Changes between Version 105 and Version 106 of Developer/OpenProjects
- Timestamp:
- 02/19/09 08:52:42 (15 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v105 v106 256 256 Some notes: The shell interface and code is better than the monitor. The shell uses FILE handles and this is nice for redirection and multi-user usage (a threaded version). It also supports a command history. The caller should provide the terminal type. This could be a string or a pointer to the terminal data returned to the caller after a call to get the terminal data with a string. It is recommended to review some of the keys actions, for example C-f, to make sure they are considered standard in relation to a normal shell. One should consider cutting out the code that disables echo and obtains the password and putting it in getpass(). See the linux man page. We don't 257 257 have a controlling /dev/tty so just make it work exactly like it does now. 258 = Dynamic Object File Loading = 259 260 261 '''Status:''' No active volunteers. 262 263 '''Mentor:''' Chris Johns 264 265 Dynamic object file loading or dynamic linking provides a way for RTEMS to run-time link an application from relocatable object files or libraries. This task is to implement the functionality using the IEEE standard API based on {{{<dlfcn.h> 266 </code> interface more commonly know as {{{dlopen</open>. The intention is for this work to build on the work by Till Straumann and the CEXP package. For more detail on the task the [Dynamic Object File Loading] page in this Wiki. 258 267 = Third Party Packages = 259 268
