Changes between Version 16 and Version 17 of Developer/Git/Committers
- Timestamp:
- 11/21/13 03:16:41 (9 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v16 v17 177 177 }}} 178 178 The git log stage will show your newly pushed patches if everything worked properly, and you can delete the am branch created. The git push at the end will push the changes up to your personal repository. 179 180 Another way to do this which pushes directly to the upstream is shown here in an example which simply (and quickly) applies a patch to the branch: 181 182 {{{ 183 git checkout -b rtems4.10 --track remotes/upstream/4.10 184 cat /tmp/sp.diff | patch 185 vi sparc.t 186 git add sparc.t 187 git commit -m "sparc.t: Correct for V8/V9" 188 git push upstream rtems4.10:4.10 189 git checkout master 190 git log 191 git branch -d rtems4.10 192 }}} 179 193 = Ooops! = 180 194
