- Timestamp:
01/26/10 02:35:22 (14 years ago)
- Author:
JoelSherrill
- Comment:
/* TinyRTEMS */ Move text to dedicated page
Legend:
- Unmodified
- Added
- Removed
- Modified
v134
v135
139 | 139 | |
140 | 140 | |
141 | | |
142 | | '''Status:''' Ongoing effort with multiple discrete projects. Much progress has made on this goal since 4.7.0 but there is more shrinking left. We are now to the point where the ARM/Thumb BSP rtl22xx_t and h8300/h8sim BSP have ~15K of code in the minimum.exe test. |
143 | | |
144 | | Reduce footprint of minimum RTEMS application. We would like to be able to run on a CPU with only 64K ROM and 16K RAM. This level of target hardware obviously is too small to host some RTEMS features. |
145 | | |
146 | | Currently a minimum RTEMS application assumes that you want items like a shutdown code, initialization of all Classic API Managers, and support for c. Some ideas in |
147 | | this area are captured at [wiki:Projects/TinyRTEMS TinyRTEMS]. The project would focus on breaking linkages between components so they can be configured out by |
148 | | the user, dropped out automatically at link time, or other mechanisms. The goal is to be able to provide the user with a full featured RTEMS |
149 | | library and defer as much configuration as possible to application configuration and link time. |
150 | | |
151 | | One issue that will be an ongoing concern is that the minimum footprint varies by BSP. This is because some BSPs are structured to be lean, while others may have |
152 | | unintentional dependencies. One idea is a tool to assist in identifying RTEMS symbols which are not expected occur in some of the sample applications such minimum, |
153 | | hello, and ticker. This utility could provide guidance on the known reasons this symbol creeps in. For example, placing printk() support in the same file as |
154 | | the console driver will result in the entirety of the Termios subsystem being in the minimum footprint even though it is unused. |
| 141 | See [wiki:Projects/TinyRTEMS TinyRTEMS] for details on the status of this project and remaining activities. |
155 | 142 | = More NIC Drivers = |
156 | 143 | |
