Changes between Version 9 and Version 10 of Developer/Eclipse/Plugin
Ignore:
Timestamp:
Dec 8, 2009, 2:01:40 PM (11 years ago)
Author:
Sh
Comment:
/* Introduction */
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Eclipse/Plugin
    v9 v10
    77= Introduction =
    88
    9 This page describes how to setup and use the RTEMS Eclipse Plug-in.  This plug-in extends [http://www.eclipse.org/cdt CDT] and most features of a full-fledged Eclipse/CDT IDE with an ordinary GNU toolchain are available (debugging is not yet tested).  Supported platforms are: Cygwin, MinGW, MacOS X and UNIX.  Every RTEMS target architecture and BSP that provides the standard Makefiles is supported.  These are at least the ones managed by the RTEMS repository from OAR.
     9This page describes how to setup and use the RTEMS Eclipse Plug-in.  This plug-in extends [http://www.eclipse.org/cdt CDT] and all features of a full-fledged Eclipse/CDT IDE with an ordinary GNU toolchain are available.  The GDB based debug support works also.  Supported platforms are: Cygwin, MinGW, MacOS X and UNIX.  Every RTEMS target architecture and BSP that provides the standard Makefiles is supported.  These are at least the ones managed by the RTEMS repository from OAR.
    1010= Starting Point =
    1111
