Changes between Version 5 and Version 6 of Ticket #2920
- Timestamp:
- 01/06/20 21:31:43 (4 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Ticket #2920 – Description
v5 v6 43 43 platforms (Linux, BSD, Windows): 44 44 45 * ~~nm is used to generate a list of symbols in a file that is 46 referenced as the symbols of interest for that set. nm is not portable and so must be removed. The fix for this is use rtemstoolkit and generate the list of symbols from the ELF files.~~ 45 * ~~nm is used to generate a list of symbols in a file that is referenced as the symbols of interest for that set. nm is not portable and so must be removed. The fix for this is use rtemstoolkit and generate the list of symbols from the ELF files.~~ 47 46 48 47 * addr2line is piped to dos2unix to find the source lines which match the objdump instruction lines. Again we want to limit the use of external tools that are not portable across platforms.
