Changes between Version 2 and Version 3 of Debugging/sis
Ignore:
Timestamp:
Nov 9, 2017, 6:51:10 AM (3 years ago)
Author:
Sebastian Huber
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Debugging/sis
    v2 v3
    1
    21[[TOC(Debugging/sis, depth=2)]]
    32
    2322
    2423{{{
    25 $ sparc-rtems4.12-sis -leon2 ./sparc-rtems4.12/c/leon3/testsuites/samples/cdtest/cdtest.exe
     24$ sparc-rtems5-sis -leon2 ./sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe
    2625
    2726 SIS - SPARC instruction simulator 2.8,  copyright Jiri Gaisler 1995
    7574
    7675{{{
    77 $ sparc-rtems4.12-gdb cdtest.exe
     76$ sparc-rtems5-gdb cdtest.exe
    7877GNU gdb (GDB) 7.12
    7978Reading symbols from cdtest.exe...done.
    10099{{{
    101100(gdb) run
    102 Starting program: /home/jiri/src/rtems/b1/sparc-rtems4.12/c/leon3/testsuites/samples/cdtest/cdtest.exe
     101Starting program: /home/jiri/src/rtems/b1/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe
    103102
    104103Breakpoint 1, memcpy (dst0=0x40fffcd0, src0=0xfffff000, len0=32)
    143142
    144143{{{
    145 $ sparc-rtems4.12-gdb ./sparc-rtems4.12/c/leon3/testsuites/samples/cdtest/cdtest.exe
     144$ sparc-rtems5-gdb ./sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe
    146145GNU gdb (GDB) 7.12
    147 Reading symbols from ./sparc-rtems4.12/c/leon3/testsuites/samples/cdtest/cdtest.exe...done.
     146Reading symbols from ./sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe...done.
    148147(gdb) tar sim -leon3
    149148Connected to the simulator.
    150149(gdb) load
    151150(gdb) run
    152 Starting program: /home/jiri/src/rtems/b1/sparc-rtems4.12/c/leon3/testsuites/samples/cdtest/cdtest.exe
     151Starting program: /home/jiri/src/rtems/b1/sparc-rtems5/c/leon3/testsuites/samples/cdtest/cdtest.exe
    153152
    154153
    181180
    182181{{{
    183 $ rtems-test --rtems-bsp=leon3-sis sparc-rtems4.12/c/leon3/testsuites
     182$ rtems-test --rtems-bsp=leon3-sis sparc-rtems5/c/leon3/testsuites
    184183[  1/568] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   | sparc/leon3: dhrystone.exe
    185184[  3/568] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   | sparc/leon3: whetstone.exe
    231230
    232231{{{
    233 $ ddd --debugger sparc-rtems4.12-gdb cdtest.exe &
     232$ ddd --debugger sparc-rtems5-gdb cdtest.exe &
    234233}}}
    235234
