Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/testsuites
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @f7d2795   11/24/14 19:57:21 Joel Sherrill testsuites/.../tmacros.h: Add parentheses to fix warning 4.115
(edit) @cceb19f4   11/21/14 10:01:34 lohathe smp: Fix scheduler helping protocol New test case for … 4.115
(edit) @6570876   11/23/14 16:40:14 Joel Sherrill termio05: Remove unreferenced files The functionality was … 4.115
(edit) @11925eef   11/21/14 07:49:57 Sebastian Huber Delete or rename MIN/MAX macros and defines Include <sys/param.h> if … 4.115
(edit) @db44590c   11/11/14 16:21:02 Jennifer Averett smpschedaffinity05: Change semaphore attributes. Change semaphore … 4.115
(edit) @1960dcb9   11/12/14 14:42:13 Jennifer Averett smpschedaffinity04: Change semaphore attributes. Change semaphore … 4.115
(edit) @bc95f816   11/12/14 14:42:48 Jennifer Averett smpschedaffinity02: Change semaphore attributes. Change semaphore … 4.115
(edit) @163519a0   11/19/14 19:57:37 Joel Sherrill libtests/malloctest/init.c: Fix warning posix_memalign() is … 4.115
(edit) @a634feb   11/20/14 08:15:19 Sebastian Huber dl01,dl02: Avoid non-runnable $(EXEEXT) files 4.115
(edit) @e02d5dd9   11/17/14 12:35:58 Sebastian Huber Ensure security of default user environment 4.115
(edit) @fa028bb   11/17/14 10:55:27 Sebastian Huber shell: Do chroot() after successful login 4.115
(edit) @065d72ce   11/17/14 09:19:00 Sebastian Huber shell: Get supplementary group IDs in login check 4.115
(edit) @b8bd90f6   11/17/14 08:01:53 Sebastian Huber Add supplementary groups to user environment 4.115
(edit) @0b3fcf5   11/18/14 09:42:45 Sebastian Huber samples/fileio: Use unlimited objects 4.115
(edit) @ab085c9   11/18/14 09:42:34 Sebastian Huber samples/fileio: Fix warning 4.115
(edit) @ffa71f1   11/17/14 06:53:01 Sebastian Huber libcsupport: Implement getgroups() 4.115
(edit) @395e5d4   11/14/14 14:33:57 Sebastian Huber libcsupport: Use POSIX key for getgrent() 4.115
(edit) @acf9a8d   11/14/14 13:31:54 Sebastian Huber shell: Use crypt_r() in rtems_shell_login_check() Use '*" to disable … 4.115
(edit) @002f351   11/14/14 13:30:36 Sebastian Huber libcsupport: Minimal /etc/passwd and /etc/group Create a minimal … 4.115
(edit) @6935428   11/14/14 10:30:50 Sebastian Huber libcsupport: Avoid TOCTOU and format errors 4.115
(edit) @4466321   11/13/14 14:13:24 Sebastian Huber Add crypt_r(), etc. Add crypt_add_format(), crypt_r(), crypt_md5_r(), … 4.115
(edit) @1bcd0378   11/13/14 12:18:24 Sebastian Huber Add SHA256 and SHA512 support 4.115
(edit) @0510cfd8   11/11/14 11:41:58 Sebastian Huber Add NXP PCA9548A 8-channel switch I2C driver 4.115
(edit) @67ac69fc   11/07/14 12:50:01 Sebastian Huber Add NXP PCA9535 16-bit GPIO I2C driver 4.115
(edit) @cce46780   11/07/14 12:49:29 Sebastian Huber Add generic EEPROM I2C device driver 4.115
(edit) @41c5f1b7   11/07/14 12:47:39 Sebastian Huber Add I2C driver framework This I2C driver framework has some major … 4.115
(edit) @3eade710   11/20/14 07:52:50 Sebastian Huber libtests/top: End test after some time if no input 4.115
(edit) @f98abbe   11/06/14 02:08:48 Chris Johns libdl: Disable building libdl for the NIOS2. No relocation support. … 4.115
(edit) @540b7b41   11/04/14 05:31:50 Chris Johns libtests: Add libdl test dl02. Loads 2 interdependent ELF object files. 4.115
(edit) @d52c9e4d   11/04/14 05:30:08 Chris Johns libtests: Update dl01 documentation. 4.115
(edit) @c58f90b   11/03/14 00:54:55 Joel Sherrill dl01/dl-load.c: Add missing const 4.115
(edit) @ae5fe7e6   10/27/14 01:09:41 Chris Johns cpukit: Add libdl with the Runtime Loader (RTL) code. This is a merge … 4.115
(edit) @410bcdfe   09/29/14 19:31:18 Jennifer Averett top: Add new test. 4.115
(edit) @254b7db0   09/08/14 14:47:13 Jennifer Averett capture01: Remove capture task tracking. This involved adding a new … 4.115
(edit) @d412e2f   10/24/14 07:18:38 Sebastian Huber smptests/smpfatal03: Wait for end of test msg 4.115
(edit) @092b8c5   10/24/14 05:21:51 Sebastian Huber tests/smptests: Normal use of test extension 4.115
(edit) @17889b2   10/23/14 15:15:47 Sebastian Huber tests/smptests: Use barriers in smpfatal0{12} Call the test extension … 4.115
(edit) @3e739ae   10/23/14 07:42:18 Sebastian Huber testsuites: Move include for C++ compatibility 4.115
(edit) @66c1ef9   10/17/14 12:46:13 Sebastian Huber Revert "fstests/mdosfs_fstime: Remove test" This reverts commit … 4.115
(edit) @43633ae   10/14/14 10:12:32 Sebastian Huber testsuites: Avoid clock driver 4.115
(edit) @945f31b9   10/13/14 16:13:11 Joel Sherrill nsecs/init.c: Use long to avoid overflow on 16-bit targets 4.115
(edit) @a38ced2   10/10/14 07:09:19 Sebastian Huber score: Rework global construction Ensure that the global construction … 4.115
(edit) @78a38fa2   10/08/14 22:38:12 Joel Sherrill Eliminate use of /*PAGE and clean up formatting 4.115
(edit) @eb7f306d   10/07/14 22:43:35 Joel Sherrill samples/base_sp: Fix printf() warning 4.115
(edit) @51a95ff9   10/07/14 22:43:18 Joel Sherrill samples/unlimited: Fix printf() warning and clean up 4.115
(edit) @22cd282   10/08/14 09:24:36 Sebastian Huber IMFS: Avoid NULL pointer access Avoid NULL pointer access in … 4.115
(edit) @b9f95225   10/08/14 08:31:36 Sebastian Huber posix: Add auto initializaton for rwlock 4.115
(edit) @7fd5e89   10/07/14 14:28:04 Sebastian Huber termios: Partially hide rtems_termios_tty Move interrupt lock to … 4.115
(edit) @a830cb8   10/07/14 14:27:51 Sebastian Huber termios: Separate flow control from normal handler 4.115
(edit) @805360b   09/23/14 12:20:35 Sebastian Huber pppd: Fix warnings 4.115
(edit) @6f1e1b3   09/19/14 12:18:00 Sebastian Huber sptests/spintrcritical22: New test 4.115
(edit) @8f0a2c9   09/17/14 08:28:13 Sebastian Huber smptests/smpload01: Report profiling only once Rely on test extension … 4.115
(edit) @8fbe2e6   09/04/14 13:59:49 Joel Sherrill Use correct prototype of benchmark_timer_read() This change starts … 4.115
(edit) @7f8a978   09/16/14 13:43:15 Sebastian Huber sptests/sp07: Minimize thread dispatch latency Do not use sprintf() … 4.115
(edit) @6e1206a   09/11/14 15:55:34 cederman smptests/smpcache01: Remove invalidation of data cache lines from test … 4.115
(edit) @f9eca790   09/12/14 14:04:40 Sebastian Huber sptests/spintrcritical_support: Optimize busy loop 4.115
(edit) @73b5d8bf   09/12/14 14:04:01 Sebastian Huber sptests/spintrcritical10: Avoid undefined memory 4.115
(edit) @f3508c44   09/11/14 05:33:16 Sebastian Huber tmtests/tmcontext01: Improve cache dirty function Increment by cache … 4.115
(edit) @e09f8b08   09/10/14 12:46:03 Sebastian Huber sptests/spfatal07: Fix end of test message 4.115
(edit) @4984ee4   09/09/14 15:13:51 Sebastian Huber sptests/sp39: Convert to sptests/spintrcritical21 Use interrupt … 4.115
(edit) @b5f9ad2   09/09/14 14:49:20 Sebastian Huber psxtests/psxonce01: Use test extension 4.115
(edit) @8028089   09/08/14 13:18:07 Sebastian Huber tests: Rework interrupt critical tests This avoids test durations of … 4.115
(edit) @6821a629   09/08/14 08:19:42 Sebastian Huber Add -std=gnu++11 to CXXFLAGS if SMP is enabled This is necessary to … 4.115
(edit) @8d30713d   09/05/14 11:33:57 Sebastian Huber tmtests/tmcontext01: Improve cache dirty function 4.115
(edit) @07b4594   09/05/14 07:27:41 Sebastian Huber sptests/spcontext01: Fix warning 4.115
(edit) @b2356837   09/05/14 06:24:52 Sebastian Huber tmtests/tmcontext01: Plot a legend 4.115
(edit) @a864016f   09/03/14 15:21:21 Joel Sherrill spcpuset01: Use %zd for size_t to eliminate warning 4.115
(edit) @de549c3   09/03/14 15:16:43 Joel Sherrill Misc psxtmtests: Use uint32_t not long for end_time to match printf() … 4.115
(edit) @9aa6ddf   09/03/14 15:07:28 Joel Sherrill spfreechain01/init.c: Use %zd for size_t to eliminate warning 4.115
(edit) @e1462e1   09/02/14 17:30:25 Joel Sherrill sp19: Eliminate warnings 4.115
(edit) @be4992b1   09/02/14 23:00:44 Joel Sherrill raspberrypi: Use shared bspreset.c 4.115
(edit) @8ae6f26   09/01/14 15:16:53 Sebastian Huber samples/iostream: Produce proper begin/end message 4.115
(edit) @5689d72   09/01/14 14:12:42 Sebastian Huber smptests/smplock01: Update screen file 4.115
(edit) @5cb5342   09/01/14 11:28:30 Sebastian Huber libtests/capture01: Fix test name 4.115
(edit) @979d95e   09/01/14 08:08:12 Sebastian Huber libtests/capture01: Force error if SMP enabled This prevents infinite … 4.115
(edit) @4030ccc   09/01/14 09:01:04 Sebastian Huber tests: Add documentation 4.115
(edit) @c147a139   09/01/14 06:45:23 Sebastian Huber smptests/smpfatal08: Fix link error 4.115
(edit) @96ec8ee8   08/22/14 15:09:36 Sebastian Huber rtems: Add more clock tick functions Add rtems_clock_tick_later(), … 4.115
(edit) @23b14f87   08/22/14 20:20:16 Hesham Almatary sptests/spcache01: Make inline assembly conditional to account for … 4.115
(edit) @9a9ab85   07/03/14 14:42:24 cederman smptests/smpcache01: Test the SMP cache manager Invokes SMP cache … 4.115
(edit) @bba3507   08/19/14 15:43:36 Sebastian Huber score: PR2179: Fix initially locked PI mutex 4.115
(edit) @0b9fe3ec   08/07/14 17:41:25 Sebastian Huber sptests/sprbtree01: Add random ops test case 4.115
(edit) @993f5ac   07/23/14 11:03:54 Sebastian Huber rbtree: Simplify insert and extract Simplify _RBTree_Insert() and … 4.115
(edit) @4752550f   07/23/14 11:19:09 Sebastian Huber rbtree: Simplify _RBTree_Rotate() Add and use _RBTree_Direction(). 4.115
(edit) @d472d21   08/05/14 12:07:07 Sebastian Huber sptests/sprbtree01: Check tree layout 4.115
(edit) @888edf6   08/05/14 11:52:45 Sebastian Huber sptests/sprbtree01: Reduce stack usage 4.115
(edit) @60fe374   08/03/14 11:02:58 Sebastian Huber rbtree: Add and use RBTree_Compare_result 4.115
(edit) @40dcafa   08/02/14 14:22:31 Sebastian Huber Add and use RTEMS_CONTAINER_OF() 4.115
(edit) @b767683a   07/22/14 20:49:09 Sebastian Huber rbtree: Rename find header in find control Simplify … 4.115
(edit) @6e93c836   07/22/14 17:42:54 Sebastian Huber rbtree: Simplify off-tree handling Only use the parent pointer, since … 4.115
(edit) @639117f   07/22/14 12:50:07 Sebastian Huber rbtree: Update maximum node in LIFO order The test sptests/sp35 … 4.115
(edit) @875fff0a   07/23/14 20:35:35 Joel Sherrill Add _TOD_Adjust to SCORE TOD Handler. This lays the proper structure … 4.115
(edit) @8abbbdde   07/21/14 16:29:00 Sebastian Huber rbtree: Do not set node off-tree in extract 4.115
(edit) @d7a94693   07/21/14 16:16:47 Sebastian Huber rbtree: Remove superfluous NULL pointer checks 4.115
(edit) @64939bc   07/12/14 19:22:22 Sebastian Huber rbtree: Reduce RBTree_Control size Remove compare function and is … 4.115
(edit) @9ba76ed8   07/07/14 22:42:28 Joel Sherrill sp59: Fix typos 4.115
(edit) @b6343c6   07/10/14 19:20:39 Joel Sherrill Enhance Semaphore Blocking and Readying Time Test Cases tm02 and tm03 … 4.115
(edit) @648c86c   07/14/14 18:12:31 Jennifer Averett capture01: Add include of assert.h. 4.115
(edit) @247118bf   07/10/14 16:55:04 Jennifer Averett smpschedsem01: new test. This test verifies priority is inherited … 4.115
(edit) @7eb3fd47   07/10/14 16:45:58 Jennifer Averett smpschedaffinity05: Add test for worst case migration for affintiy … 4.115
