Changes between Version 5 and Version 6 of Developer/Coverage/Analysis
- Timestamp:
- 01/03/16 18:23:11 (8 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
v5 v6 3 3 = The project aims are as follows: = 4 4 5 * To perform automated coverage testing on the RTEMS code base and analy se the object level coverage provided by the RTEMS test suite5 * To perform automated coverage testing on the RTEMS code base and analyze the object level coverage provided by the RTEMS test suite 6 6 * Identify and report parts of code that are not being exercised under the test suites 7 * Analy se each case separately and classify into categories previously identified.7 * Analyze each case separately and classify into categories previously identified. 8 8 * Address each of these cases and eliminate them. 9 9 … … 12 12 13 13 Total Uncovered Ranges: 208 14 Total Bytes Analy sed: 7160414 Total Bytes Analyzed: 71604 15 15 Total Bytes not executed: 2732 16 16 Percentage of executed bytes: 0.9618
