@c42be504
11/16/16 13:50:09 |
Sebastian Huber |
posix: Add self-contained pthread spinlock
Turn pthread_spinlock_t …
5
@125f248
11/16/16 15:39:43 |
Sebastian Huber |
score: Add thread queue enqueue callout
Replace the expected thread …
5
@84e6f15
11/10/16 11:02:28 |
Sebastian Huber |
score: Robust thread dispatch
On SMP configurations, it is a fatal …
5
@a6283671
11/22/16 11:51:12 |
Sebastian Huber |
smptests/smplock01: Test TAS and TTAS locks
Cache align locks in the …
5
@46b5343
11/22/16 10:34:43 |
Sebastian Huber |
libtests/cpuuse: Check status only
We may own the allocator mutex …
5
@db20706
11/23/16 06:17:00 |
Sebastian Huber |
smptests/smpscheduler02: Fix task initialization
Set scheduler before …
5
@8954368
11/23/16 05:33:31 |
Sebastian Huber |
psxtests/psxkey08: Avoid rtems_semaphore_flush()
Avoid …
5
@408609f6
11/10/16 14:17:28 |
Sebastian Huber |
score: Add _ISR_Is_enabled()
In contrast to _ISR_Get_level() the …
5
@537f00eb
11/10/16 15:25:41 |
Sebastian Huber |
score: Restrict task interrupt level to 0 on SMP
Update #2811.
5
@d78d529
11/14/16 08:11:07 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_direct()
This function is useful …
5
@1897fa6
11/10/16 15:56:11 |
Sebastian Huber |
sptests/sp37: Better cope with internal padding
5
@38a1449
11/09/16 13:59:33 |
Sebastian Huber |
powerpc: Add _CPU_Get_current_per_CPU_control()
Add …
5
@05ca53d
10/31/16 12:08:33 |
Sebastian Huber |
rtems: Add scheduler processor add/remove
Update #2797.
5
@1f5bee3
11/07/16 15:54:40 |
Sebastian Huber |
score: Add and use Thread_Control::is_idle
Update #2797.
5
@2612a0b
11/02/16 05:36:13 |
Sebastian Huber |
score: Simplify _Scheduler_Get_by_id()
Avoid dead code in non-SMP …
5
@eb98dd49
11/09/16 12:14:38 |
Sebastian Huber |
score: Inline some SMP lock operations by default
The SMP ticket lock …
5
@6de41c5f
10/27/16 06:24:50 |
Sebastian Huber |
Provide kernel space header files
These kernel space header files …
5
@edbd43c6
11/04/16 12:19:11 |
Sebastian Huber |
score: Prevent assignment to _Thread_Executing
5
@ee42943
11/03/16 13:44:15 |
Sebastian Huber |
score: Optimize self-contained mutexes
5
@8cf2f8b
10/03/16 16:03:36 |
joel |
testsuites/testdata/dltests-broken-on-this-bsp.tcfg: Add new dl tests 03-05
5
@47d2464
10/31/16 15:23:52 |
Sebastian Huber |
score: Conditionally enable thread resource count
Maintain the thread …
5
@9e7fa07
10/31/16 15:23:13 |
Sebastian Huber |
score: Relax _Scheduler_Set() restrictions
No longer unconditionally …
5
@6e31b56f
11/03/16 09:52:53 |
Sebastian Huber |
rtems: Fix binary semaphore resource count
Binary semaphores (not …
5
@0154dea3
11/03/16 07:55:24 |
Sebastian Huber |
tmtests/tmfine01: Update screen file
Add plot script.
5
@d505fbb
11/03/16 07:22:59 |
Sebastian Huber |
smptests/smplock01: Update screen file
5
@63e2ca1b
10/31/16 08:13:35 |
Sebastian Huber |
score: Simplify yield and unblock scheduler ops
Update #2556.
5
@2dd098a
10/31/16 07:33:11 |
Sebastian Huber |
score: Introduce Thread_Scheduler_control::home
Replace …
5
@1cafc46
10/31/16 05:19:43 |
Sebastian Huber |
score: Delete Resource Handler
Update #2556.
5
@6771359f
10/27/16 04:42:06 |
Sebastian Huber |
score: Second part of new MrsP implementation
Update #2556.
5
@9c238e1
10/21/16 12:33:01 |
Sebastian Huber |
score: Simplify update priority scheduler op
Remove unused return status.
5
@3a27248
10/21/16 07:23:58 |
Sebastian Huber |
score: First part of new MrsP implementation
Update #2556.
5
@6a82f1ae
10/10/16 09:46:07 |
Sebastian Huber |
score: Yield support for new SMP helping protocol
Update #2556.
5
@351c14d
09/27/16 09:33:36 |
Sebastian Huber |
score: Add new SMP scheduler helping protocol
Update #2556.
5
@72e0bdb
10/10/16 12:50:19 |
Sebastian Huber |
score: Pass scheduler node to unblock operation
Changed for …
5
@e382a1b
10/10/16 12:33:17 |
Sebastian Huber |
score: Pass scheduler node to block operation
Changed for consistency …
5
@2df4abc
10/10/16 12:01:55 |
Sebastian Huber |
score: Pass scheduler node to yield operation
5
@501043a
09/30/16 12:38:04 |
Sebastian Huber |
score: Pass scheduler node to update priority op
This enables to call …
5
@b7694c8c
10/31/16 15:04:11 |
Sebastian Huber |
sptests/sp35: Remove dead code
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@7eec247
10/31/16 09:50:54 |
Sebastian Huber |
smptests/smplock01: Use test support
Convert output to XML.
5
@826f3afa
10/11/16 22:15:23 |
Chris Johns |
libmisc/xz: Add xz decompression.
Add support to untar XZ compressed …
5
@be57318
09/23/16 04:45:07 |
Sebastian Huber |
score: More robust linker sets
Update #2408.
Update #2790.
5
@ed19002
10/12/16 08:37:07 |
Sebastian Huber |
smpschedaffinity05: Fix configuration
5
@475faef5
10/10/16 06:47:26 |
Sebastian Huber |
tmfine01: Add self-contained mutex test case
This demonstrates the …
5
@938ee19c
09/23/16 08:09:57 |
Sebastian Huber |
sptests/spsem03: Fix compile error
5
@f6142c19
09/09/16 09:00:06 |
Sebastian Huber |
score: Scheduler node awareness for thread queues
Maintain the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@6ae309ec
09/09/16 08:01:06 |
Sebastian Huber |
smptests/smpmutex01: Use test case functions
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@610b9ef1
09/19/16 05:51:07 |
Sebastian Huber |
libtests/devfs: Use printk()
This avoids problems with console …
5
@caf4064
09/16/16 12:54:12 |
Sebastian Huber |
fstests: Use printk() for IMFS configuration tests
This avoids …
5
@29770e12
09/16/16 12:21:30 |
Sebastian Huber |
tests: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
Avoid unnecessary use …
5
@a42be52
09/12/16 13:00:46 |
alexander.krutwig |
Add SPI bus framework
User API is compatible to Linux userspace API. …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@3709987
08/10/16 06:21:54 |
Sebastian Huber |
score: Add _Chain_Initialize_one()
5
@83b0229
06/28/16 04:59:29 |
Sebastian Huber |
score: Add _RBTree_Initialize_one()
5
@1c18ebf0
08/31/16 08:56:09 |
Chris Johns |
libmisc/capture: Remove the reserved _t in the types.
5
@6da06c5
08/30/16 06:46:25 |
Chris Johns |
libmisc/capture: Fix the capture engine on SMP.
This patches some …
5
@5d1fc66
08/12/16 13:54:46 |
Sebastian Huber |
psxtests: Adjust sporadic server tests
According to POSIX priority …
5
@381c42b
08/12/16 09:18:38 |
Chris Johns |
testsuite: Add libdl/dl04 cache test.
5
@97d395b
08/12/16 08:55:53 |
Chris Johns |
testsuite: Add libdl/dl03 cache test.
5
@55faa44
08/12/16 09:16:45 |
Sebastian Huber |
score: Improve _RBTree_Insert_inline()
Return if the inserted node is …
5
@03c1038
08/10/16 03:28:50 |
Chris Johns |
librtems++: Remove from RTEMS.
This is old and there are better …
5
@9a4eca5
08/10/16 03:07:29 |
Chris Johns |
build-system: Always enable C++ if the compiler is present.
We always …
5
@21d73655
08/10/16 07:54:13 |
Sebastian Huber |
sptests/splinkersets01: Fix for small-data area
5
@b0f08c8
08/01/16 01:02:13 |
Chris Johns |
libmisc/untar: Set the perms to the value in the tar file.
This patch …
5
@5c09e9d
08/08/16 07:47:06 |
Sebastian Huber |
sptests/splinkersets01: Fix warnings
5
@aaaf9610
08/08/16 06:44:51 |
Sebastian Huber |
score: Add debug support to red-black trees
This helps to detect …
5
@5fe6d07a
08/01/16 11:16:57 |
Christian.Mauderer |
linker set: Allow adding any variable into content
The newly created …
5
@d79df38
07/26/16 08:34:21 |
Sebastian Huber |
score: Add deadlock detection
The mutex objects use the owner field …
5
@1fcac5ad
07/25/16 14:35:37 |
Sebastian Huber |
score: Turn thread lock into thread wait lock
The …
5
@6a174c02
07/25/16 13:34:43 |
alexander.krutwig |
Add Untar_FromGzChunk_Print() + Test
5
@1a8fe67a
07/13/16 07:22:35 |
alexander.krutwig |
Add Untar_FromChunk_Print() + Test
5
@c1b815ab
07/26/16 07:26:19 |
Sebastian Huber |
sptests/spextensions01: Avoid NULL pointer access
5
@6e98ea91
06/09/16 15:40:35 |
Gedare Bloom |
posix: add clock_nanosleep and tests
updates #2732
5
@57a00bc6
07/05/16 09:30:14 |
Sebastian Huber |
smptests/smpmutex02: New test
Update #2765.
5
@0fd6f255
07/08/16 14:58:48 |
Sebastian Huber |
score: Relax thread begin extension environment
Update #2752.
5
@059529e
07/21/16 08:15:02 |
Sebastian Huber |
score: Add debug support to chains
* double …
5
@6f6cf785
07/05/16 07:04:15 |
Sebastian Huber |
score: Postpone SMP shutdown in _Terminate()
This enables fatal …
5
@2e3ba71
07/01/16 13:16:10 |
Sebastian Huber |
net: Fix byte order issue for getnameinfo()
5
@c0bd006
06/30/16 12:08:18 |
Sebastian Huber |
rtems: Fix rtems_task_set_scheduler() API
Task priorities are only …
5
@4280dff7
06/30/16 09:01:05 |
Sebastian Huber |
smptests/smpstrongapa01: Simplify
5
@4fe0e97f
06/30/16 07:50:41 |
Sebastian Huber |
smptests/smpstrongapa01: Add test cases
5
@195d412
05/02/16 12:49:33 |
libnetworking: Add minimal getnameinfo()
This implementation just …
5
@187a0744
05/02/16 12:49:35 |
libcsupport: Add dummy for setgroups().
The dummy for setgroups() …
5
@254dc82
06/24/16 09:22:03 |
Sebastian Huber |
score: Change Priority_Control to 64-bit
A 32-bit Priority_Control …
5
@9f61ad60
06/23/16 11:43:38 |
Sebastian Huber |
testsuites: Increase invalid priority values
Increase the invalid …
5
@50a56dff
06/24/16 09:16:35 |
Sebastian Huber |
score: Move SCHEDULER_EDF_PRIO_MSB
This is an implementation detail …
5
@b364d38
06/24/16 06:26:55 |
Sebastian Huber |
sptests/spintrcritical23: Explicity set scheduler
This test uses …
5
@b679b492
06/23/16 07:09:55 |
Sebastian Huber |
sptests/sp42: Relax priority requirements
5
@ec5d95e1
06/23/16 08:31:04 |
Sebastian Huber |
smptests/smpmrsp01: Fix due to API changes
Commit …
5
@9bfad8c
06/08/16 20:22:46 |
Sebastian Huber |
score: Add thread priority to scheduler nodes
The thread priority is …
5
@77ff5599
06/10/16 06:48:54 |
Sebastian Huber |
score: Introduce map priority scheduler operation
Introduce map/unmap …
5
@c82835a
06/21/16 15:12:40 |
Sebastian Huber |
rtems: Rework RTEMS API to SuperCore? priority
Use same structure as …
5
@ce6e9ec2
06/14/16 04:50:38 |
Sebastian Huber |
posix: pthread_mutexattr_setprioceiling()
Accept all priority values …
5
@3d9fd2ce
06/21/16 12:30:13 |
Sebastian Huber |
sptests/sp20: Use printer task
This avoids test failures due to slow …
5
@506bfc8
06/21/16 11:30:15 |
Sebastian Huber |
Move printer initialization to separate header
The RTEMS print user …
5
