Changes between Initial Version and Version 1 of Ticket #3892
- Timestamp:
- 02/29/20 05:58:45 (4 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Ticket #3892 – Description
initial v1 12 12 A qualified developer for this project does not need to know anything about RTEMS or an RTOS in general. 13 13 14 ---- 14 15 15 16 = Project = … … 29 30 * Tutorial using new Python utility for running code on hardware. 30 31 32 === What you will learn === 33 34 * How to properly test Python software. 35 * Using code coverage tools. 36 * Using performance tools. 37 * Writing technical documentation both in and out of source., 38 * Writing a beginner tutorial from a technical perspective. 39 * Library/API design and consumption. 40 * Using modern documentation tools. 41 31 42 32 43 == Prerequisite == … … 38 49 39 50 40 == Good to Have ==51 == Good to have == 41 52 42 53 None of these are required but having them will strengthen a candidates chances of being accepted. … … 47 58 48 59 49 == Current Tools == 60 == Current tools == 61 62 The following tools are among the programs that current exist that need to be worked on. 63 64 * [https://git.rtems.org/rtems-tools/ rtems-run] 65 * [https://git.rtems.org/rtems-tools/ rtems-test] 66 * [https://git.rtems.org/rtems-tools/ tftp proxy] 67 * [https://git.rtems.org/rtems-source-builder/ rtems-source-builder] 50 68 51 69 52 == New Tools == 70 71 == New tools == 53 72 54 73 Currently, low-level tools exist that help with running binaries on real hardware. However RTEMS lacks a high level management utility for configuring `tftp-proxy`, `rtems-test`, `rtems-run` and `ser2net`.
