86 | | Chris and Joel have done some initial work and prototyping has been done on the first four parts. Chris wrote the capture engine and this is currently part of RTEMS. The purpose was to look at performance issues relating to filtering, triggering, and storage of events ready for transmission to a host. Together Chris and Joel believe that the bulk of the work adding trace points can be done automatically using the GNU ld "wrap capability" given a user generated list of trace points. The first stage of this task is to extract function signatures from existing libraries then match against the requested list of trace points to generate the wrap code module for the target. The next stage is to integrate this code module with the existing capture engine to allow filtering and triggering. The implementation needs to keep overheads as low as possible and to manage the threading issues that are present in this area of the code. A key requirement is not to change any code in the libraries being traced. |
| 86 | The requirements of the Run-Time tracing is to provide a common means audit an RTEMS application for conformance of input/output parameters and/or timing, or to debug an application. The auditing process typically uses a static configuration the user manages. The debugging process usually targets a standard set of calls such as the RTEMS Classic API and uses dynamic filtering to control what is looked at as the debugging session unfolds. |
| 87 | |
| 88 | Chris and Joel have done some initial work and prototyping has been done on the first four parts. Chris wrote the capture engine and this is currently part of RTEMS ([wiki:TBR/UserManual/Capture_Engine Capture Engine]). The purpose was to look at performance issues relating to filtering, triggering, and storage of events ready for transmission to a host. Together Chris and Joel believe that the bulk of the work adding trace points can be done automatically using the GNU ld "wrap capability" given a user generated list of trace points. The first stage of this task is to extract function signatures from existing libraries then match against the requested list of trace points to generate the wrap code module for the target. Extracting a signature lowers the on going maintenance of the signature as the tool will always match the library being traced. The next stage is to integrate this code module with the existing capture engine to allow filtering and triggering. The implementation needs to keep overheads as low as possible and to manage the threading issues that are present in this area of the code. A key requirement is not to change any code in the libraries being traced. |
