- Timestamp:
03/12/09 17:35:21 (15 years ago)
- Author:
JoelSherrill
- Comment:
/* Small Projects */ break into subnumbers
Legend:
- Unmodified
- Added
- Removed
- Modified
v111
v112
64 | 64 | |
65 | 65 | |
66 | | These are small projects that could be tackled by anyone. |
| 66 | These are small projects that could be tackled by anyone. They are mostly projects which can easily be nibbled on in small work units. |
| 67 | = No Coding Required = |
| 68 | |
67 | 69 | |
68 | 70 | The following requires no coding although it may help to be able to read C code: |
73 | 75 | * Flesh out our POSIX API User's Guide |
74 | 76 | * RTEMS supports the POSIX 1003 standard following the "single process, multi-threaded" profile. We have permission from The Open Group and IEEE to excerpt text from their standards (available online) for use in this manual if cited. This manual is in the doc/posix_users directory in the source tree and by looking at it, I am sure you can find something that needs to be written. The corresponding code is in cpukit/posix or cpukit/libcsupport. |
| 77 | = Modest Coding Required = |
| 78 | |
75 | 79 | |
76 | 80 | The following require only modest coding experience. Remember you can test RTEMS on a simulator so no special hardware is required. |
