Changes between Version 9 and Version 10 of Developer/Contributing
Ignore:
Timestamp:
Mar 4, 2012, 4:23:16 AM (8 years ago)
Author:
Gedare
Comment:
Prune website changes
Legend:
Unmodified
Added
Removed
Modified
  • Developer/Contributing
    v9 v10
    3939With documentation changes, you must make the doc manuals and correct any errors.
    4040
    41 Changes to the web site must validate as XHTML 1.0 Transitional. The web pages as checked into CVS do not include DOCTYPE declarations; they are automatically added when the web server checks out its copy. To validate your changes, temporarily insert this header in place of the <html> tag, then use the "upload file" mode of the validator.
    42
    43 {{{
    44     <?xml version="1.0" encoding="ISO-8859-1"?>
    45     <!DOCTYPE html
    46               PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    47               "DTD/xhtml1-transitional.dtd">
    48     <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
    49 }}}
    50
    5141In all cases you must test exactly the change that you intend to submit; it's not good enough to test an earlier variant. The tree where you perform this test should not have any other changes applied to it, because otherwise you cannot be sure that your patch will work correctly on its own. Include all your new test cases in your testsuite run.
    5242= Patches =
