@e8878d4
04/07/22 13:48:39 |
joel |
fstests/fsdosfsname01/create_image.sh: Manually change license to …
@6d410fe8
04/07/22 13:49:10 |
joel |
testsuites/fstests/*: Change license to BSD-2
Updates #3053.
@d1c10d6
04/07/22 13:45:56 |
joel |
testsuites/libtests/*/*.dts. stackchk02.doc: Change license to BSD-2
@52a67757
04/07/22 13:44:36 |
joel |
testsuites/libtests/[m-z]*: Change license to BSD-2
Updates #3053.
@33078a2
04/07/22 13:44:05 |
joel |
testsuites/libtests/[a-l]*: Change license to BSD-2
Updates #3053.
@e0d6736
04/06/22 21:47:43 |
joel |
testsuites/support/*: Change license to BSD-2
Updates #3053.
@194d9ca5
04/06/22 21:46:59 |
joel |
testsuites/tmtests/*/*.py: Change license to BSD-2
Updates #3053.
@04b6c51
04/06/22 21:42:21 |
joel |
testsuites/tmtests/ remainder: Change license to BSD-2
+ include
@2c1d928
04/06/22 21:41:56 |
joel |
testsuites/tmtests/tm[23]*: Change license to BSD-2
Updates #3053.
@ef9df16a
04/06/22 21:40:46 |
joel |
testsuites/rmtests/tm[01]*: Change license to BSD-2
Updates #3053.
@e19e650
04/06/22 21:39:47 |
joel |
testsuites/benchmarks/*: Change license to BSD-2
Updates #3053.
@2c292f3
04/06/22 21:35:49 |
joel |
testsuites/ada/mptests/*: Change license to BSD-2
Updates #3053.
@b6656a00
04/06/22 21:35:15 |
joel |
testsuites/ada/tmtests/tmck: Change license to BSD-2
Updates #3053.
@2bf4acfc
04/06/22 21:34:53 |
joel |
testsuites/ada/tmtests/tm2*: Change license to BSD-2
Updates #3053.
@61ac3ab
04/06/22 21:34:30 |
joel |
testsuites/ada/tmtests/tm0*: Change license to BSD-2
Updates #3053.
@37426ca
04/06/22 21:33:54 |
joel |
testsuites/ada/tmtests/tm1*: Change license to BSD-2
Updates #3053.
@20cec598
04/06/22 21:38:10 |
joel |
testsuites/ada/sptests/spatcb01, spname01: Change license to BSD-2
@a767a2b
04/06/22 21:37:52 |
joel |
testsuites/ada/sptests/sp2*: Change license to BSD-2
Updates #3053.
@3d8f2a55
04/06/22 21:37:41 |
joel |
testsuites/ada/sptests/sp1*: Change license to BSD-2
Updates #3053.
@2df35d7
04/06/22 21:37:18 |
joel |
testsuites/ada/sptests/sp0*: Change license to BSD-2
Updates #3053.
@28052b7
04/06/22 21:38:43 |
joel |
testsuites/ada/samples/*: Change license to BSD-2
Updates #3053.
@8d5eb7e
04/06/22 21:36:15 |
joel |
testsuites/ada/support/*: Change license to BSD-2
Updates #3053.
@873e7da
04/12/22 06:32:11 |
Sebastian Huber |
validation: Avoid double fatal error
In the …
@ba36e4a
04/12/22 06:29:00 |
Sebastian Huber |
validation: Allow custom idle task body
@74e532f
04/01/22 19:35:50 |
joel |
testsuites/smptests/*: Change license to BSD-2
Updates #3053.
@e2ffe95
04/01/22 19:32:30 |
joel |
Updates #3053.
@acceb47
04/01/22 19:24:13 |
joel |
testsuites/libtests/[p-z]*: Change license to BSD-2
Updates #3053.
@1ef07d46
04/01/22 19:23:37 |
joel |
testsuites/libtests/[d-o]*: Change license to BSD-2
Updates #3053.
@366711f
04/01/22 19:22:44 |
joel |
testsuites/libtests/dl*: Change license to BSD-2
Updates #3053.
@85cc173
04/01/22 19:21:55 |
joel |
testsuites/libtests/[a-c]*: Change license to BSD-2
Updates #3053.
@b331f40
04/01/22 19:05:19 |
joel |
testsuites/tmtests/*: Change license to BSD-2
Updates #3053.
@42d4ebe
04/01/22 19:01:34 |
joel |
testsuites/mptests/*: Change license to BSD-2.
Updates #3053.
@43119193
04/04/22 13:17:56 |
christian.mauderer |
imfs: Fix index underrun when extending empty file
Currently the …
@c1a6e62
10/06/21 06:13:00 |
Sebastian Huber |
unit: Test red-black trees
@7ca6eeee
09/17/20 11:11:47 |
Sebastian Huber |
unit: Add test for misaligned builtin memcpy()
@95e3ade
09/17/20 11:10:41 |
Sebastian Huber |
unit: Add a unit test suite
@4160547
03/31/22 22:22:46 |
joel |
sp0*/*.doc: Remove junk UTF-8 character
@3ed5987
03/31/22 22:03:22 |
joel |
testsuites/sptests/sp[i-z]*/*.doc: Change license to BSD-2
Updates #3053.
@df6a7e0
03/31/22 22:02:59 |
joel |
testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2
Updates #3053.
@ce8d47b
03/31/22 22:01:46 |
joel |
testsuites/sptests/sp[0-7]*/*.doc: Change license to BSD-2
Updates #3053.
@d865c65
03/31/22 21:36:45 |
joel |
testsuites/sptests/sp[s-z]*: Change license to BSD-2
Updates #3053.
@0473b2b3
03/31/22 21:36:16 |
joel |
testsuites/sptests/sp[g-r]*: Change license to BSD-2
Updates #3053.
@e7d46b73
03/31/22 21:35:18 |
joel |
testsuites/sptests/sp[a-f*]*: Change license to BSD-2
Updates #3053.
@c50bb51
03/31/22 21:33:41 |
joel |
testsuites/sptests/sp[4-7]*: Change license to BSD-2
Updates #3053.
@d987a57
03/31/22 21:32:45 |
joel |
testsuites/sptests/sp[2-3]*: Change license to BSD-2
Updates #3053.
@eb57966
03/31/22 21:32:14 |
joel |
testsuites/sptests/sp1*: Change license to BSD-2
Updates #3053.
@72510115
03/31/22 21:31:58 |
joel |
testsuites/sptests/sp0*: Change license to BSD-2
Updates #3053.
@ea4d7566
03/24/22 12:22:32 |
matthew.joyce |
newlib01: Added tests for exit procedures
Added tests for exit …
@9f9f140
03/29/22 13:23:29 |
Sebastian Huber |
rtems: Clarify scheduler of created task
@c2d7376
03/29/22 14:31:25 |
Sebastian Huber |
validation: Use individual names for ident tests
Make the task …
@c9625a21
03/22/22 19:45:11 |
joel |
testsuites/: Update Eric Norum contact info and normalize file headers
@10d1de25
03/24/22 10:19:55 |
Sebastian Huber |
validation: Clarify comment
@3661518
03/10/22 13:11:12 |
Sebastian Huber |
smp: Add fatal error
Add SMP-specifc …
@14de245d
12/09/21 15:25:29 |
Sebastian Huber |
validation: Test support functions
The test source code is generated …
@ab2c04a
12/09/21 15:25:12 |
Sebastian Huber |
validation: Test thread implementation
The test source code is …
@4a8f4b7
12/09/21 15:24:46 |
Sebastian Huber |
validation: Test SMP-specific aspects
@ff50664
12/09/21 15:22:28 |
Sebastian Huber |
validation: Test scheduler operations
@9f283e7
12/09/21 15:22:11 |
Sebastian Huber |
validation: Test C libary functions
@c24747a6
12/09/21 15:21:26 |
Sebastian Huber |
validation: Test <sys/lock.h> mutex operations
The test source code …
@5fb7ce8
12/09/21 15:21:08 |
Sebastian Huber |
validation: Test futex support
The test source code is generated from …
@fa660c4d
12/09/21 15:20:45 |
Sebastian Huber |
validation: Test status code directives
@7eb4fc8d
12/09/21 15:19:41 |
Sebastian Huber |
validation: Test timecounter
@bc0cd69
12/09/21 15:19:24 |
Sebastian Huber |
validation: Test object services
@c88db0f
12/09/21 15:17:23 |
Sebastian Huber |
validation: Test User Extensions Manager
@565a7e66
12/09/21 15:17:07 |
frank.kuehndel |
validation: Test Timer Manager
@6b293904
09/07/21 11:56:42 |
Sebastian Huber |
validation: Test Task Manager
@32e472a7
09/07/21 11:56:42 |
Sebastian Huber |
validation: Test Signal Manager
@43adf2e
12/09/21 15:16:34 |
Sebastian Huber |
validation: Test Semaphore Manager
@1c87bb5
12/09/21 15:15:46 |
Sebastian Huber |
validation: Test Scheduler Manager
@98091b6d
12/09/21 15:14:37 |
frank.kuehndel |
validation: Test Rate Monotonic Manager
@5c85024
12/09/21 15:14:24 |
Sebastian Huber |
validation: Test Partition Manager
@372ff26
12/09/21 15:14:08 |
Sebastian Huber |
validation: Test options
@b63084a
12/09/21 15:13:58 |
Sebastian Huber |
validation: Test task modes
@04fb7b6
12/09/21 15:12:55 |
frank.kuehndel |
validation: Test Message Manager
@134b4cb7
12/09/21 15:12:23 |
Sebastian Huber |
validation: Test IO Manager
@aebf6b6
09/02/21 13:29:10 |
Sebastian Huber |
validation: Test Interrupt Manager
@8d3fe04
12/09/21 15:11:43 |
Sebastian Huber |
validation: Test Event Manager
@32ca0c47
12/09/21 15:11:08 |
Sebastian Huber |
validation: Test rtems_cpu_usage_reset()
@034d0b2
12/09/21 15:10:46 |
frank.kuehndel |
validation: Test Clock Manager
@b322a3ba
12/09/21 15:10:25 |
Sebastian Huber |
validation: Test Cache Manager
@99544e3
12/09/21 15:09:47 |
frank.kuehndel |
validation: Test <rtems/score/basedefs.h>
@1410d5b8
07/15/21 08:02:40 |
Sebastian Huber |
validation: Test Barrier Manager
@0b26e099
12/09/21 15:09:03 |
Sebastian Huber |
validation: Test attributes
@ca4d9ea
12/09/21 15:08:42 |
Sebastian Huber |
validation: Test application configuration
@d9a07fd8
12/09/21 15:05:48 |
Sebastian Huber |
validation: Test object identification
@a4b77184
12/09/21 15:05:27 |
Sebastian Huber |
validation: Test mutex operations
@a6b4a3b0
12/09/21 15:05:09 |
Sebastian Huber |
validation: Test semaphore operations
@7db4c14b
12/09/21 15:02:20 |
Sebastian Huber |
validation: Test thread queues
@c39133b8
12/10/21 08:41:22 |
Sebastian Huber |
validation: Add system termination test suites
@212b0ca
12/09/21 14:58:14 |
Sebastian Huber |
validation: Add test suites
@40cc4f5
12/09/21 14:49:53 |
Sebastian Huber |
validation: Improve support library
Update #3716.
@33454152
03/24/22 10:10:03 |
Sebastian Huber |
newlib01: Adjust variable name
@c82eb0b0
03/16/22 21:35:06 |
matthew.joyce |
newlib01: Check exit processing for file objects
@5028a9f
03/03/22 09:18:03 |
testsuites: Manual file header clean up
Updates #4625.
@bbe71c61
03/01/22 21:40:17 |
joel |
bsps/testsuites/: Scripted embedded brains header file clean up
@da72043
03/01/22 18:00:48 |
joel |
testsuites/fstests/fsdosfsname01/create_files.cs: Convert to UNIX …
@5fbb4779
03/01/22 17:45:02 |
joel |
testsuites/.../*doc: Manual cleanup of embedded brains File Headers
@b08ba92
03/08/22 08:22:43 |
Sebastian Huber |
smptests/smpstart01: New test program
Update #4627.
@8f1e8f8f
02/07/22 15:10:45 |
Sebastian Huber |
kern_ntptime.c: Port to RTEMS
Remove previous adjtime() …
@d24da94
02/15/22 11:26:12 |
matthew.joyce |
newlib01: Edit asserts to check initialization
Edit assert statements …
