Changes between Initial Version and Version 1 of Ticket #3853
- Timestamp:
- 01/08/20 06:38:00 (4 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Ticket #3853 – Description
initial v1 3 3 https://lists.rtems.org/pipermail/devel/2020-January/056728.html 4 4 5 == Approach A 6 5 7 Use c-user/glossary.rst as the project-wide glossary. Generate document-specific glossaries from this file and the use of :term: in the specific document. Add new waf target "./waf regenerate" to carry out the glossary generation. 8 9 == Approach B 10 11 Move the glossary terms to the RTEMS specification (e.g. in the RTEMS sources "spec/glossary/*.yml") and generate the glossary.rst for the documents with a script. This gives us more flexibility and removes the need for the special parser code, see: 12 13 https://lists.rtems.org/pipermail/devel/2020-January/056811.html 14 15 The AV-2 mentioned of the DoD Architecture Framework (DoDAF) wants the glossary terms in categories. We could add categories to the glossary specification items. This would be difficult with a master glossary in reST.
