- Timestamp:
03/21/13 19:21:18 (11 years ago)
- Author:
Gedare
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v313
v314
30 | 30 | * [wiki:RTEMSgprof_ Add support for gprof output to covoar] |
31 | 31 | * Improve [wiki:Projects/GNUToolsTesting Testing of the GNU Tools] on RTEMS targets |
32 | | * ''[wiki:Testing/Filesystem File System Test Suite]'' |
33 | 32 | * ''[wiki:TBR/Delete/POSIXTimingTests POSIX Timing Tests]'' |
34 | 33 | * ''Add [wiki:RTEMSgcov_ support for gcov output] to covoar so tools like gcov and lcov can be used with RTEMS ([wiki:Projects/GCOVSupport another page here])'' |
64 | 63 | * Unified Interrupt and PCI APIs -- [wiki:UnifiedAPIs UnifiedAPIs] |
65 | 64 | * [wiki:Projects/SystemEvents RTEMS System Events] is a project to add a first class object for events. Currently all event sets are tied to a specific thread. |
66 | | * Support for new Processor Families - Xtensa, Microblaze |
67 | 65 | * Add cache manager support for architectures not having it. |
68 | 66 | * [wiki:Projects/TinyRTEMS TinyRTEMS] is an umbrella term that corresponds to any activities or ideas that could shrink the code and data space requirements for RTEMS. The goal is to progressively lower the minimum CPU requirements. |
69 | 67 | * Improve the RTEMS [wiki:SuperCore_Scheduler_ SuperCore Scheduler] |
70 | | * ''[wiki:Projects/GSoC/Bdbuf_improvements Bdbuf improvements].'' The current block device buffer implementation can benefit from a number of improvements. |
71 | 68 | * ''[wiki:RTEMS_Paravirtualization_ Paravirtualization]'' of RTEMS to make it suitable to be run as a guest OS in a hypervisor. |
72 | 69 | * ''[wiki:MMU_Support_ MMU Support]'' for RTEMS. |
78 | 75 | = API Layers (POSIX, Classic, SAPI) = |
79 | 76 | |
| 77 | * Make rename() implementation POSIX conformant |
80 | 78 | * Implement OSEK Support [http://portal.osek-vdx.org/] |
81 | 79 | * Investigate the feasibility of implementing applicable sections of the [http://en.wikipedia.org/wiki/IEC_61131 IEC 61131] standard to enable RTEMS-enabled hardware to act as a [http://en.wikipedia.org/wiki/Programmable_logic_controller Programmable Logic Controller]. More information on the IEC 61131 standard can be found at http://www.plcopen.org/ . [http://www.beremiz.org/] is an open source framework for automation that may be a useful starting point.. |
112 | 110 | |
113 | 111 | * Testing |
| 112 | * [wiki:Testing/Filesystem File System Test Suite] |
114 | 113 | * Tools |
115 | 114 | * Runtime |
117 | 116 | * [wiki:Projects/Refactor_the_filesystem_infrastructure Refactor the filesystem infrastructure] |
118 | 117 | * Use [wiki:UseHashOrMapInNotepadsAndKeys_ Maps or Hashes] in the implementation of Classic API Notepads and POSIX API Keys. |
| 118 | * [wiki:Projects/GSoC/Bdbuf_improvements Bdbuf improvements]. The current block device buffer implementation can benefit from a number of improvements. |
119 | 119 | * Languages |
120 | 120 | * [wiki:Projects/Parrot Parrot On RTEMS] |
