Changes between Version 14 and Version 15 of Developer/Laboratory
- Timestamp:
- 03/25/11 19:43:24 (13 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v14 v15 2 2 3 3 4 OAR hosts the RTEMS Laboratory for the RTEMS Project. It provides remote access to a collection of target boards for testing including the ability to remotely power the boards on and off. The serial ports from the target boards and remote power control modules are offered over the network using the [http://sourceforge.net/projects/sercd sercd] package which implements the RFC2217 protocol for access to serial devices over a network. Each control computer, Wales and Germany, in the lab has a parallel port which may be used at some point in the future for BDM modules for boards that need those. The preferred model for a board to operate is to provide a serial port console with a monitor for control and to download via the network. The individual boards can then be configured to download from the RTEMS development machine, England.4 OAR hosts the RTEMS Laboratory for the RTEMS Project. It provides remote access to a collection of target boards for testing including the ability to remotely power the boards on and off. The serial ports from the target boards and remote power control modules are offered over the network using the [http://sourceforge.net/projects/sercd sercd] package which implements the RFC2217 protocol for access to serial devices over a network. Each control computer, rtrack2 and rtrack3, in the lab has a parallel port which may be used at some point in the future for BDM modules for boards that need those. The preferred model for a board to operate is to provide a serial port console with a monitor for control and to download via the network. The individual boards can then be configured to download from the RTEMS development machine, England. 5 5 6 The remote control power switches are Western Telematic RPB+ ([http://www.wti.com/guides/rpbp_b.pdf User's Guide]. On both Wales and Germany, the RPB+ is connected to /dev/ttyS0 and offered on port 7000.6 The remote control power switches are Western Telematic RPB+ ([http://www.wti.com/guides/rpbp_b.pdf User's Guide]. On rtrack2, the RPB+ is connected to /dev/ttyS0 and offered on port 40000. On rtrack3, the RPB+ is connected to /dev/ttyS0 and offered on port 7000. 7 7 8 8 NOTE: This lab is currently under development and all of the boards we have are not hooked up yet. If you would like to donate a board which uses a BSP in the RTEMS development tree for use in the lab, please contact [wiki:TBR/User/JoelSherrill JoelSherrill]. … … 15 15 |'''Host''' || '''Serial Port''' || '''Port''' || '''Plug Number''' || '''BSP''' || '''Board''' || '''Note''' 16 16 |- 17 | RTRACK2 || /dev/ttyS 1 || 7001 || NA || free ||17 | RTRACK2 || /dev/ttyS0 || 40000 || NA || NA || NA || Remote Power Boot Controller 18 18 |- 19 | RTRACK2 || /dev/ttyUSB0 || 7002 || 2 || icecube || Embedded Planets EP-5200 || not configured to boot from england yet19 | RTRACK2 || /dev/ttyUSB0 || 40002 || 1 || mrm332 || Mini Robomind MRM332 || no network, load through serial port 20 20 |- 21 | RTRACK2 || /dev/ttyUSB1 || 7003 || 1 || pc386 || WINSYSEMS EBC-855 (COM1-Console) || not configured to boot from england yet21 | RTRACK2 || /dev/ttyUSB1 || 40003 || 2 || pc386 || WINSYSEMS EBC-855 (COM1-Console) || 22 22 |- 23 | RTRACK2 || /dev/ttyUSB2 || 7004 || 3 || mpc8313erdb || Freescale MPC8313E RDB || not configured to boot from england yet23 | RTRACK2 || /dev/ttyUSB2 || 40004 || 3 || mcf52235 || Lite 5200B || 24 24 |- 25 | RTRACK2 || /dev/ttyUSB 2 || 7004 || 4 || mcf52235|| [wiki:TBR/BSP/Mcf52235 Freescale MCF52235EVB] || not configured, no net cable25 | RTRACK2 || /dev/ttyUSB3 || 40005 || 4 || icecube || [wiki:TBR/BSP/Mcf52235 Freescale MCF52235EVB] || not configured, no net cable 26 26 |- 27 | RTRACK2 || /dev/ttyUSB 3 || 7005 || 5 || mvme167 || [wiki:TBR/BSP/Mvme167 Motorola MVME167] || has coax network connector27 | RTRACK2 || /dev/ttyUSB4 || 40006 || 5 || lpc24xx_ea || LPC 2478 || ttyUSB4 not available until board is powered 28 28 |- 29 | RTRACK3 || /dev/ttyS 1 || 7001 || NA || free || ||29 | RTRACK3 || /dev/ttyS0 || 7000 || NA || NA || NA ||Remote Power Boot Controller 30 30 |- 31 | RTRACK3 || /dev/ttyUSB0 || 7002 || 1 || m cf5235 || Axiom 5235 || not configured to boot31 | RTRACK3 || /dev/ttyUSB0 || 7002 || 1 || mpc8313erdb || Freescale MPC8313E RDB || 32 32 |- 33 | RTRACK3 || /dev/ttyUSB1 || 7003 || NA || free || ||33 | RTRACK3 || /dev/ttyUSB1 || 7003 || 2 || mcf5235 || Axiom 5235 || 34 34 |- 35 | RTRACK3 || /dev/ttyUSB2 || 7004 || NA || free || ||35 | RTRACK3 || /dev/ttyUSB2 || 7004 || 3 || mvme162 || [wiki:TBR/BSP/Mvme162 Motorola MVME162] || 36 36 |- 37 | RTRACK3 || /dev/ttyUSB3 || 7005 || 5 || mvme162 || [wiki:TBR/BSP/Mvme162 Motorola MVME162] || needs network configured, unsure if net working37 | RTRACK3 || /dev/ttyUSB3 || 7005 || 4 || mvme167 || [wiki:TBR/BSP/Mvme167 Motorola MVME167] || 38 38 |- 39 39 |} … … 41 41 42 42 43 The following boards are currently in the lab but not yet hooked up to wales or germany and offered over the net. Each board added to the lab setup presents its own unique configuration and cabling challenge rs.43 The following boards are currently in the lab but not yet hooked up to wales or germany and offered over the net. Each board added to the lab setup presents its own unique configuration and cabling challenges. 44 44 45 * [http://www.versalogic.com/products/ds.asp?productid=135 Versalogic Bobcat PC-104 Motorola MVME162] - need help with net booting 46 * [[http://www.robominds.com/ Mini RoboMind MRM332]] -- [[mrm332]] 45 * [http://www.versalogic.com/products/ds.asp?productid=135 Versalogic Bobcat PC-104 Motorola MVME167] - need help with net booting
