Changes between Version 452 and Version 453 of Developer/OpenProjects
- Timestamp:
- 03/02/17 20:44:05 (7 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v452 v453 94 94 * ''[wiki:Projects/Open/StackAnalysis Static Analysis of Stack Usage]'' - Develop a tool for static analysis of stack usage. 95 95 * ''[wiki:Projects/Open/PythonCoverageReporting Python Coverage Reporting (Python)]'' - Convert coverage reporting to Python and integrate into RTEMS Tools. 96 * ~~ [wiki:Projects/Open/TesterImprovements RTEMS Test Improvements (Python)]- Improve RTEMS Tester (rtems-test) by adding simulator recipes for more simulators.~~96 * ~~'' '''[wiki:Projects/Open/TesterImprovements RTEMS Test Improvements (Python)]''' '' - Improve RTEMS Tester (rtems-test) by adding simulator recipes for more simulators.~~ 97 97 * [wiki:Projects/Open/GCovReports GCov Reports] - Use gcov output as generated by covoar to generate useful reports. 98 98 * [wiki:Projects/Open/GProfReports GProf Reports] - Use gprof output as generated by covoar to generate useful reports. … … 130 130 * ~~~[wiki:Projects/Open/Emulatei386BIOS x86 BIOS emulation for VESA] - This is Pavel Pisa's idea.~~~ 131 131 * ~~~[wiki:Projects/Open/MicroblazePort Port RTEMS to Microblaze architecture] - New architecture port.~~~ 132 * [wiki:Projects/Open/SimulatorBSPs More BSPs for Simulators] - RTEMS can always use more BSPs for simulators (and readily available boards or open cores).132 * ~~~[wiki:Projects/Open/SimulatorBSPs More BSPs for Simulators] - RTEMS can always use more BSPs for simulators (and readily available boards or open cores).~~~ 133 133 * ~~~[wiki:Projects/Open/MemoryProtection Memory Protection] - Implement MMU low-level support code for more BSPs.~~~ 134 134 * ~~~''[wiki:Projects/Open/MergeLEON Merge Leon]'' - Merging Gaisler LEON support code into mainstream RTEMS.~~~
