Changes between Initial Version and Version 2 of Ticket #4115
Ignore:
Timestamp:
10/05/20 06:47:22 (3 years ago)
Author:
Sebastian Huber
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Ticket #4115
    • Property Owner set to Sebastian Huber
    • Property Status changed from new to assigned
    • Property Summary changed from Cortex-A9 MPCore based BSPs should include the workaround for Errata 845369 (cloned) to Cortex-A9 MPCore based BSPs should include the workaround for Errata 794072 and 845369
  • Ticket #4115 – Description
    initial v2
    11Cloned from #4114:
    22----
    3 The workaround may be already set up by the bootloader. Not having the workaround applied may lead to system crashes, so make sure the BSP sets it also during system startup.
     3The workaround may be already set up by the bootloader. Not having the workaround applied may lead to system crashes, so make sure the BSP does it during system startup.
