Changes between Initial Version and Version 1 of Ticket #3186
- Timestamp:
- 10/12/17 16:59:11 (7 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Ticket #3186 – Description
initial v1 1 The rtems_print_buffer() method always uses printk(). It should be changed to use the rtems_printer pattern like cpuuse reports.1 The `rtems_print_buffer()` method always uses `printk()`. It should be changed to use the rtems_printer pattern like cpuuse reports. 2 2 3 3 Documentation will need to be updated as this changes the API and adds at least one method.
