296 | | = Nano-X (formerly MicroWindows) = |
297 | | |
298 | | |
299 | | '''Status:''' Work for [wiki:GSoC Google Summer of Code] is in progress by Roxana Leontie with [wiki:User:AaronGrier_ Aaron Grier] as mentor. Preliminary frame buffer drivers for the pc386 and ARM BSPs have been checked into RTEMS CVS. Patches are still pending submittal to the Nano-X project, and can be found at http://code.google.com/p/rtems-nano-x/ . |
300 | | |
301 | | '''Introduction:''' Nano-X is a graphics library providing both Microsoft- and X Windows-like graphics programming APIs for embedded systems. |
302 | | |
303 | | '''Goal:''' To provide more frame buffer drivers and examples that run on various BSPs. Frame buffer drivers are wanted for BSPs that have simulators. In particular, we would like an appropriately licensed pc386 frame buffer driver for MicroWindows. Any drivers that will run on Skyeye are also desired. |
304 | | |
305 | | '''Requirements:''' The developer should be familiar with RTEMS development. Most of this work can be done outside the RTEMS source tree and treating MicroWindows and its demos as example applications. |
306 | | |
307 | | '''Resources:''' Nano-X ports to RTEMS of various quality are pre-existing. The Nintendo DS BSP submitter is a recent user of it so should be able to provide advice. [wiki:User:AaronGrier_ Aaron Grier] also has some experience with Nano-X on custom hardware. |
308 | | |
309 | | '''Extention and Related Projects:''' |
310 | | |
311 | | * NXLIB -- NXLIB is a binary replacement for the libX11 library to allow applications to be run under Nano-X instead of full-blown X11. It assumes that a native port of the X Window System is available for the target in question, which is often the case for Linux, but not for RTEMS. Rather than port X11 to RTEMS, it seems like it would be more feasible to package the necessary collection of X11 headers and build utilities (imake) for RTEMS and NXLIB. |
312 | | |
313 | | * Qt Embedded (http://qt.nokia.com/products/) -- While the Qt/X11 port could likely be run under NXLIB, performance may be better with a native Nano-X port. |
314 | | |
315 | | * TinyWidgets (http://www.tnw2000.org/) -- Last updated in 2007, but source is still available. |
316 | | |
317 | | * wxWidgets for Microwindows (http://www.wxwidgets.org/docs/embedded.htm#wxmwin) -- incomplete port, appears to need some work to make it threadsafe. |
318 | | |
319 | | * directfb (http://www.directfb.org/) -- Linux' DirectFB API provides additional graphics acceleration and limited windowing support. It may be possible to provide a similar API under RTEMS to allow porting of Linux DirectFB applications. |
320 | | |
321 | | '''URLs:''' |
322 | | |
323 | | * http://www.microwindows.org/ |
| 296 | = RTEMS Graphics Toolkit = |
| 297 | |
| 298 | |
| 299 | See the [wiki:RTEMSGraphicsToolkit#Open_Projects Open Projects] section of the [wiki:Projects/GraphicsToolkit RTEMS Graphics Toolkit] for current status of the kit and ideas for future work. |
