source: rtems/testsuites
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @bcd0c06c   11/07/17 21:25:36 Chris Johns tests: Use rtems_test_begin and rtems_test_end. Add a tests enum and … 5
(edit) @6f3fb8a   11/07/17 05:43:11 Chris Johns cpukit: Add a Version API. Provide functions to get the version … 5
(edit) @748a126   11/09/17 21:06:19 joel pppd/Makefile.am: Add support/include 5
(edit) @4a147518   10/17/17 11:44:22 Sebastian Huber Upgrade to 5.0.0 Tool name will be "rtems5", e.g. arm-rtems5-gcc. … 5
(edit) @64ba1a96   11/08/17 14:29:14 Sebastian Huber posix: Change created_with_explicit_scheduler Remove … 5
(edit) @7147dc4   11/08/17 13:37:35 Sebastian Huber posix: Remove POSIX_API_Control::schedpolicy Use the thread CPU … 5
(edit) @8d0a0aa   11/03/17 20:16:09 Sebastian Huber sptests/spconsole01: New test 5
(edit) @791469bd   11/06/17 13:49:32 Sebastian Huber termios: Fix canonical mode In canonical mode, input is made … 5
(edit) @1055ff20   11/07/17 06:07:35 Sebastian Huber tests: Use normal console for user input tests 5
(edit) @32ceb385   11/07/17 07:30:59 Sebastian Huber tests: Use <tmacros.h> Update #3170. Update #3199. 5
(edit) @0c286e3   10/25/17 14:00:17 Sebastian Huber score: _Chain_Insert_ordered_unprotected() Change the chain order … 5
(edit) @7b00c2fa   11/06/17 06:56:17 Sebastian Huber tests: Use <tmacros.h> in all tests Update #3170. Update #3199. 5
(edit) @d71542c   11/06/17 08:05:30 Sebastian Huber fsjffs2gc01: Fix sporadic test failures 5
(edit) @c4b8b147   11/03/17 07:35:38 Sebastian Huber tests: Use simple console driver Update #3170. Update #3199. 5
(edit) @1082798   10/23/17 11:30:44 Sebastian Huber score: Add _IO_Printf() and _IO_Vprintf() The previous vprintk() … 5
(edit) @a54d10d   11/03/17 11:53:51 Sebastian Huber smpscheduler02: Avoid sporadic test failures 5
(edit) @3e81d52   10/29/17 19:29:05 Sebastian Huber posix: Use far future for very long timeouts Close #3205. 5
(edit) @8c1f4064   11/02/17 12:56:12 Sebastian Huber tests: Use printf() instead of fprintf() Update #3170. Update #3199. 5
(edit) @0d796d6   11/02/17 13:08:02 Sebastian Huber tests: Delete obsolete TESTS_USE_PRINTF Update #3170. Update #3199. 5
(edit) @81fd79d   10/27/17 06:52:41 Sebastian Huber smppsxaffinity02: Fix thread attribute usage The pthread_getattr_np() … 5
(edit) @2126438a   10/30/17 05:30:11 Chris Johns testsuite: Add bspIo for a local printk. Update #3170. Update #3199. 5
(edit) @af43554   10/26/17 11:59:11 Sebastian Huber tests: Remove TEST_INIT The TEST_EXTERN is a used only by the … 5
(edit) @acc9d064   10/26/17 11:59:10 Sebastian Huber tests: Remove obsolete TESTS_USE_PRINTK Update #3170. Update #3199. 5
(edit) @7e102915   10/26/17 11:59:09 Sebastian Huber tests: Use rtems_test_printer in general Update #3170. Update #3199. 5
(edit) @46ddc3c5   10/26/17 11:59:08 Sebastian Huber tests: Use rtems_print_printer_fprintf_putc() Use … 5
(edit) @73d892d8   10/26/17 11:59:07 Sebastian Huber tests: Use rtems_test_printer Update #3170. Update #3199. 5
(edit) @f703e7f   10/26/17 11:59:05 Sebastian Huber tests: Move rtems_test_printer definition Statically initialize it to … 5
(edit) @0719fc6   10/27/17 07:04:54 Sebastian Huber sptests/spscheduler01: Test POSIX set/get affinity 5
(edit) @8744498   10/27/17 07:04:53 Sebastian Huber score: Fix _Scheduler_Set_affinity() 5
(edit) @0f1fa19   10/26/17 11:19:57 Sebastian Huber smptests: Fix format warnings 5
(edit) @1510ce4   10/26/17 11:17:21 Sebastian Huber psxtests/psxstat: Fix format warnings 5
(edit) @b31ccb5   10/26/17 11:08:27 Sebastian Huber psxtests/psxclockrealtime01: Fix warnings Update #3182. 5
(edit) @e3ef14b   10/25/17 05:57:58 Sebastian Huber smptests: Remove duplicate Makefile targets Close #3187. 5
(edit) @34799c3b   10/24/17 07:35:06 Sebastian Huber rtems: rtems_clock_get_ticks_per_second() Add macro implementation … 5
(edit) @4c70110   10/24/17 21:32:53 Chris Johns testsuite: Fix build Updates #3170. 5
(edit) @c3105894   10/19/17 11:47:57 Sebastian Huber score: Move thread queue timeout handling Update #3117. Update #3182. 5
(edit) @cea5ff7   10/20/17 13:35:14 Sebastian Huber score: Add _Watchdog_Nanoseconds_per_tick Move it from the … 5
(edit) @7ed377b   10/20/17 06:43:15 Sebastian Huber score: _Watchdog_Is_far_future_monotonic_timespec Update #3117. … 5
(edit) @27cfe7c   10/20/17 06:31:36 Sebastian Huber score: Add _Watchdog_Ticks_per_second This value is frequently used. … 5
(edit) @d85c94c0   10/13/17 06:00:46 Sebastian Huber psxclockrealtime01: New test Update #3182. 5
(edit) @0e1ad7fa   10/24/17 07:27:06 Sebastian Huber tmtests/tmfine01: Reduce test context size Reduce test context size … 5
(edit) @88e84c22   10/23/17 11:48:56 Sebastian Huber testsuite: Fix build Updates #3170. 5
(edit) @36d974ba   10/22/17 22:57:52 Chris Johns testsuite: Remove warnings. 5
(edit) @98c6d50   10/19/17 05:39:16 Chris Johns testsuite: Use printk for all test output where possible. - Remove … 5
(edit) @a05861d   10/21/17 10:16:21 Sebastian Huber libtests/tar01: Fix build dependencies 5
(edit) @205d8d71   10/17/17 09:46:14 Christian.Mauderer sptests/sptimecounter04: New test Ensure that the time flow of … 5
(edit) @6087f33e   10/18/17 06:50:17 Sebastian Huber tmtests/tmfine01: Add test cases Update #2674. Update #3112. Update … 5
(edit) @3f3f4248   10/17/17 07:20:20 Sebastian Huber posix: Remove POSIX_API_Control::schedparam Move sporadic server … 5
(edit) @2fcea4c   10/17/17 08:06:08 Sebastian Huber posix: Fix _POSIX_Threads_Create_extension() The thread POSIX API … 5
(edit) @bf2a53d2   10/14/17 13:14:53 Sebastian Huber score: Rename watchdog variants Rename PER_CPU_WATCHDOG_RELATIVE in … 5
(edit) @6ba02954   10/12/17 17:56:06 joel spthreadq01/init.c: Fix unused variable warnings 5
(edit) @ee537ea   10/12/17 08:00:10 Sebastian Huber ada-tests: Move to testsuites/ada This solves a build dependency … 5
(edit) @14e5a08   10/12/17 02:32:32 joel Fix warnings for using C/ObjC specific GCC flags with C++ Closes #3181. 5
(edit) @871c23c   10/12/17 01:17:29 joel Fix spprofiling01 overriding recipe warning Closes #3084. 5
(edit) @16aaf73b   10/11/17 06:33:19 Sebastian Huber smpaffinity01: Fix test case Update #2514. 5
(edit) @b2dbb634   10/10/17 09:36:23 Sebastian Huber score: Remove CPU_set_Control Use Processor_mask instead. Update #2514. 5
(edit) @a3ad4af   10/10/17 09:22:21 Sebastian Huber posix: Validate affinity sets by the scheduler Update #2514. 5
(edit) @4f9ed26   10/10/17 05:13:37 Sebastian Huber posix: Constify default thread processor affinity Set default thread … 5
(edit) @8c5267a   10/10/17 05:11:29 Sebastian Huber posix: Simplify pthread_attr_setstack() Simplify * … 5
(edit) @da9f5f1   10/09/17 13:34:26 Sebastian Huber posix: Remove rtems_pthread_attribute_compare() Update #2514. Close #3174. 5
(edit) @af9115f3   10/06/17 08:07:38 Sebastian Huber posix: Simplify POSIX_API_Control Return stack area via … 5
(edit) @6489bcb   10/09/17 05:23:32 Sebastian Huber psxtests/psx05: Fix timeout calculation Update #3111. 5
(edit) @de59c065   09/27/17 13:08:33 Sebastian Huber posix: Implement self-contained POSIX mutex POSIX mutexes are now … 5
(edit) @5222488   09/26/17 05:49:17 Sebastian Huber posix: Implement self-contained POSIX condvar POSIX condition … 5
(edit) @89fc9345   09/21/17 13:42:45 Sebastian Huber posix: Implement self-contained POSIX rwlocks POSIX rwlocks are now … 5
(edit) @e67929c   09/21/17 12:13:16 Sebastian Huber posix: Implement self-contained POSIX barriers POSIX barriers are now … 5
(edit) @c090db7   09/12/17 06:09:16 Sebastian Huber posix: Implement self-contained POSIX semaphores For semaphore object … 5
(edit) @bdc468a   09/22/17 06:22:11 Sebastian Huber posix: Allow PTHREAD_PROCESS_SHARED for rwlocks Close #3153. 5
(edit) @714cb06   09/21/17 15:16:41 joel psxrdwrv/test.c: Clear iovec to ensure consistent results closes #3148. 5
(edit) @c030edd   09/15/17 11:48:44 Sebastian Huber posix: Allow PTHREAD_PROCESS_SHARED for condvar Close #3137. 5
(edit) @8230a329   09/15/17 11:24:51 Sebastian Huber posix: Allow PTHREAD_PROCESS_SHARED for barriers Close #3126. 5
(edit) @3b47ce73   09/15/17 11:14:57 Sebastian Huber posix: Allow PTHREAD_PROCESS_SHARED for mutexes Close #3125. 5
(edit) @ac74162   09/14/17 13:21:14 Sebastian Huber libio: Use FIFO for iop free list Update #3136. 5
(edit) @baef823c   09/13/17 07:22:19 Sebastian Huber libio: Add hold/drop iop reference Check iop reference count in … 5
(edit) @0169e90   09/13/17 06:55:05 Sebastian Huber libio: Do simple parameter checks early This simplifies error … 5
(edit) @62f3fa84   09/13/17 13:18:16 Sebastian Huber fstests/fsimfsgeneric01: Fix test assert 5
(edit) @18b32d76   09/08/17 13:25:47 Sebastian Huber posix: Ignore pshared for semaphores Since we have only one process, … 5
(edit) @fae59c9   09/06/17 08:12:06 Sebastian Huber dosfs: Support a cluster size of 64KiB Close #3003. 5
(edit) @d85d2676   08/27/17 19:11:43 joel psxconfig01/init.c: Fix printf() format warnings 5
(edit) @8b29f9b9   08/27/17 19:11:24 joel sp25/task1.c: Fix printf() format warnings 5
(edit) @37f0023f   08/27/17 19:09:34 joel spstkalloc02/init.c: Fix printf() format warnings 5
(edit) @02b007e   08/25/17 12:39:38 Sebastian Huber Include missing <limits.h> Update #2132. 5
(edit) @80a13ec4   08/24/17 06:42:57 Sebastian Huber samples/fileio: Give command availability hint Close #3088. 5
(edit) @a8f4fd2   08/10/17 12:29:55 Sebastian Huber smptests: Fix format specifier Update #3082. 5
(edit) @3ebbabb   07/28/17 20:53:21 joel psximfs02/init.c: Increase size of buffer to avoid overwrite 5
(edit) @bed7ec1   07/28/17 16:21:18 joel psxmmap01/init.c: Correct printf() format specifier 5
(edit) @77cbb2a   07/28/17 11:53:18 Sebastian Huber psxtests/psxmmap01: Fix warning Update #2859. 5
(edit) @9d1522ed   07/28/17 11:25:25 Sebastian Huber Fix IO control request type 5
(edit) @7f1e6fa   07/28/17 10:19:05 Sebastian Huber libtests/block08: Fix format warning 5
(edit) @3fd0197   07/27/17 22:29:24 joel psxmmap01/test_helper.c: Use correct printf format for size_t 5
(edit) @3a3d85c   07/27/17 22:29:02 joel psxmmap01/test_driver.c: Fix mmap_h handler type mismatch 5
(edit) @146adb1   07/17/17 05:30:46 Sebastian Huber sparc: Add lazy floating point switch The SPARC ABI is a bit special … 5
(edit) @600d88d   07/19/17 07:07:17 Sebastian Huber INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT Add new fatal error … 5
(edit) @1c256e6   07/20/17 09:32:53 Sebastian Huber tmtests/tmcontext01: Prevent GCC 7.1 optimizations It is getting … 5
(edit) @5f1ae90e   07/19/17 14:00:48 Sebastian Huber sptests/sptls02: Use standard test IO Update #3076. 5
(edit) @0ea7ca9   07/19/17 13:51:28 Sebastian Huber sptests/spcache01: Use standard test IO Update #3076. 5
(edit) @a0271a7   07/19/17 13:50:57 Sebastian Huber tests: Use floating point task These tests directly or indirectly use … 5
(edit) @96ce1ec   07/19/17 11:03:13 Sebastian Huber smptests/smpscheduler02: Remove invalid assert Update #3059. 5
(edit) @7ad8239   07/19/17 10:58:55 Sebastian Huber smptests/smpscheduler01: Use right scheduler Update #3063. 5
(edit) @6f46848   07/19/17 09:57:01 Sebastian Huber tests: Use floating point task These tests directly or indirectly use … 5
