Changes between Version 461 and Version 462 of Developer/OpenProjects
- Timestamp:
- 11/14/18 00:11:23 (5 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v461 v462 20 20 * The Summary field of the ticket is the title of the open project. 21 21 * The Description field of the ticket is the project detail. Please use the [https://devel.rtems.org/wiki/WikiFormatting WikiFormatting] to enhance the readability of the project's details. If you are not sure please review existing open projects as an example. 22 * Set the Type field of the ticket as "project". This is done if you clickon the New Ticket link above.23 * Set the Milestone field to be "Indefinite". This is done if you clickon the New Ticket link above.22 * Set the Type field of the ticket as "project". This would have already been filled if you clicked on the New Ticket link above. 23 * Set the Milestone field to be "Indefinite". This would have already been filled if you clicked on the New Ticket link above. 24 24 * If this is a SoC Project one of the mentors of the project should be mentioned in the Owner field and you should CC the rest of the mentors. If no mentors are mentioned, keep the fields blank. 25 25 * The Keywords field should be set to "SoC" denoting any projects that can participate in the Summer of Code. The keyword is case sensitive.
