# # ChangeLog for ports/beagleboneblack/cpuio.c in umon # # Generated by Trac 1.2.1.dev0 # 03/28/24 09:52:57 Sat, 18 Jul 2015 15:28:03 GMT Ed Sutter [723a2e2] * ports/beagleboneblack/cpuio.c (modified) fix uninitialized variable issue in mpu_pll_init() Thu, 16 Jul 2015 11:26:43 GMT Jarielle Catbagan [273af8f] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/rom_reset.S (modified) BBB: cpuio.c/rom_reset.S: Configure the MPU, Core, DDR, and Per PLLs ... Thu, 16 Jul 2015 11:26:42 GMT Jarielle Catbagan [b9f0b9e] * ports/beagleboneblack/am335x.h (modified) * ports/beagleboneblack/cpuio.c (modified) BBB: am335x.h/cpuio.c: Add CM_PER_GPIO1_CLKCTRL in am335x.h and ... Thu, 16 Jul 2015 11:26:39 GMT Jarielle Catbagan [82f6941] * ports/beagleboneblack/cpuio.c (modified) BBB: cpuio.c: Fixed indentation Tue, 14 Jul 2015 02:11:27 GMT Ed Sutter [b8ffb40] * main/dev/uart16550.c (modified) * ports/beagleboneblack/am335x.h (modified) * ports/beagleboneblack/config.h (modified) * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) * ports/beagleboneblack/xcmdtbl.h (modified) BBB: Changes to support runtime blinking LED. Fri, 03 Jul 2015 17:54:52 GMT Jarielle Catbagan [40b5966] * ports/beagleboneblack/cpuio.c (modified) BBB: cpuio.c: Set devInit() to return 0 by default devInit() is not ... Fri, 03 Jul 2015 17:54:50 GMT Jarielle Catbagan [d77ed25] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) BBB: cpuio.*: Add UART0 initialization and set DEFAULT_BAUD_RATE to ... Fri, 03 Jul 2015 17:54:49 GMT Jarielle Catbagan [a5f94c8] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/rom_reset.S (modified) BBB: Migrate custom exception handler mapping from rom_reset.S to ... Mon, 29 Jun 2015 22:21:19 GMT Ed Sutter [d6c7226] * ports/beagleboneblack/cpuio.c (modified) cleanup uninitialized variable warning Sat, 20 Jun 2015 02:57:53 GMT Jarielle Catbagan [11c6677] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) Replaced cpuio.c and cpuio.h in BBB port The former cpuio.* files ... Fri, 19 Jun 2015 18:53:54 GMT Jarielle Catbagan [dee5246] * ports/beagleboneblack/.vimrc (added) * ports/beagleboneblack/CSB740_boot.ldt (added) * ports/beagleboneblack/CSB740_ramtst.ldt (added) * ports/beagleboneblack/Makefile (added) * ports/beagleboneblack/_vimrc (added) * ports/beagleboneblack/ad7843.c (added) * ports/beagleboneblack/ad7843.h (added) * ports/beagleboneblack/ads7846.c (added) * ports/beagleboneblack/ads7846.h (added) * ports/beagleboneblack/bashrc (added) * ports/beagleboneblack/bdi2000.cfg (added) * ports/beagleboneblack/config.h (added) * ports/beagleboneblack/cpu.h (added) * ports/beagleboneblack/cpu_gpio.h (added) * ports/beagleboneblack/cpu_i2c.c (added) * ports/beagleboneblack/cpu_i2c.h (added) * ports/beagleboneblack/cpuio.c (added) * ports/beagleboneblack/cpuio.h (added) * ports/beagleboneblack/etherdev.c (added) * ports/beagleboneblack/fbidemo (added) * ports/beagleboneblack/font8x16.h (added) * ports/beagleboneblack/gdbregs.c (added) * ports/beagleboneblack/lcd_lut.h (added) * ports/beagleboneblack/nand740.c (added) * ports/beagleboneblack/omap3530.h (added) * ports/beagleboneblack/omap3530_gpio.c (added) * ports/beagleboneblack/omap3530_iomux.c (added) * ports/beagleboneblack/omap3530_iomux.h (added) * ports/beagleboneblack/omap3530_lcd.c (added) * ports/beagleboneblack/omap3530_lcd.h (added) * ports/beagleboneblack/omap3530_mem.h (added) * ports/beagleboneblack/omap3530_sdmmc.c (added) * ports/beagleboneblack/ram_reset.S (added) * ports/beagleboneblack/regnames.c (added) * ports/beagleboneblack/rom_reset.S (added) * ports/beagleboneblack/target_version.h (added) * ports/beagleboneblack/tfsdev.h (added) * ports/beagleboneblack/xcmddcl.h (added) * ports/beagleboneblack/xcmdtbl.h (added) Duplicated csb740 directory to beagleboneblack directory for BBB port
