Changes between Version 8 and Version 9 of Building/RTEMS
Ignore:
Timestamp:
01/03/16 20:17:34 (7 years ago)
Author:
Ralph Holmes
Comment:
Fix broken links.
Legend:
Unmodified
Added
Removed
Modified
  • Building/RTEMS
    v8 v9
    1 = BuildingRTEMS =
     1= Building RTEMS =
    22
     3The primary source of information about building and configuring RTEMS is the '''''Getting Started''''' manual for the RTEMS version you are using (see https://docs.rtems.org/releases/), although the [wiki:TBR/UserManual/Quick_Start Quick Start] manual may also be of use.
    34
    4
    5 [[TOC(Building/RTEMS, depth=2)]]
    6
    7
    8 The primary source of information about building and configuring RTEMS is '''always''' the '''''Getting Started''''' manual for the RTEMS version you are using (see http://www.rtems.com/onlinedocs.html.
    9
    10 The recommended approach to building tools is to use the [wiki:TBR/UserManual/RTEMS_Source_Builder RTEMS Source Builder], which may also be used to build RTEMS.
     5The recommended approach to building tools is to use the [wiki:Developer/Tools/RSB RTEMS Source Builder], which may also be used to build RTEMS.
