Changes between Version 423 and Version 424 of Developer/OpenProjects
Ignore:
Timestamp:
03/12/15 15:09:59 (9 years ago)
Author:
Gedare Bloom
Comment:
Fix links to obsolete projects.
Legend:
Unmodified
Added
Removed
Modified
  • Developer/OpenProjects
    v423 v424
    150150Some projects have been proposed that are viewed as being of minor use. This list is meant to provide a way to avoid wasted effort on projects that are not widely desired. However, projects on this list might still be useful to someone, given a motivated individual to work on them.
    151151
    152  *  Various ideas have been proposed related to using RTEMS as a [wiki:Projects/Hypervisor  hypervisor]. The lack of protected (kernel mode) execution precludes any feasible implementations.
    153  *  Merge [wiki:Developer/Simulators/SimpleScalar  BSP for Simplescalar simulator]. The BSP is heavily bit-rotted and the simulator is a dead project.
    154  *  [http://code.google.com/p/rosetta-os Rosetta OS] [wiki:Projects/RosettaOSDeviceDriverAPI  OS Independent Device Driver API].
     152 *  Various ideas have been proposed related to using RTEMS as a [wiki:Developer/Projects/Obsolete/Hypervisor  hypervisor]. The lack of protected (kernel mode) execution precludes any feasible implementations.
     153 *  Merge [wiki:Developer/Projects/Obsolete/SimpleScalar  BSP for Simplescalar simulator]. The BSP is heavily bit-rotted and the simulator is a dead project.
     154 *  [http://code.google.com/p/rosetta-os Rosetta OS] [wiki:Developer/Projects/Obsolete/RosettaOSDeviceDriverAPI  OS Independent Device Driver API].
    155155 *  Implement current version of µITRON Interface [http://www.www.tron.org/index-e.html]. itron support was removed from RTEMS due to lack of interest.
    156  *  More [[TBR/Delete/Libbsd-port| NIC device drivers]]. See instead [wiki:Projects/TCP/IP_update TCP/IP update].
    157  *  Integrate [wiki:Projects/CEXP CEXP] into main RTEMS distribution. Possible licensing issues, please apply to the RTL project instead.
    158  *  Scripts and documentation for creating and installing prebuilt tool packages [wiki:Building/RPM_Packages Building Tool RPM Packages], [[Building/DebianHostedTools| Debian Packages]], [[TBR/Delete/MacOSHostedTools|MacOS tools]], [wiki:TBR/UserManual/MinGW_Tools_for_Windows MinGW Tools for Windows], [wiki:TBR/Delete/Canadian_Cross_Compiler Canadian Cross Compiler]. Please apply to the [wiki:Projects/Open/ImproveRSB RSB] project instead.
     156 *  More [wiki:Developer/Projects/Obsolete/Libbsd-port NIC device drivers for the old networking stack]. See instead [wiki:Projects/TCP/IP_update new TCP/IP stack].
     157 *  Integrate [wiki:Developer/Projects/Obsolete/CEXP CEXP] into main RTEMS distribution. Possible licensing issues, please apply to the RTL project instead.
     158 *  Scripts and documentation for creating and installing prebuilt tool packages [wiki:Developer/Projects/Obsolete/RPM_Packages Building Tool RPM Packages], [wiki:Developer/Projects/Obsolete/DebianHostedTools Debian Packages], [wiki:Developer/Projects/Obsolete/MacOSHostedTools MacOS tools], [wiki:TBR/UserManual/MinGW_Tools_for_Windows MinGW Tools for Windows], [wiki:Developer/Projects/Obsolete/Canadian_Cross_Compiler Canadian Cross Compiler]. Please apply to the [wiki:Projects/Open/ImproveRSB RSB] project instead.
