@c77cd426
04/30/18 22:18:49 |
joel |
Drop executable permissions on .[ch] files
5
@8b5a801
04/27/18 05:20:27 |
Sebastian Huber |
smptests/smpschededf02: Add test case
5
@adb85dd
04/21/18 08:22:08 |
Sebastian Huber |
bsps: Move make/custom/* files to bsps
Adjust various build files. …
5
@5e8a24ca
04/23/18 08:35:35 |
Sebastian Huber |
smptests/smpschedaffinity02: Fix configuration
5
@ad071b68
04/22/18 13:54:56 |
Sebastian Huber |
sptests/sp36: Remove obsolete test program
It tests the (never really …
5
@234f0a2d
04/20/18 12:41:05 |
Sebastian Huber |
build: Remove subdir-objects from Ada tests
Somehow it does not work. …
5
@9964895
04/20/18 08:35:35 |
Sebastian Huber |
bsps: Move startup files to bsps
Adjust build support files to new …
5
@1b2681fe
04/12/18 15:13:48 |
joel |
Multiple BSP tcfg: Disable iconv files.
5
@696b9121
04/12/18 07:48:28 |
Chris Johns |
libdl: Fix the tests loading the correct files
5
@86e79d7
04/12/18 04:52:36 |
Chris Johns |
testsuites/dl06: Add a test for RAP format.
This test loads a RAP …
5
@af6168c6
04/11/18 05:45:38 |
Chris Johns |
build: Add support for automake's silent build support.
5
@b8c59353
04/11/18 03:26:58 |
Chris Johns |
build: Fix make clean.
Update #3254.
5
@aa567bc1
04/10/18 06:06:39 |
Chris Johns |
configure: Add subdir-objects to all automake flags.
This option …
5
@7ff743d
04/10/18 00:32:25 |
Chris Johns |
Generate an error if a BSP in the --enable-rtemsbsp list is not valid
5
@9e8df1fe
04/10/18 05:02:01 |
Chris Johns |
fstest/fsrfsbitmap01: Update RFS bitmap tests to test fixes.
Add …
5
@2eaea422
04/10/18 10:38:10 |
Sebastian Huber |
sptests: Fix AM_CONDITIONAL
Update #3382.
5
@ee3d7dcb
04/09/18 03:46:17 |
Chris Johns |
testsuites: Remove the test check from the subdir support.
Leave the …
5
@cc14545e
04/09/18 03:45:48 |
Chris Johns |
testsuite/tmtests: Merged nested Makefile.am files into one …
5
@bc06753
04/09/18 03:45:15 |
Chris Johns |
testsuite/sptests: Merged nested Makefile.am files into one …
5
@8074fa0b
04/09/18 03:44:37 |
Chris Johns |
testsuite/smptests: Merged nested Makefile.am files into one …
5
@d027e6bb
04/09/18 03:44:01 |
Chris Johns |
testsuite/samples: Merged nested Makefile.am files into one …
5
@590a5809
04/09/18 03:43:30 |
Chris Johns |
testsuite/irhealstone: Merged nested Makefile.am files into one …
5
@dfc57eb
04/09/18 03:42:49 |
Chris Johns |
testsuite/psxtmtests: Merged nested Makefile.am files into one …
5
@2a99a6a
04/09/18 03:42:02 |
Chris Johns |
testsuite/psxtests: Merged nested Makefile.am files into one …
5
@3206879f
04/09/18 03:41:08 |
Chris Johns |
testsuite/mptests: Merged nested Makefile.am files into one …
5
@8967e5f
04/09/18 03:40:29 |
Chris Johns |
testsuite/fstests: Merged nested Makefile.am files into one …
5
@5c65b988
04/09/18 03:39:19 |
Chris Johns |
testsuite/libtests: Merged nested Makefile.am files into one …
5
@32f2629b
04/09/18 03:35:17 |
Chris Johns |
testsuite/benchmarks: Merged nested Makefile.am files into one …
5
@18f77699
04/08/18 22:18:46 |
Chris Johns |
testsuite: Autoconf test check support.
The autoconf function checks …
5
@9edb72e
04/05/18 04:56:26 |
Sebastian Huber |
build: Remove DISTCLEANFILES
A "make distclean" is not supported. So, …
5
@2d0bc83
03/30/18 18:42:21 |
Sebastian Huber |
build: Remove EXTRA_DIST
A "make dist" is not supported. So, it makes …
5
@6fadb7af
03/08/18 05:33:24 |
Sebastian Huber |
config: Use new scheduler configuration defines
Update #3325.
5
@828049cb
03/08/18 07:48:28 |
Sebastian Huber |
sptests/sp19: Fix test output methods
Do not use fprintf() in non-fp …
5
@a4151d0
03/07/18 12:00:44 |
Sebastian Huber |
libtests/capture01: Fix configuration
5
@ff281a6f
03/07/18 09:31:10 |
Sebastian Huber |
smptests: Fix obsolete FIXME comments/code
5
@337a186
02/21/18 11:40:18 |
Sebastian Huber |
Add a simple task console driver
Close #3320.
5
@8b2d5b8
02/28/18 12:02:55 |
Sebastian Huber |
spglobalcon02: New test
Update #3319.
5
@0d44e251
02/22/18 15:37:26 |
Sebastian Huber |
ada/sp04: Fix test failure due to compiler opti
The SPTEST.RUN_COUNT …
5
@a3eec5c
02/09/18 12:17:45 |
Sebastian Huber |
fsclose01: Fix task mode, use attribute
Update #1971.
5
@48aa4b5d
02/09/18 12:14:18 |
Sebastian Huber |
fsclose01: Use floating-point task
The tmpfile() uses sprintf().
5
@dc8fd01
02/09/18 07:56:20 |
Sebastian Huber |
tests: Support %g print format specifier
5
@d9800ac
01/03/18 05:36:10 |
Sebastian Huber |
libdl: Use self-contained recursive mutex
Update #2843.
5
@53b6484
02/05/18 08:57:45 |
Sebastian Huber |
termios: Remove obsolete configuration options
Update #2843.
5
@4ac5ffbb
02/05/18 08:31:32 |
Sebastian Huber |
fsclose01: Add tmpfile() test case
Close #1971.
5
@8ddd92d
12/14/17 05:12:59 |
Sebastian Huber |
pipe: Use self-contained mutex
Update #2843.
5
@2c12262
11/28/17 05:30:35 |
Sebastian Huber |
termios: Use self-contained objects
Update #2840.
5
@f14a04c6
11/24/17 05:38:07 |
Sebastian Huber |
Add RTEMS thread API
Update #2843.
5
@9480815a
12/21/17 13:36:52 |
Sebastian Huber |
score: Introduce new monotonic clock
Rename …
5
@89c0313
12/21/17 13:31:55 |
Sebastian Huber |
score: Optimize watchdog tickle
Avoid unnecessary lock …
5
@0c5d22f
12/18/17 09:24:34 |
Sebastian Huber |
smptests/smpopenmp01: New test
5
@d71d1da
02/02/18 07:00:23 |
Sebastian Huber |
spsyslock01: Fix object compare
Due to structure internal padding the …
5
@c1c71cd
02/01/18 12:49:11 |
Sebastian Huber |
sp20: Fix print buffer size
There were two issues:
1. The buffer …
5
@cf56b18a
02/02/18 06:48:08 |
Sebastian Huber |
smpschededf01: Use rtems_test_busy_cpu_usage()
The rtems_test_busy() …
5
@63fab5aa
02/01/18 14:14:55 |
Sebastian Huber |
smpschedaffinity04: Fix configuration
5
@c9aba80
02/01/18 14:11:41 |
Sebastian Huber |
smpcapture01: Fix configuration
5
@865b3027
01/29/18 12:53:13 |
Sebastian Huber |
Avoid Newlib-specific _EXFUN()
5
@bc96f3b4
01/23/18 08:53:06 |
Sebastian Huber |
ada: Introduce RTEMS.Size type
Some time ago the Classic API object …
5
@2afb22b
12/23/17 07:18:56 |
Chris Johns |
Remove make preinstall
A speciality of the RTEMS build system was the …
5
@0349a2b
01/22/18 14:23:26 |
Sebastian Huber |
cdtest: Increase stack size
5
@990235d
01/22/18 13:13:11 |
Sebastian Huber |
psxchroot01: Force release of global locations
Free deferred …
5
@6bc5e47
12/22/17 12:44:56 |
Sebastian Huber |
smptests: Fix configuration
Update #2843.
5
@cf2024b
01/19/18 12:08:46 |
Sebastian Huber |
smp03: Use floating-point tasks
This test uses sprintf().
5
@cf099be
01/19/18 12:04:25 |
Sebastian Huber |
5
@5e3ef46
01/19/18 09:57:38 |
Sebastian Huber |
smpaffinity01: Use floating-point task
5
@7274e67
01/19/18 09:56:13 |
Sebastian Huber |
smp08: Use floating-point task
5
@60dc020
01/19/18 09:54:23 |
Sebastian Huber |
psxfile01: Use floating-point task
This test uses fprintf().
5
@654fa58a
01/19/18 09:50:44 |
Sebastian Huber |
block06: Use floating-point task
5
@5b7f922
01/19/18 09:49:01 |
Sebastian Huber |
fstests: Use floating-point task
The fstests use snprintf().
5
@32d50688
01/19/18 09:05:24 |
Sebastian Huber |
psxpasswd02: Use floating-point task
5
@e9588d5f
01/19/18 09:03:53 |
Sebastian Huber |
psxstat: Use floating-point task
5
@d2f9d10f
01/19/18 09:00:15 |
Sebastian Huber |
psximfs02: Use floating-point task
5
@32e8fc3
01/19/18 08:57:05 |
Sebastian Huber |
spassoc01: Use floating-point task
5
@3205fd6
01/19/18 08:53:34 |
Sebastian Huber |
tests: Use vprintk() in locked_printf()
This avoids blocking output …
5
@047e8aa
01/19/18 08:53:18 |
Sebastian Huber |
tests: Remove unused locked_printk()
5
@e6d89860
01/19/18 08:52:23 |
Sebastian Huber |
smpmigration01: Enable floating-point output
5
@9c270ac
01/19/18 08:47:39 |
Sebastian Huber |
5
@030ce68
01/02/18 08:03:19 |
Sebastian Huber |
tests: Fix canonical-target-name.m4
Update #3109.
5
@1307e75
12/08/17 18:15:12 |
joel |
tm08: Do not use RTEMS_INTERRUPT_MASK for no reschedule case
Updates …
5
@21e96d66
12/08/17 18:14:20 |
joel |
sp08: Disable RTEMS_INTERRUPT_MASK testing when SMP enabled
Updates #3000.
5
@2fe3687
12/06/17 14:56:50 |
Christian.Mauderer |
dosfs: Allow creating a file with similar name.
If there is already a …
5
@e9e0f1d4
12/05/17 15:56:47 |
joel |
smpunsupported01: Add missing error check for rtems_task_mode
Update …
5
@9e339a8
12/06/17 18:17:03 |
Sebastian Huber |
sptests/sp51: Delete semaphore after use
This ensures that the …
5
@bc5b56a
12/04/17 07:56:00 |
Sebastian Huber |
libio: Use API mutex
5
@ca835e56
11/28/17 15:42:00 |
dosfs: Fix files with same name as volume name.
Take care that a file …
5
@fd5471b
12/01/17 21:37:06 |
Sebastian Huber |
ada: Check C and POSIX types
Update #3256.
5
@6c2b8a4b
11/29/17 05:23:27 |
Sebastian Huber |
score: Use self-contained API mutex
Use a self-contained recursive …
5
@3d7d2a37
12/04/17 09:52:01 |
Sebastian Huber |
ada/sp09: Fix timer server test case
A priority of zero is valid for …
5
@535d0183
12/04/17 09:51:33 |
Sebastian Huber |
ada/sp09: Fix region test cases
5
@6e05265f
12/04/17 09:50:49 |
Sebastian Huber |
ada: Fix work_space_size() test support
5
@215fa231
12/04/17 08:38:25 |
Sebastian Huber |
ada/tm04: Account for task delete behaviour change
5
@76bd25e
12/02/17 19:15:29 |
Sebastian Huber |
ada/sp19: Add missing FP attribute
5
@dda8142f
12/01/17 14:22:02 |
Sebastian Huber |
ada/sp07: Fix uninitialized variable
Bug was introduced by …
5
@5e05fa0
12/01/17 14:21:34 |
Sebastian Huber |
ada: Fix user extension support
5
@c589775a
12/01/17 12:56:50 |
Sebastian Huber |
ada: Use CONFIGURE_DISABLE_SMP_CONFIGURATION
Most Ada tests fail …
5
@2178978a
12/01/17 12:18:14 |
Sebastian Huber |
ada/tm20: Account for optional heap protection
Reduce size of the big …
5
@a01e169
12/01/17 10:26:10 |
Sebastian Huber |
ada/spname01: Fix several issues
5
@f6c9334d
12/01/17 07:51:17 |
Sebastian Huber |
ada: Add standard test begin/end message
5
@6899a8d
12/01/17 07:38:05 |
Sebastian Huber |
ada: Delete superfluous CONFIGURE_SPTEST
5
@d6c5a97
11/29/17 16:30:43 |
joel |
block06/init.c: Fix printf() format warning
5
@e58e29fd
11/24/17 06:58:55 |
Sebastian Huber |
Remove coverhd.h
This header file contained timing overhead values …
5
