# # ChangeLog for ports/beagleboneblack in umon # # Generated by Trac 1.2.1.dev0 # 05/28/24 08:57:01 Tue, 14 Jul 2015 02:11:27 GMT Ed Sutter [b8ffb40] * main/dev/uart16550.c (modified) * ports/beagleboneblack/am335x.h (modified) * ports/beagleboneblack/config.h (modified) * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) * ports/beagleboneblack/xcmdtbl.h (modified) BBB: Changes to support runtime blinking LED. Tue, 14 Jul 2015 00:35:44 GMT Ed Sutter [8107331] * ports/beagleboneblack/envsetup (moved) replace bashrc with envsetup to eliminate implication that it is bash ... Tue, 14 Jul 2015 00:31:45 GMT Ed Sutter [5bed147] * ports/beagleboneblack/fbidemo (deleted) * ports/beagleboneblack/font8x16.h (deleted) * ports/beagleboneblack/lcd_lut.h (deleted) remove files leftover from csb740 port Mon, 13 Jul 2015 23:25:20 GMT Jarielle Catbagan [b919871] * ports/beagleboneblack/sd_setup.sh (modified) BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to ... Wed, 08 Jul 2015 23:27:04 GMT Ed Sutter [812918d] * ports/beagleboneblack/sd_setup.sh (modified) add sync to script to guarantee sd write completes, also missing '1' ... Wed, 08 Jul 2015 21:28:42 GMT Jarielle Catbagan [2945559] * ports/beagleboneblack/README (added) * ports/beagleboneblack/sd_setup.sh (added) BBB: Add sd_setup.sh to create a bootable SD and README to document ... Wed, 08 Jul 2015 21:28:41 GMT Jarielle Catbagan [220ee4b] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/config_header.S (added) BBB: Build a uMon image with a Configuration header and a GP header ... Fri, 03 Jul 2015 17:54:55 GMT Jarielle Catbagan [f344230] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/gp_header.S (added) BBB: Build an MLO file when booting from non-XIP devices (e.g. SD) ... Fri, 03 Jul 2015 17:54:54 GMT Jarielle Catbagan [f94045f] * ports/beagleboneblack/xcmddcl.h (modified) * ports/beagleboneblack/xcmdtbl.h (modified) BBB: xcmddcl.h/xcmdtbl.h: Remove irrelevant commands Fri, 03 Jul 2015 17:54:53 GMT Jarielle Catbagan [dd9f290] * ports/beagleboneblack/Makefile (modified) BBB: Makefile: Remove irrelevant source files from CPUCSRC, IODEVSRC, ... Fri, 03 Jul 2015 17:54:52 GMT Jarielle Catbagan [40b5966] * ports/beagleboneblack/cpuio.c (modified) BBB: cpuio.c: Set devInit() to return 0 by default devInit() is not ... Fri, 03 Jul 2015 17:54:51 GMT Jarielle Catbagan [27db08e] * ports/beagleboneblack/cpuio.h (modified) BBB: cpuio.h: Remove MONARGV0 Fri, 03 Jul 2015 17:54:50 GMT Jarielle Catbagan [d77ed25] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) BBB: cpuio.*: Add UART0 initialization and set DEFAULT_BAUD_RATE to ... Fri, 03 Jul 2015 17:54:49 GMT Jarielle Catbagan [a5f94c8] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/rom_reset.S (modified) BBB: Migrate custom exception handler mapping from rom_reset.S to ... Fri, 03 Jul 2015 17:54:48 GMT Jarielle Catbagan [37e453e] * ports/beagleboneblack/am335x.h (modified) BBB: am335x.h: Fix/update * Fixed file header * Formatted code to ... Mon, 29 Jun 2015 22:23:41 GMT Ed Sutter [08a34d8] * ports/beagleboneblack/Makefile (modified) add support for RTEMS toolset, make this the default Mon, 29 Jun 2015 22:22:03 GMT Ed Sutter [2236db2] * ports/beagleboneblack/config.h (modified) remove APPRAMBASE_OVERRIDE and include DM/PM commands Mon, 29 Jun 2015 22:21:19 GMT Ed Sutter [d6c7226] * ports/beagleboneblack/cpuio.c (modified) cleanup uninitialized variable warning Sat, 20 Jun 2015 14:52:45 GMT Jarielle Catbagan [d468669] * ports/beagleboneblack/rom_reset.S (modified) BBB/AM335x: Store addresses of custom exception handlers in the ... Sat, 20 Jun 2015 05:32:16 GMT Jarielle Catbagan [d47f458] * ports/beagleboneblack/Makefile (modified) Map base Umon image in internal SRAM of AM335x/BBB The internal ... Sat, 20 Jun 2015 05:31:47 GMT Jarielle Catbagan [dfb586e] * ports/beagleboneblack/config.h (modified) Updated BBB CONSOLE_UART_BASE in config.h CONSOLE_UART_BASE in ... Sat, 20 Jun 2015 05:30:54 GMT Jarielle Catbagan [9318819] * ports/beagleboneblack/Makefile (modified) In BBB Makefile, the value of -mcpu in CUSTOM_CFLAGS has been changed ... Sat, 20 Jun 2015 02:58:03 GMT Jarielle Catbagan [4d79fb9] * ports/beagleboneblack/bdi2000.cfg (deleted) Removed bdi2000.cfg in BBB port as it does not target the AM335x Sat, 20 Jun 2015 02:58:02 GMT Jarielle Catbagan [5a9a72f] * ports/beagleboneblack/cpu_gpio.h (deleted) * ports/beagleboneblack/cpu_i2c.c (deleted) * ports/beagleboneblack/cpu_i2c.h (deleted) Removed cpu_gpio.h, cpu_i2c.c, and cpu_i2c.h Sat, 20 Jun 2015 02:58:01 GMT Jarielle Catbagan [35608bb] * ports/beagleboneblack/am335x.h (added) * ports/beagleboneblack/omap3530.h (deleted) * ports/beagleboneblack/ram_reset.S (modified) * ports/beagleboneblack/rom_reset.S (modified) Replaced omap3530.h with am335x.h in BBB port am335x.h contains ... Sat, 20 Jun 2015 02:58:00 GMT Jarielle Catbagan [4df7813] * ports/beagleboneblack/ads7846.c (deleted) * ports/beagleboneblack/ads7846.h (deleted) Removed ads7846.* from BBB port The ADS7846 Interface routines are ... Sat, 20 Jun 2015 02:57:59 GMT Jarielle Catbagan [470b252] * ports/beagleboneblack/cpu.h (modified) Replaced cpu.h with the template cpu.h Sat, 20 Jun 2015 02:57:58 GMT Jarielle Catbagan [ce2a00f] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/nand740.c (deleted) Removed nand740.c from BBB port nand740.c is for the NAND device ... Sat, 20 Jun 2015 02:57:57 GMT Jarielle Catbagan [c0d0e6a] * ports/beagleboneblack/xcmddcl.h (modified) * ports/beagleboneblack/xcmdtbl.h (modified) Removed "ads" command from being included in the common cmdtbl.c from ... Sat, 20 Jun 2015 02:57:56 GMT Jarielle Catbagan [d9ca895] * ports/beagleboneblack/config.h (modified) Updated BBB config.h to target BBB * Updated header comment to ... Sat, 20 Jun 2015 02:57:55 GMT Jarielle Catbagan [6504fc5] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/ad7843.c (deleted) * ports/beagleboneblack/ad7843.h (deleted) Removed ad7843.* from BBB port The AD7843 Interface routines are ... Sat, 20 Jun 2015 02:57:54 GMT Jarielle Catbagan [cf419d2] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/omap3530_gpio.c (deleted) * ports/beagleboneblack/omap3530_iomux.c (deleted) * ports/beagleboneblack/omap3530_iomux.h (deleted) * ports/beagleboneblack/omap3530_lcd.c (deleted) * ports/beagleboneblack/omap3530_lcd.h (deleted) * ports/beagleboneblack/omap3530_mem.h (deleted) * ports/beagleboneblack/omap3530_sdmmc.c (deleted) Removed all omap3530_* peripheral source and header files from BBB ... Sat, 20 Jun 2015 02:57:53 GMT Jarielle Catbagan [11c6677] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) Replaced cpuio.c and cpuio.h in BBB port The former cpuio.* files ... Sat, 20 Jun 2015 02:57:52 GMT Jarielle Catbagan [3f3cc2b] * ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt (modified) Updated header comment in BEAGLEBONEBLACK_boot.ldt Sat, 20 Jun 2015 02:57:51 GMT Jarielle Catbagan [09fa828] * ports/beagleboneblack/rom_reset.S (modified) Removed csb740 OMAP3530 setup in rom_reset.S in BBB port Fri, 19 Jun 2015 21:32:49 GMT Jarielle Catbagan [38e5eef] * ports/beagleboneblack/Makefile (modified) Fixed 'boot' and 'ramtst' prerequisite makefile name in Makefile for ... Fri, 19 Jun 2015 21:32:48 GMT Jarielle Catbagan [9049385] * ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt (moved) * ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt (moved) Renamed linker script templates in BBB port to match BBB target * ... Fri, 19 Jun 2015 21:32:46 GMT Jarielle Catbagan [8b46c00] * ports/beagleboneblack/Makefile (modified) Updated BBB port makefile * Changed PLATFORM and TGTDIR to match ... Fri, 19 Jun 2015 21:32:45 GMT Jarielle Catbagan [d734d80] * ports/beagleboneblack/bashrc (modified) Updated bashrc in BBB port to target BBB Fri, 19 Jun 2015 18:53:54 GMT Jarielle Catbagan [dee5246] * ports/beagleboneblack/.vimrc (added) * ports/beagleboneblack/CSB740_boot.ldt (added) * ports/beagleboneblack/CSB740_ramtst.ldt (added) * ports/beagleboneblack/Makefile (added) * ports/beagleboneblack/_vimrc (added) * ports/beagleboneblack/ad7843.c (added) * ports/beagleboneblack/ad7843.h (added) * ports/beagleboneblack/ads7846.c (added) * ports/beagleboneblack/ads7846.h (added) * ports/beagleboneblack/bashrc (added) * ports/beagleboneblack/bdi2000.cfg (added) * ports/beagleboneblack/config.h (added) * ports/beagleboneblack/cpu.h (added) * ports/beagleboneblack/cpu_gpio.h (added) * ports/beagleboneblack/cpu_i2c.c (added) * ports/beagleboneblack/cpu_i2c.h (added) * ports/beagleboneblack/cpuio.c (added) * ports/beagleboneblack/cpuio.h (added) * ports/beagleboneblack/etherdev.c (added) * ports/beagleboneblack/fbidemo (added) * ports/beagleboneblack/font8x16.h (added) * ports/beagleboneblack/gdbregs.c (added) * ports/beagleboneblack/lcd_lut.h (added) * ports/beagleboneblack/nand740.c (added) * ports/beagleboneblack/omap3530.h (added) * ports/beagleboneblack/omap3530_gpio.c (added) * ports/beagleboneblack/omap3530_iomux.c (added) * ports/beagleboneblack/omap3530_iomux.h (added) * ports/beagleboneblack/omap3530_lcd.c (added) * ports/beagleboneblack/omap3530_lcd.h (added) * ports/beagleboneblack/omap3530_mem.h (added) * ports/beagleboneblack/omap3530_sdmmc.c (added) * ports/beagleboneblack/ram_reset.S (added) * ports/beagleboneblack/regnames.c (added) * ports/beagleboneblack/rom_reset.S (added) * ports/beagleboneblack/target_version.h (added) * ports/beagleboneblack/tfsdev.h (added) * ports/beagleboneblack/xcmddcl.h (added) * ports/beagleboneblack/xcmdtbl.h (added) Duplicated csb740 directory to beagleboneblack directory for BBB port
