Changes between Version 245 and Version 246 of Developer/OpenProjects
Ignore:
Timestamp:
Feb 11, 2012, 2:58:30 AM (8 years ago)
Author:
Gedare
Comment:
/* Projects Whose Page Need Updating */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/OpenProjects
    v245 v246
    117117
    118118
    119 The following projects have been worked on and the pages require updating.  There may or may not be enough work remaining to constitute a Summer of Code project.  If you are interested in one of these, please ask on the mailing list or IRC.
     119The following projects have been worked on and the pages require updating.  There may or may not be enough work remaining to constitute an SOC project; many of these are past SOC projects.  If you are interested in one of these, please ask on the mailing list or IRC.
    120120
    121121 *  Implement [wiki:POSIX_Asynchronous_IO_  POSIX Asynchronous and List IO]
    126126 *  [wiki:Projects/Parrot Parrot On RTEMS]
    127127 *  RTEMS port of [wiki:Projects/GCCGoRTEMS  GNU GCC Go]
     128 *  [wiki:Testing/Filesystem  File System Test Suite]
     129 *  [wiki:TBR/Delete/POSIXTimingTests  POSIX Timing Tests]
     130 *  [wiki:GSoC/2011/ISO9660_Filesystem  ISO9660 file system]
     131 *  RTEMS port of the [wiki:Projects/GNUJavaCompiler  GNU Java Compiler (gjc)]
     132 *  Add [wiki:RTEMSgcov_  support for gcov output] to covoar so tools like gcov and lcov can be used with RTE
    128133= Third Party Packages =
    129134
