Changes between Version 190 and Version 191 of Developer/OpenProjects
- Timestamp:
- 05/14/10 02:44:22 (14 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v190 v191 67 67 * Add cache manager support for architectures not having it. 68 68 * Refactor RTEMS scheduler to a modular [wiki:SuperCore_Scheduler_ SuperCore Scheduler] 69 * Investigate the feasibility of implementing applicable sections of the [http://en.wikipedia.org/wiki/IEC_61131 IEC 61131] standard to enable RTEMS-enabled hardware to act as a [http://en.wikipedia.org/wiki/Programmable_logic_controller Programmable Logic Controller]. More information on the IEC 61131 standard can be found at http://www.plcopen.org/ . 69 * Investigate the feasibility of implementing applicable sections of the [http://en.wikipedia.org/wiki/IEC_61131 IEC 61131] standard to enable RTEMS-enabled hardware to act as a [http://en.wikipedia.org/wiki/Programmable_logic_controller Programmable Logic Controller]. More information on the IEC 61131 standard can be found at http://www.plcopen.org/ . [http://www.beremiz.org/] is an open source framework for automation that may be a useful starting point. 70 70 * Port RTEMS to a [http://www.xen.org/ Xen] or other hypervisor environment. 71 71 = Run-Time Projects With Some Work =
