Changes between Version 331 and Version 332 of Developer/OpenProjects
- Timestamp:
- 05/25/13 19:29:46 (11 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v331 v332 27 27 * [wiki:Projects/TestingImprovements RTEMS Testing]. Testing for RTEMS, including Unit, Regression operational and building a custom test harness. No prior knowledge of software testing is required. 28 28 * '''[wiki:RTEMS_Test_Coverage Test Coverage Analysis]''' - Improve coverage by adding more test cases. Eliminating dead code and reaching 100% coverage helps reduce the likelihood of new and recurrent bugs. 29 * Write a tutorial, modify a [ 29 * Write a tutorial, modify a [http://en.wikipedia.org/wiki/Fault_injection#Research_tools fault injection tool] to work with RTEMS 30 30 * Test the [wiki:Projects/POSIXFIFOs POSIX FIFO Implementation]. 31 31 * [wiki:RTEMSgprof_ Add support for gprof output to covoar]
