Changes between Version 413 and Version 414 of Developer/OpenProjects
Ignore:
Timestamp:
Feb 17, 2015, 5:02:42 PM (5 years ago)
Author:
Gedare Bloom
Comment:
Fix links.
Legend:
Unmodified
Added
Removed
Modified
  • Developer/OpenProjects
    v413 v414
    4747 * [wiki:Projects/Open/GProfReports GProf Reports] - Use gprof output as generated by covoar to generate useful reports.
    4848 * [wiki:Projects/Open/ImproveRSB Improve RSB] - General improvements to the [wiki:TBR/UserManual/RTEMS_Source_Builder RTEMS Source Builder].
    49  * [wiki:Projects/Open/AddCoverageToGDBSimulators] - Add execution coverage logging/reporting to the simulators supported by GDB and used by the RTEMS Project.
     49 * [wiki:Projects/Open/AddCoverageToGDBSimulators GDB Coverage] - Add execution coverage logging/reporting to the simulators supported by GDB and used by the RTEMS Project.
    5050 * [wiki:Projects/Open/ImproveEclipsePlugin Improve Eclipse Plugin] - Improvements in the [wiki:Developer/Eclipse/Information RTEMS Eclipse Integration].
    5151 * [wiki:Projects/Open/PyGDB Python GDB Support] - Add Python Script support for debugging RTEMS with GDB.
