Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
Changes between Version 10 and Version 11 of Boards/Zynq - Zedboard
Ignore:
Timestamp:
02/09/17 02:13:06 (7 years ago)
Author:
Chris Johns
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Boards/Zynq - Zedboard
    v10 v11
    332332
    333333'''Note:'''
    334 1. The `-nx` is being used to stop loading any `.gdbinit` files. This done when testing the GDB connection. For a real development environment you should create a suitable `.gdbinit` file.
     3341. The GDB `-nx` option is being used to stop loading any `.gdbinit` files. This done when testing the GDB connection. For a real development environment you should create a suitable `.gdbinit` file.
    3353352. The remote port on the RTEMS target is `1122`. You can configure this in the RTEMS application.
    3363363. Killing the session using the `kill` command reboots the target. If you have updated the executable on the TFTP before running this command a new version of the application will be download.
