- Timestamp:
01/12/13 22:51:02 (11 years ago)
- Author:
Mat
- Comment:
"Contract" should be "Contact"
Legend:
- Unmodified
- Added
- Removed
- Modified
v28
v29
19 | 19 | The code and data size depends on the file system being used. A simple TFTP type file system has a small foot print but does require a networking stack. A block device file system such as the FAT file system has the overhead of implementing a full file system plus the cache. |
20 | 20 | |
21 | | Real-time use of a file system is a complex issue and beyond the scope of this topic. Dr Joel Sherrill's PHD thesis studied real-time file-systems and concluded the whole system from application to driver needs to be considered when handling real-time data. You should contract Joel if you would like advise on this topic. Typically an application would read configuration type data into memory rather than use the file-system directly. |
| 21 | Real-time use of a file system is a complex issue and beyond the scope of this topic. Dr Joel Sherrill's PHD thesis studied real-time file-systems and concluded the whole system from application to driver needs to be considered when handling real-time data. You should contact Joel if you would like advise on this topic. Typically an application would read configuration type data into memory rather than use the file-system directly. |
22 | 22 | |
23 | 23 | RTEMS supports the following file systems: |
