# # ChangeLog for / in umon # # Generated by Trac 1.2.1.dev0 # 04/25/24 13:52:08 Mon, 29 Jun 2015 22:22:03 GMT Ed Sutter [2236db2] * ports/beagleboneblack/config.h (modified) remove APPRAMBASE_OVERRIDE and include DM/PM commands Mon, 29 Jun 2015 22:21:19 GMT Ed Sutter [d6c7226] * ports/beagleboneblack/cpuio.c (modified) cleanup uninitialized variable warning Mon, 29 Jun 2015 22:20:31 GMT Ed Sutter [eb2caa2] * main/common/misccmds.c (modified) cleanup monargs warning Sat, 20 Jun 2015 14:52:45 GMT Jarielle Catbagan [d468669] * ports/beagleboneblack/rom_reset.S (modified) BBB/AM335x: Store addresses of custom exception handlers in the ... Sat, 20 Jun 2015 05:32:16 GMT Jarielle Catbagan [d47f458] * ports/beagleboneblack/Makefile (modified) Map base Umon image in internal SRAM of AM335x/BBB The internal ... Sat, 20 Jun 2015 05:31:47 GMT Jarielle Catbagan [dfb586e] * ports/beagleboneblack/config.h (modified) Updated BBB CONSOLE_UART_BASE in config.h CONSOLE_UART_BASE in ... Sat, 20 Jun 2015 05:30:54 GMT Jarielle Catbagan [9318819] * ports/beagleboneblack/Makefile (modified) In BBB Makefile, the value of -mcpu in CUSTOM_CFLAGS has been changed ... Sat, 20 Jun 2015 02:58:03 GMT Jarielle Catbagan [4d79fb9] * ports/beagleboneblack/bdi2000.cfg (deleted) Removed bdi2000.cfg in BBB port as it does not target the AM335x Sat, 20 Jun 2015 02:58:02 GMT Jarielle Catbagan [5a9a72f] * ports/beagleboneblack/cpu_gpio.h (deleted) * ports/beagleboneblack/cpu_i2c.c (deleted) * ports/beagleboneblack/cpu_i2c.h (deleted) Removed cpu_gpio.h, cpu_i2c.c, and cpu_i2c.h Sat, 20 Jun 2015 02:58:01 GMT Jarielle Catbagan [35608bb] * ports/beagleboneblack/am335x.h (added) * ports/beagleboneblack/omap3530.h (deleted) * ports/beagleboneblack/ram_reset.S (modified) * ports/beagleboneblack/rom_reset.S (modified) Replaced omap3530.h with am335x.h in BBB port am335x.h contains ... Sat, 20 Jun 2015 02:58:00 GMT Jarielle Catbagan [4df7813] * ports/beagleboneblack/ads7846.c (deleted) * ports/beagleboneblack/ads7846.h (deleted) Removed ads7846.* from BBB port The ADS7846 Interface routines are ... Sat, 20 Jun 2015 02:57:59 GMT Jarielle Catbagan [470b252] * ports/beagleboneblack/cpu.h (modified) Replaced cpu.h with the template cpu.h Sat, 20 Jun 2015 02:57:58 GMT Jarielle Catbagan [ce2a00f] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/nand740.c (deleted) Removed nand740.c from BBB port nand740.c is for the NAND device ... Sat, 20 Jun 2015 02:57:57 GMT Jarielle Catbagan [c0d0e6a] * ports/beagleboneblack/xcmddcl.h (modified) * ports/beagleboneblack/xcmdtbl.h (modified) Removed "ads" command from being included in the common cmdtbl.c from ... Sat, 20 Jun 2015 02:57:56 GMT Jarielle Catbagan [d9ca895] * ports/beagleboneblack/config.h (modified) Updated BBB config.h to target BBB * Updated header comment to ... Sat, 20 Jun 2015 02:57:55 GMT Jarielle Catbagan [6504fc5] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/ad7843.c (deleted) * ports/beagleboneblack/ad7843.h (deleted) Removed ad7843.* from BBB port The AD7843 Interface routines are ... Sat, 20 Jun 2015 02:57:54 GMT Jarielle Catbagan [cf419d2] * ports/beagleboneblack/Makefile (modified) * ports/beagleboneblack/omap3530_gpio.c (deleted) * ports/beagleboneblack/omap3530_iomux.c (deleted) * ports/beagleboneblack/omap3530_iomux.h (deleted) * ports/beagleboneblack/omap3530_lcd.c (deleted) * ports/beagleboneblack/omap3530_lcd.h (deleted) * ports/beagleboneblack/omap3530_mem.h (deleted) * ports/beagleboneblack/omap3530_sdmmc.c (deleted) Removed all omap3530_* peripheral source and header files from BBB ... Sat, 20 Jun 2015 02:57:53 GMT Jarielle Catbagan [11c6677] * ports/beagleboneblack/cpuio.c (modified) * ports/beagleboneblack/cpuio.h (modified) Replaced cpuio.c and cpuio.h in BBB port The former cpuio.* files ... Sat, 20 Jun 2015 02:57:52 GMT Jarielle Catbagan [3f3cc2b] * ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt (modified) Updated header comment in BEAGLEBONEBLACK_boot.ldt Sat, 20 Jun 2015 02:57:51 GMT Jarielle Catbagan [09fa828] * ports/beagleboneblack/rom_reset.S (modified) Removed csb740 OMAP3530 setup in rom_reset.S in BBB port Fri, 19 Jun 2015 21:32:49 GMT Jarielle Catbagan [38e5eef] * ports/beagleboneblack/Makefile (modified) Fixed 'boot' and 'ramtst' prerequisite makefile name in Makefile for ... Fri, 19 Jun 2015 21:32:48 GMT Jarielle Catbagan [9049385] * ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt (moved) * ports/beagleboneblack/BEAGLEBONEBLACK_ramtst.ldt (moved) Renamed linker script templates in BBB port to match BBB target * ... Fri, 19 Jun 2015 21:32:47 GMT Jarielle Catbagan [d871a74] * main/make/common.make (modified) Fixed BASE variable in common.make The BASE variable was changed ... Fri, 19 Jun 2015 21:32:46 GMT Jarielle Catbagan [8b46c00] * ports/beagleboneblack/Makefile (modified) Updated BBB port makefile * Changed PLATFORM and TGTDIR to match ... Fri, 19 Jun 2015 21:32:45 GMT Jarielle Catbagan [d734d80] * ports/beagleboneblack/bashrc (modified) Updated bashrc in BBB port to target BBB Fri, 19 Jun 2015 18:53:54 GMT Jarielle Catbagan [dee5246] * ports/beagleboneblack/.vimrc (added) * ports/beagleboneblack/CSB740_boot.ldt (added) * ports/beagleboneblack/CSB740_ramtst.ldt (added) * ports/beagleboneblack/Makefile (added) * ports/beagleboneblack/_vimrc (added) * ports/beagleboneblack/ad7843.c (added) * ports/beagleboneblack/ad7843.h (added) * ports/beagleboneblack/ads7846.c (added) * ports/beagleboneblack/ads7846.h (added) * ports/beagleboneblack/bashrc (added) * ports/beagleboneblack/bdi2000.cfg (added) * ports/beagleboneblack/config.h (added) * ports/beagleboneblack/cpu.h (added) * ports/beagleboneblack/cpu_gpio.h (added) * ports/beagleboneblack/cpu_i2c.c (added) * ports/beagleboneblack/cpu_i2c.h (added) * ports/beagleboneblack/cpuio.c (added) * ports/beagleboneblack/cpuio.h (added) * ports/beagleboneblack/etherdev.c (added) * ports/beagleboneblack/fbidemo (added) * ports/beagleboneblack/font8x16.h (added) * ports/beagleboneblack/gdbregs.c (added) * ports/beagleboneblack/lcd_lut.h (added) * ports/beagleboneblack/nand740.c (added) * ports/beagleboneblack/omap3530.h (added) * ports/beagleboneblack/omap3530_gpio.c (added) * ports/beagleboneblack/omap3530_iomux.c (added) * ports/beagleboneblack/omap3530_iomux.h (added) * ports/beagleboneblack/omap3530_lcd.c (added) * ports/beagleboneblack/omap3530_lcd.h (added) * ports/beagleboneblack/omap3530_mem.h (added) * ports/beagleboneblack/omap3530_sdmmc.c (added) * ports/beagleboneblack/ram_reset.S (added) * ports/beagleboneblack/regnames.c (added) * ports/beagleboneblack/rom_reset.S (added) * ports/beagleboneblack/target_version.h (added) * ports/beagleboneblack/tfsdev.h (added) * ports/beagleboneblack/xcmddcl.h (added) * ports/beagleboneblack/xcmdtbl.h (added) Duplicated csb740 directory to beagleboneblack directory for BBB port Fri, 19 Jun 2015 21:32:43 GMT Jarielle Catbagan [b987a75] * apps/common/timer.h (modified) * main/common/dns.c (modified) * main/common/env.c (modified) * main/common/fbi.c (modified) * main/common/fbi.h (modified) * main/common/flash.c (modified) * main/common/flash.h (modified) * main/common/font.c (modified) * main/common/font.h (modified) * main/common/if.c (modified) * main/common/nand.c (modified) * main/common/tfsclean1.c (modified) * main/common/time.h (modified) * main/common/timestuff.c (modified) * main/common/tsi.c (modified) * main/glib/getglib (modified) * main/glib/inrange.c (modified) * main/glib/pollconsole.c (modified) * main/glib/prascii.c (modified) * main/glib/printmem.c (modified) * main/glib/smemcpy.c (modified) * main/glib/smemset.c (modified) * main/glib/strtolower.c (modified) * main/glib/swap.c (modified) * main/glib/ticktock.c (modified) * main/make/common.make (modified) * ports/csb740/CSB740_boot.ldt (modified) * ports/csb740/CSB740_ramtst.ldt (modified) * ports/csb740/Makefile (modified) * ports/csb740/_vimrc (modified) * ports/csb740/ad7843.c (modified) * ports/csb740/ad7843.h (modified) * ports/csb740/ads7846.c (modified) * ports/csb740/ads7846.h (modified) * ports/csb740/bashrc (modified) * ports/csb740/bdi2000.cfg (modified) * ports/csb740/config.h (modified) * ports/csb740/cpu.h (modified) * ports/csb740/cpu_gpio.h (modified) * ports/csb740/cpu_i2c.c (modified) * ports/csb740/cpu_i2c.h (modified) * ports/csb740/cpuio.c (modified) * ports/csb740/cpuio.h (modified) * ports/csb740/etherdev.c (modified) * ports/csb740/fbidemo (modified) * ports/csb740/font8x16.h (modified) * ports/csb740/gdbregs.c (modified) * ports/csb740/lcd_lut.h (modified) * ports/csb740/omap3530.h (modified) * ports/csb740/omap3530_gpio.c (modified) * ports/csb740/omap3530_iomux.c (modified) * ports/csb740/omap3530_iomux.h (modified) * ports/csb740/omap3530_lcd.c (modified) * ports/csb740/omap3530_lcd.h (modified) * ports/csb740/omap3530_mem.h (modified) * ports/csb740/omap3530_sdmmc.c (modified) * ports/csb740/ram_reset.S (modified) * ports/csb740/regnames.c (modified) * ports/csb740/rom_reset.S (modified) * ports/csb740/target_version.h (modified) * ports/csb740/tfsdev.h (modified) * ports/csb740/xcmddcl.h (modified) * ports/csb740/xcmdtbl.h (modified) * ports/template/flashtest.scr (modified) Removed execution mode file attribute from all ASCII text files Thu, 16 Apr 2015 19:29:24 GMT Amar Takhar [24d5973] * apps/demo/Makefile (moved) * ports/csb740/Makefile (moved) * ports/template/Makefile (moved) Rename makefile -> Makefile. Thu, 16 Apr 2015 19:26:21 GMT Amar Takhar [87db514] * LICENSE (added) * NOTICE (added) * README (added) * apps/common/cli.h (added) * apps/common/crt0_arm.S (added) * apps/common/crt0_bfin.S (added) * apps/common/crt0_cf.S (added) * apps/common/crt0_mb.S (added) * apps/common/crt0_mips.s (added) * apps/common/crt0_ppc.S (added) * apps/common/cygprof.c (added) * apps/common/monlib.c (added) * apps/common/monlib.h (added) * apps/common/tfs.h (added) * apps/common/timer.h (added) * apps/demo/README (added) * apps/demo/bashrc (added) * apps/demo/cfg.h (added) * apps/demo/main.c (added) * apps/demo/makefile (added) * apps/demo/strace.c (added) * main/common/alttfsdevtbl.S (added) * main/common/aout.h (added) * main/common/arp.c (added) * main/common/bits.h (added) * main/common/bmem.h (added) * main/common/boardinfo.c (added) * main/common/boardinfo.h (added) * main/common/cache.c (added) * main/common/cache.h (added) * main/common/cast.c (added) * main/common/cf.c (added) * main/common/cf.h (added) * main/common/chario.c (added) * main/common/cli.h (added) * main/common/cmdtbl.c (added) * main/common/coff.h (added) * main/common/cstart.c (added) * main/common/dallasdate.c (added) * main/common/date.c (added) * main/common/date.h (added) * main/common/devices.c (added) * main/common/devices.h (added) * main/common/dhcp_00.c (added) * main/common/dhcp_01.c (added) * main/common/dhcp_02.c (added) * main/common/dhcp_03.c (added) * main/common/dhcpboot.c (added) * main/common/dns.c (added) * main/common/docmd.c (added) * main/common/edit.c (added) * main/common/elf.h (added) * main/common/endian.h (added) * main/common/env.c (added) * main/common/ether.h (added) * main/common/etheraddr.S (added) * main/common/ethernet.c (added) * main/common/fbi.c (added) * main/common/fbi.h (added) * main/common/flash.c (added) * main/common/flash.h (added) * main/common/flashram.c (added) * main/common/font.c (added) * main/common/font.h (added) * main/common/gdb.c (added) * main/common/genlib.h (added) * main/common/i2c.c (added) * main/common/i2c.h (added) * main/common/icmp.c (added) * main/common/if.c (added) * main/common/igmp.c (added) * main/common/inc_check.h (added) * main/common/jffs2.c (added) * main/common/ledit_vi.c (added) * main/common/ledit_vt100.c (added) * main/common/malloc.c (added) * main/common/mallocdebug.h (added) * main/common/memcmds.c (added) * main/common/memtrace.c (added) * main/common/misc.c (added) * main/common/misccmds.c (added) * main/common/monbuilt.c (added) * main/common/moncom.c (added) * main/common/moncomptr.S (added) * main/common/monflags.h (added) * main/common/monlib.c (added) * main/common/monlib.h (added) * main/common/monprof.c (added) * main/common/monprof.h (added) * main/common/mprintf.c (added) * main/common/msbin.h (added) * main/common/nand.c (added) * main/common/nand.h (added) * main/common/password.c (added) * main/common/pci.c (added) * main/common/pci.h (added) * main/common/redirect.c (added) * main/common/reg_cache.c (added) * main/common/sbrk.c (added) * main/common/sd.c (added) * main/common/sd.h (added) * main/common/spif.c (added) * main/common/spif.h (added) * main/common/start.c (added) * main/common/stddefs.h (added) * main/common/struct.c (added) * main/common/symtbl.c (added) * main/common/syslog.c (added) * main/common/tcpstuff.c (added) * main/common/term.c (added) * main/common/term.h (added) * main/common/tfs.c (added) * main/common/tfs.h (added) * main/common/tfsapi.c (added) * main/common/tfsclean1.c (added) * main/common/tfsclean2.c (added) * main/common/tfsclean3.c (added) * main/common/tfscli.c (added) * main/common/tfsloader.c (added) * main/common/tfslog.c (added) * main/common/tfsprivate.h (added) * main/common/tftp.c (added) * main/common/time.h (added) * main/common/timer.h (added) * main/common/timestuff.c (added) * main/common/tsi.c (added) * main/common/tsi.h (added) * main/common/umongpio.h (added) * main/common/version.h (added) * main/common/warmstart.h (added) * main/common/xmodem.c (added) * main/cpu/arm/arm.h (added) * main/cpu/arm/cache_arm.c (added) * main/cpu/arm/except_arm.c (added) * main/cpu/arm/gdbregs_arm.c (added) * main/cpu/arm/ldatags.c (added) * main/cpu/arm/misc_arm.c (added) * main/cpu/arm/misc_arm.h (added) * main/cpu/arm/regs_arm.c (added) * main/cpu/arm/strace_arm.c (added) * main/cpu/arm/vectors_arm.S (added) * main/cpu/template/except_template.c (added) * main/cpu/template/strace_template.c (added) * main/dev/bp (added) * main/dev/fb_draw.c (added) * main/dev/fb_draw.h (added) * main/dev/fb_fonts.h (added) * main/dev/smsc911x.c (added) * main/dev/smsc911x.h (added) * main/dev/uart16550.c (added) * main/dev/uart16550.h (added) * main/dev/vga_lookup.h (added) * main/flash/README (added) * main/flash/devices/s29gl512n_16x1.c (added) * main/flash/devices/s29gl512n_16x1.h (added) * main/glib/abs.c (added) * main/glib/asctime.c (added) * main/glib/atoi.c (added) * main/glib/crc16.c (added) * main/glib/crc32.c (added) * main/glib/div.c (added) * main/glib/getglib (added) * main/glib/getopt.c (added) * main/glib/inrange.c (added) * main/glib/ldiv.c (added) * main/glib/list (added) * main/glib/memccpy.c (added) * main/glib/memchr.c (added) * main/glib/memcmp.c (added) * main/glib/memcpy.c (added) * main/glib/memset.c (added) * main/glib/pollconsole.c (added) * main/glib/prascii.c (added) * main/glib/printmem.c (added) * main/glib/smemcpy.c (added) * main/glib/smemset.c (added) * main/glib/strcasecmp.c (added) * main/glib/strcat.c (added) * main/glib/strchr.c (added) * main/glib/strcmp.c (added) * main/glib/strcpy.c (added) * main/glib/strlen.c (added) * main/glib/strncat.c (added) * main/glib/strncmp.c (added) * main/glib/strncpy.c (added) * main/glib/strnlen.c (added) * main/glib/strpbrk.c (added) * main/glib/strrchr.c (added) * main/glib/strstr.c (added) * main/glib/strtok.c (added) * main/glib/strtol.c (added) * main/glib/strtolower.c (added) * main/glib/strtoul.c (added) * main/glib/swap.c (added) * main/glib/ticktock.c (added) * main/make/common.make (added) * main/make/defaults.make (added) * main/make/objects.make (added) * main/make/rules.make (added) * main/zlib/README (added) * main/zlib/adler32.c (added) * main/zlib/adler_mail_1.txt (added) * main/zlib/adler_mail_2.txt (added) * main/zlib/deflate.h (added) * main/zlib/gzio.c (added) * main/zlib/infblock.c (added) * main/zlib/infblock.h (added) * main/zlib/infcodes.c (added) * main/zlib/infcodes.h (added) * main/zlib/inffast.c (added) * main/zlib/inffast.h (added) * main/zlib/inffixed.h (added) * main/zlib/inflate.c (added) * main/zlib/inftrees.c (added) * main/zlib/inftrees.h (added) * main/zlib/infutil.c (added) * main/zlib/infutil.h (added) * main/zlib/trees.c (added) * main/zlib/trees.h (added) * main/zlib/uncompr.c (added) * main/zlib/zconf.h (added) * main/zlib/zcrc32.c (added) * main/zlib/zlib.h (added) * main/zlib/zutil.c (added) * main/zlib/zutil.h (added) * ports/csb740/.vimrc (added) * ports/csb740/CSB740_boot.ldt (added) * ports/csb740/CSB740_ramtst.ldt (added) * ports/csb740/_vimrc (added) * ports/csb740/ad7843.c (added) * ports/csb740/ad7843.h (added) * ports/csb740/ads7846.c (added) * ports/csb740/ads7846.h (added) * ports/csb740/bashrc (added) * ports/csb740/bdi2000.cfg (added) * ports/csb740/config.h (added) * ports/csb740/cpu.h (added) * ports/csb740/cpu_gpio.h (added) * ports/csb740/cpu_i2c.c (added) * ports/csb740/cpu_i2c.h (added) * ports/csb740/cpuio.c (added) * ports/csb740/cpuio.h (added) * ports/csb740/etherdev.c (added) * ports/csb740/fbidemo (added) * ports/csb740/font8x16.h (added) * ports/csb740/gdbregs.c (added) * ports/csb740/lcd_lut.h (added) * ports/csb740/makefile (added) * ports/csb740/nand740.c (added) * ports/csb740/omap3530.h (added) * ports/csb740/omap3530_gpio.c (added) * ports/csb740/omap3530_iomux.c (added) * ports/csb740/omap3530_iomux.h (added) * ports/csb740/omap3530_lcd.c (added) * ports/csb740/omap3530_lcd.h (added) * ports/csb740/omap3530_mem.h (added) * ports/csb740/omap3530_sdmmc.c (added) * ports/csb740/ram_reset.S (added) * ports/csb740/regnames.c (added) * ports/csb740/rom_reset.S (added) * ports/csb740/target_version.h (added) * ports/csb740/tfsdev.h (added) * ports/csb740/xcmddcl.h (added) * ports/csb740/xcmdtbl.h (added) * ports/template/OLD_TO_NEW.txt (added) * ports/template/README.txt (added) * ports/template/TEMPLATE_boot.ldt (added) * ports/template/TEMPLATE_ramtst.ldt (added) * ports/template/_vimrc (added) * ports/template/bashrc (added) * ports/template/config.h (added) * ports/template/cpu.h (added) * ports/template/cpuio.c (added) * ports/template/cpuio.h (added) * ports/template/etherdev.c (added) * ports/template/except_template.c (added) * ports/template/flashtest.scr (added) * ports/template/makefile (added) * ports/template/regnames.c (added) * ports/template/reset.S (added) * ports/template/strace_template.c (added) * ports/template/target_version.h (added) * ports/template/tfsdev.h (added) * ports/template/xcmddcl.h (added) * ports/template/xcmdtbl.h (added) Initial commit of the umon repository. Prior to this three changes ...
