Changes between Version 51 and Version 52 of Developer/Git
Ignore:
Timestamp:
Jul 27, 2013, 7:16:43 PM (7 years ago)
Author:
ChrisJohns
Comment:
/* Git Access for Committers */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Git
    v51 v52
    4242
    4343The [wiki:Developer/GitCommitters Git Committers] page has policies and procedures for committers to make changes to the RTEMS repositories.
     44=  Git Commits  =
     45
     46When committing a change the first line is a summary. Please make it short while hinting at the nature of the change. You can argument the change if you wish with a PR number. After the first line leave an empty line and add what ever required detail you feel is needed.
     47
     48Please to not use terms such as "Fix bug" or "With this change it works". If you fix a bug please state the nature of the bug and why this change fixes it. If a change makes something work then detail the reason. You do not need to explain the change line by line as the commits diff will.
     49
     50If you change formatting please make that a separate patch and use "Formatting changes only" on the first line.
    4451=  Learn more about Git  =
    4552Links to site with good Git information.
