Changes between Version 22 and Version 23 of Developer/Eclipse/Plugin
- Timestamp:
- 11/22/14 05:25:56 (9 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v22 v23 7 7 = Introduction = 8 8 9 This page describes how to setup and use the RTEMS Eclipse Plug-in. This plug-in extends [http://www.eclipse.org/cdt CDT] and all features of a full-fledged !Eclipse/CDT IDE with an ordinary GNU toolchain are available. The GDB based debug support works also. Supported platforms are: Cygwin, MinGW, MacOS X and UNIX. Every RTEMS target architecture and BSP that provides the standard Makefiles is supported. These are at least the ones managed by the RTEMS repository from OAR.9 This page describes how to setup and use the RTEMS Eclipse Plug-in. This plug-in extends [http://www.eclipse.org/cdt CDT] and all features of a full-fledged Eclipse/CDT IDE with an ordinary GNU toolchain are available. The GDB based debug support works also. Supported platforms are: Cygwin, MinGW, MacOS X and UNIX. Every RTEMS target architecture and BSP that provides the standard Makefiles is supported. These are at least the ones managed by the RTEMS repository from OAR. 10 10 11 11 = Starting Point =
