for 100% instruction and branch path coverage, you get some very interesting and challenging work. |
81 | | |
82 | | Some of the identified activities which would augment our testing capabilities are listed here: |
| 86 | * Testing |
83 | 87 | * ''[wiki:Projects/Open/TestSpecification RTEMS Test Specification]'' - Develop a formal test specification. |
84 | 88 | * [wiki:Projects/Open/TestScreenValidation RTEMS Test Screen Validation] - Create a tool to validate test output. |
89 | 93 | * ''[wiki:Projects/Open/Fault_injection Fault tolerance]'' - get a fault injection tool to work with RTEMS and create tutorials and examples. |
90 | 94 | |
91 | | = Development Ecosystem = |
92 | | |
93 | | RTEMS applications are cross-compiled on a development host to produce executables that are transferred to and executed on target systems. The projects in this section focus on the host side of that equation. This means they will run on a developer's computer and possibly communicate with embedded hardware. |
94 | | |
95 | | The following areas have been identified for projects related to improving RTEMS development: |
96 | | |
| 95 | * Development Ecosystem |
97 | 96 | * [wiki:Projects/Open/ConfigGUI Config GUI (Python)] - GUI for configuring RTEMS build. |
98 | 97 | * [wiki:Projects/Open/BuildVariables Build Variables (Python)] - Add bounds checking for all build options as well as cleanup. |
109 | 108 | * [wiki:Projects/Open/ArgoUML ArgoUML] - UML for RTEMS. |
110 | 109 | |
111 | | = RTEMS Run-Time Oriented = |
112 | | |
113 | | The projects in this category are more focused on the development of software that runs on RTEMS on target hardware. |
114 | | |
115 | | = Executive (!SuperCore, SuperCoreCPU, libcpu): a.k.a. kernel = |
116 | | |
| 110 | * Executive (!SuperCore, SuperCoreCPU, libcpu): a.k.a. kernel |
117 | 111 | * ''[wiki:Projects/Open/ImproveSMP Improvements to SMP support]'' - Propose an improvement to the existing [wiki:Developer/SMP SMP capabilities]. |
118 | 112 | * [wiki:Projects/Open/UnifiedInterrupts Unified Interrupts] - Unify the interrupt and PCI interfaces. |
120 | 114 | * ''[wiki:Projects/Open/Paravirtualization Paravirtualization]''- Make RTEMS suitable to run as a guest in a hypervisor. |
121 | 115 | |
122 | | = Run-Time Statistics = |
123 | | |
| 116 | * Run-Time Statistics |
124 | 117 | * ''[wiki:Projects/Open/CPU_Statistics CPU Statistics]'' - Improvements to CPU Usage Statistics. |
125 | 118 | * ''[wiki:Projects/Open/StackChecker Stack Checker]'' - Improvements to Stack Bounds Checker. |
126 | 119 | |
127 | | = Board Support Package (BSP) = |
128 | | |
| 120 | * Board Support Package (BSP) |
129 | 121 | * [wiki:Projects/Open/EdisonBSP x86 Edison] - on hold due to unavailability of open information |
130 | 122 | |
131 | | = API Layers (POSIX, Classic, SAPI) = |
132 | | |
| 123 | * API Layers (POSIX, Classic, SAPI) |
133 | 124 | * [wiki:Projects/Open/OSEK OSEK] - Implement [http://portal.osek-vdx.org/ OSEK] automotive APIs. |
134 | 125 | * [wiki:Projects/Open/ProgammableLogicController Programmable Logic Controller] - Enable RTEMS as a [http://en.wikipedia.org/wiki/Programmable_logic_controller Programmable Logic Controller (PLC)]. |
135 | 126 | * ''[wiki:Projects/Open/ARINC653API ARINC653 in RTEMS]'' - Implement ARINC-653 avionics APIs. |
136 | 127 | |
137 | | = rtems-libbsd = |
138 | | |
| 128 | * rtems-libbsd |
139 | 129 | * [wiki:Projects/TCP/IP_update Update the RTEMS TCP/IP stack] - Ask about possibilities about Ethernet over USB and Wifi support. |
140 | 130 | * [wiki:TBR/UserManual/USBStack USB stack] - Ask about possible addition of other device types. |
141 | 131 | |
142 | | = Languages = |
143 | | |
| 132 | * Languages |
144 | 133 | * [wiki:Projects/Open/Mono Mono On RTEMS] - Add support for [http://www.mono-project.com Mono]. |
145 | 134 | * [wiki:Projects/Open/V8 Port V8 JavaScript Engine to RTEMS] - Add support for the [http://code.google.com/p/v8/ V8 Engine]. |
146 | 135 | * [wiki:Projects/Open/SWIGforRTEMS SWIG on RTEMS] - Add support for SWIG. |
147 | 136 | |
148 | | = Libraries and Applications = |
149 | | |
| 137 | * Libraries and Applications |
150 | 138 | * [wiki:Projects/Open/InternetOfThings] Internet of Things (IoT) - Port IoT infrastructure |
151 | 139 | * [wiki:Projects/Open/PortMonkey Port Monkey HTTP Server] - Port the [http://monkey-project.com/ Monkey HTTP Server]. |
