@e5a76ee5
11/23/99 13:35:45 |
Joel Sherrill |
Patch rtems-rc-19991117-13.diff from Ralf Corsepius …
4.104.114.84.95
@6e9ad6c
11/23/99 13:32:07 |
Joel Sherrill |
Patch rtems-rc-19991117-12.diff from Ralf Corsepius …
4.104.114.84.95
@de759c5
11/22/99 19:23:10 |
Joel Sherrill |
Patch rtems-rc-19991117-8.diff from Ralf Corsepius …
4.104.114.84.95
@e31c63e5
11/22/99 19:21:38 |
Joel Sherrill |
Patch rtems-rc-19991117-7.diff from Ralf Corsepius …
4.104.114.84.95
@5fe4a109
11/22/99 19:08:23 |
Joel Sherrill |
Converted to automake.
4.104.114.84.95
@b8cda5a6
11/22/99 19:02:35 |
Joel Sherrill |
Added ifndef around build_time so pmacros.h and tmacros.h could be …
4.104.114.84.95
@24f6608
11/22/99 16:05:09 |
Jennifer.Averett |
+ Corrected error messages.
+ Added tests for sem_open, sem_close, and …
4.104.114.84.95
@65052685
11/22/99 14:28:19 |
Joel Sherrill |
Added ifndef around build_time macro so tmacros.h and pmacros.h
can be …
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@8c5cc6b2
11/18/99 19:51:13 |
Jennifer.Averett |
Added test code for named semaphores and moved to use of …
4.104.114.84.95
@23168f53
11/18/99 19:50:45 |
Jennifer.Averett |
Started to added POSIX message queue test code.
4.104.114.84.95
@f811c8e
11/18/99 17:05:44 |
Joel Sherrill |
Removed IT_COUNT since it was not used.
4.104.114.84.95
@b7852c2
11/18/99 13:58:02 |
Joel Sherrill |
Patch rtems-rc-19991105-3.diff.gz from Ralf Corsepius …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@d2b8d742
11/17/99 16:58:04 |
Jennifer.Averett |
+ Updated copyright information.
4.104.114.84.95
@9d9a3dd
11/17/99 16:47:58 |
Jennifer.Averett |
4.104.114.84.95
@4ccd020
11/17/99 15:24:32 |
Joel Sherrill |
New shell of a test for ITRON Mailbox Manager.
4.104.114.84.95
@0545e15
11/16/99 22:57:58 |
Joel Sherrill |
Fixed screen.
4.104.114.84.95
@987445b
11/16/99 22:55:11 |
Joel Sherrill |
Added proper nesting level for dispatch disable check.
4.104.114.84.95
@96c2db6
11/16/99 22:51:47 |
Joel Sherrill |
Added code so if dispatching level is specified to be -1, then no …
4.104.114.84.95
@cea3304
11/16/99 22:51:06 |
Joel Sherrill |
Corrected nesting level on dispatching verification.
4.104.114.84.95
@0beded61
11/16/99 22:50:08 |
Joel Sherrill |
Corrected disable dispatch nesting count checks.
4.104.114.84.95
@ca7d922
11/16/99 21:32:09 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@9c7867b
11/16/99 21:30:41 |
Jennifer.Averett |
Inserted output from the erc32 run into the output file.
4.104.114.84.95
@7fe5ff38
11/16/99 21:15:03 |
Joel Sherrill |
Use miniIMFS like hello from samples.
4.104.114.84.95
@a470c0ee
11/16/99 21:10:48 |
Joel Sherrill |
Increased stack space because message buffers are on the stack.
4.104.114.84.95
@22542b6b
11/16/99 20:50:36 |
Jennifer.Averett |
Removed leading space from output.
4.104.114.84.95
@f89df68
11/16/99 20:50:07 |
Jennifer.Averett |
Added comment indicating that dup is known to be broken.
4.104.114.84.95
@47c7705
11/16/99 20:49:18 |
Jennifer.Averett |
Added data to the log file so it matches the real output.
4.104.114.84.95
@ac0ba842
11/16/99 20:48:48 |
Jennifer.Averett |
Added comment to log file indicating that task order is not
critical.
4.104.114.84.95
@36072c8a
11/16/99 20:47:30 |
Jennifer.Averett |
Added test case of rsm_tsk and frsm_tsk on a task not suspended.
This …
4.104.114.84.95
@90378e4
11/16/99 16:23:26 |
Joel Sherrill |
Added BSP_MAXIMUM_OPERATION_COUNT and BSP_ITERATION_COUNT
which allow …
4.104.114.84.95
@4b960e5
11/16/99 16:21:00 |
Joel Sherrill |
Added code to the macros which checked directive status to also
check …
4.104.114.84.95
@72d4b1d9
11/16/99 16:19:06 |
Joel Sherrill |
Use the miniIMFS to reduce code space.
4.104.114.84.95
@a20190a4
11/16/99 16:15:05 |
Joel Sherrill |
Added test cases for uname().
4.104.114.84.95
@fa3346f
11/16/99 15:41:58 |
Jennifer.Averett |
Modified file to match seen output.
4.104.114.84.95
@f9879915
11/16/99 15:41:29 |
Jennifer.Averett |
Modified output file to match seen output. Added comment to all ino …
4.104.114.84.95
@e9b00d7
11/16/99 15:40:40 |
Jennifer.Averett |
Removed compiler warning.
4.104.114.84.95
@d37aa444
11/16/99 15:39:08 |
Jennifer.Averett |
Changed asserts to tmmacros.
4.104.114.84.95
@2d82857
11/16/99 15:38:44 |
Jennifer.Averett |
Updated scn file to match new output. Left out unemplemented
parts as …
4.104.114.84.95
@47619951
11/16/99 15:33:10 |
Jennifer.Averett |
+ Changed ID to 1. ( Compilation error introduced by modifications. )
4.104.114.84.95
@1da9f4bd
11/16/99 15:30:04 |
Jennifer.Averett |
Modified scan file to match.
4.104.114.84.95
@c276c87
11/16/99 15:24:30 |
Joel Sherrill |
Added itron tests.
4.104.114.84.95
@3fb7b70b
11/16/99 14:39:56 |
Jennifer.Averett |
Changed to call tmmacros instead of assert.
4.104.114.84.95
@e672263
11/15/99 21:28:21 |
Jennifer.Averett |
Fixed verificaiton checks to call correct macro if dispatch is disabled.
4.104.114.84.95
@06380cfe
11/15/99 21:25:53 |
Jennifer.Averett |
+ Added check that a task could be sent to a dormant state
then …
4.104.114.84.95
@0f88857
11/15/99 21:19:58 |
Jennifer.Averett |
+ Changed preempt routine into two dummy tasks one that is in dormant
4.104.114.84.95
@afb11f8
11/12/99 22:00:10 |
Joel Sherrill |
+ Modified calls to use TSK_SLF for calls to self.
+ Modified calls to …
4.104.114.84.95
@624d7ca4
11/12/99 21:27:42 |
Joel Sherrill |
+ Added comments on paths tested.
4.104.114.84.95
@e8c902c
11/12/99 21:26:54 |
Joel Sherrill |
+ Added check for priority over 256.
+ Modified output to correctly …
4.104.114.84.95
@8ed3125d
11/12/99 21:24:56 |
Joel Sherrill |
Added comments for path's tested.
4.104.114.84.95
@f4771656
11/12/99 14:51:03 |
Joel Sherrill |
Test name changed to reflect placement after merger.
4.104.114.84.95
@ec0b5ce
11/12/99 14:50:42 |
Joel Sherrill |
Changed output …
4.104.114.84.95
@3136f5c9
11/12/99 14:49:47 |
Joel Sherrill |
Increased stack …
4.104.114.84.95
@6977b38
11/12/99 13:45:39 |
Joel Sherrill |
Enabled after merging message buffer code.
4.104.114.84.95
@f9078d1
11/12/99 13:22:31 |
Joel Sherrill |
Added comment block and removed include of deleted file.
4.104.114.84.95
@dc83752
11/11/99 02:23:26 |
Joel Sherrill |
Screen updated.
4.104.114.84.95
@458d4e66
11/11/99 02:23:04 |
Joel Sherrill |
Added new test sp28 to test the task variable directives.
4.104.114.84.95
@713b2ea
11/10/99 22:15:42 |
Joel Sherrill |
General cleanup. Test documentation improved. The message buffer …
4.104.114.84.95
@74db82a
11/10/99 20:36:25 |
Joel Sherrill |
rtems_semaphore_flush test from Eric Norum <eric@…>.
4.104.114.84.95
@442d0478
11/10/99 14:19:55 |
Joel Sherrill |
Combination of committing some new files which had been overlooked
and …
4.104.114.84.95
@dcc1f6b6
11/10/99 13:45:54 |
Joel Sherrill |
Added support for ITRON tests.
4.104.114.84.95
@bab5ba44
11/09/99 23:28:04 |
Joel Sherrill |
Added more tasking tests.
4.104.114.84.95
@e099180
11/09/99 23:27:05 |
Joel Sherrill |
Merged tests from Task group.
4.104.114.84.95
@3d67661
11/09/99 23:10:48 |
Joel Sherrill |
Added nesting count for suspend/resume.
4.104.114.84.95
@70e9af9
11/09/99 22:45:35 |
Joel Sherrill |
Changed B, H, and W variables to BVar, HVar, and WVar to avoid …
4.104.114.84.95
@ad502d18
11/09/99 22:14:21 |
Joel Sherrill |
Renamed classes to avoid single letter class names.
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@a8df60b
11/09/99 13:38:00 |
Joel Sherrill |
New test for POSIX Message Queues added.
4.104.114.84.95
@27eb3ec
11/09/99 13:36:26 |
Joel Sherrill |
New files.
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@4c1b914
11/02/99 16:39:44 |
Joel Sherrill |
Minor changes to make the screen match a bit better.
4.104.114.84.95
@78edd44
11/02/99 16:38:19 |
Joel Sherrill |
Minor fixes to make screen match a bit better.
4.104.114.84.95
@3251b55
11/02/99 16:29:56 |
Joel Sherrill |
Added more proper checking of F_GETFL and F_SETFL.
Disabled test of …
4.104.114.84.95
@a49a7f3d
11/02/99 15:22:00 |
Joel Sherrill |
Backed out change that increased the minimum stack size since it
was …
4.104.114.84.95
@f59df6b2
11/02/99 15:19:43 |
Joel Sherrill |
Modified to use minimum stack size and reserve the necessary amount
of …
4.104.114.84.95
@2e3e407
11/01/99 20:21:17 |
Joel Sherrill |
Increased stack space for all initialization tasks in tmtests.
4.104.114.84.95
@5fe6b21a
11/01/99 20:14:35 |
Joel Sherrill |
Increased stack space of a task.
4.104.114.84.95
@328aa64c
11/01/99 20:11:24 |
Joel Sherrill |
Increased stack space of task 2.
4.104.114.84.95
@4443984
11/01/99 20:08:05 |
Joel Sherrill |
Increased stack space for a task.
4.104.114.84.95
@c42e6c72
11/01/99 20:06:02 |
Joel Sherrill |
Increased stack space for task 1.
4.104.114.84.95
@5c104e08
10/28/99 15:12:10 |
Joel Sherrill |
New test added - psxcancel. This is just a shell for now.
4.104.114.84.95
@1232196a
10/25/99 14:14:07 |
Joel Sherrill |
Added sp26 which tests the rtems_task_is_suspended directive.
4.104.114.84.95
@9060699
10/25/99 14:13:14 |
Joel Sherrill |
Modified to ease comparison of screen to target output.
4.104.114.84.95
@48296038
10/25/99 14:11:12 |
Joel Sherrill |
Modified to reflect test change where reinitialize mutex test case was …
4.104.114.84.95
@524767cb
10/25/99 14:10:38 |
Joel Sherrill |
Removed reinitialize mutex test case to reflect earlier code change in …
4.104.114.84.95
@d013d05
10/21/99 16:48:06 |
Joel Sherrill |
Increased stack size of initialization thread.
4.104.114.84.95
@7a81160
10/05/99 19:21:54 |
Joel Sherrill |
Removed ifdef on go32.
4.104.114.84.95
@7d96321
10/04/99 19:41:34 |
Joel Sherrill |
Modifications necessary to support testing of exitting a pthread from …
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@e50e3eff
10/04/99 13:54:25 |
Joel Sherrill |
New test for getenv/putenv added by Joel.
4.104.114.84.95
@b808038
08/18/99 20:59:36 |
Joel Sherrill |
Reran and replaced screen after report from Gerwin Pfab …
4.104.114.84.95
@908436c1
08/10/99 15:38:09 |
Joel Sherrill |
New configuration files added by patch from
Ralf Corsepius …
4.104.114.84.95
@3a8915e
08/06/99 17:55:25 |
Joel Sherrill |
Patch rtems-rc-19990709-6-diff from Ralf Corsepius …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@10794a7
07/01/99 22:08:33 |
Joel Sherrill |
Modified to reflect change in calling sequence of mount().
4.104.114.84.95
@dbf969e
07/01/99 22:08:13 |
Joel Sherrill |
Test modified to reflect change in calling sequence of mount().
4.104.114.84.95
@d7851582
05/17/99 22:15:56 |
Joel Sherrill |
Added simple test to find minimum code size of executive with this BSP …
4.104.114.84.95
@fcf17a4
05/14/99 16:25:15 |
Joel Sherrill |
Added testing for C++ exceptions from Rosimildo DaSilva? …
4.104.114.84.95
