Changes between Initial Version and Version 1 of Ticket #2683
- Timestamp:
- 04/04/16 01:48:55 (8 years ago)
Legend:
- Unmodified
- Added
- Removed
- Modified
Ticket #2683 – Description
initial v1 7 7 }}} 8 8 9 I would like the `smp_enabled` variable to always be defined for 4.12 and always set to `false` when RTEMS_SMP is not defined. It is impossible to parse the configuration table with external auditing tools with out this field always being present un tilyou examine the DWARF debug info.9 I would like the `smp_enabled` variable to always be defined for 4.12 and always set to `false` when RTEMS_SMP is not defined. It is impossible to parse the configuration table with external auditing tools with out this field always being present unless you examine the DWARF debug info. 10 10 11 11 I wonder if `User_multiprocessing_table` is the same so this means the members of the configuration table must always be defined.
