Changes between Initial Version and Version 1 of Ticket #3425, comment 1
Ignore:
Timestamp:
May 2, 2018, 12:38:48 AM (3 years ago)
Author:
Chris Johns
Comment:
Legend:
Unmodified
Added
Removed
Modified
  • Ticket #3425, comment 1
    initial v1
    1 Please run with `-v` and have a look at the command line and compare it to a similar compile in the testsuite? Is there something in the BSP configuration and is not being set in the BSP's `pkg-config` file?
     1Please run with `-v` and have a look at the command line and compare it to a similar compile in the testsuite? Is there something in the BSP configuration that is not being set in the BSP's `pkg-config` file?
