@a1b4af4b
07/20/15 07:05:30 |
Sebastian Huber |
score: Add scheduler <sys/lock.h> support
5
@40188718
07/13/15 08:00:28 |
Sebastian Huber |
score: Add self-contained futex implementation
5
@7237b3e
07/02/15 11:12:38 |
Sebastian Huber |
score: Add self-contained semaphore implementation
5
@214d8ed
06/28/15 20:06:36 |
Sebastian Huber |
score: Add self-contained mutex implementation
This mutex …
5
@08135c85
07/23/15 07:00:31 |
Sebastian Huber |
i2c: Fix return status of i2c dev read/write
5
@d7665823
06/24/15 13:43:19 |
Sebastian Huber |
score: Introduce Thread_queue_Heads
Move the storage for the thread …
5
@e2735012
06/24/15 09:05:39 |
Sebastian Huber |
score: Introduce Thread_queue_Queue
Separate the thread queue heads …
5
@9341773
07/11/15 20:04:32 |
Sebastian Huber |
score: Typo
4.115
@f59f2fe9
06/25/15 04:50:04 |
Sebastian Huber |
score: Accept NULL pointer in _Freechain_Put()
With this a …
4.115
@fdb45d6
06/24/15 12:00:08 |
Sebastian Huber |
score: Freechain handler API changes
Replace the extend function with …
4.115
@d811dac
06/25/15 09:24:44 |
Sebastian Huber |
score: Hide SMP lock profiling impl if disabled
The problem is that …
4.115
@5f31bbe
06/25/15 12:22:31 |
Sebastian Huber |
libmisc: Simplify <rtems/stackchk.h>
Drop the <rtems/score/percpu.h> …
4.115
@cdf30f05
06/19/15 12:57:44 |
Sebastian Huber |
rtems: Add rtems_interrupt_local_disable|enable()
Add …
4.115
@f9090ac
06/19/15 19:38:20 |
Sebastian Huber |
tmtests/tm27: Use scheduler lock
4.115
@f22af606
06/19/15 19:17:55 |
Sebastian Huber |
sptests/sp37: Fix type and simplify
4.115
@e6b31b27
05/27/15 15:13:58 |
Joel Sherrill |
Remove use ticks for statistics configure option.
This was obsolete …
4.115
@80fca28
06/13/15 13:29:04 |
Sebastian Huber |
score: Add _Watchdog_Preinitialize()
Add an assert to ensure that the …
4.115
@0562060
06/12/15 11:57:15 |
Sebastian Huber |
sptests/sptasknopreempt01: New test
Update #2365.
4.115
@2ccd150d
06/02/15 19:41:26 |
Sebastian Huber |
sptests/sptimecounter03: New test
4.115
@b88d346f
06/09/15 07:28:36 |
Sebastian Huber |
sptests/spcontext01: Add second volatile clobber
Do a volatile …
4.115
@b2765075
06/03/15 08:07:23 |
Sebastian Huber |
sptests/spcontext01: Improve output
4.115
@43d7005
06/02/15 12:32:58 |
Sebastian Huber |
smptests/smpscheduler02: Reduce required CPU count
4.115
@2c14e67
06/02/15 12:22:03 |
Sebastian Huber |
smptests/smpmrsp01: Reduce required CPU count
4.115
@f48b73de
06/02/15 12:10:05 |
Sebastian Huber |
smptests/smpscheduler03: Use proper lock
4.115
@18d18e1
05/29/15 19:20:31 |
Sebastian Huber |
tmtests/tm26: Fix context switch to FP task
It is wrong to restore …
4.115
@b17fb17a
05/29/15 15:51:38 |
Sebastian Huber |
Revert "tmtests/tm26: Avoid NULL pointer access"
There is no NULL …
4.115
@5611839
05/29/15 12:18:32 |
Sebastian Huber |
4.115
@9d0913d1
05/27/15 10:48:22 |
Sebastian Huber |
libtests/i2c01: Avoid stack overflow
4.115
@ec84273d
05/27/15 09:43:44 |
Sebastian Huber |
score: Replace _API_Mutex_Is_locked()
Replace _API_Mutex_Is_locked() …
4.115
@ee4e7f0
05/26/15 13:17:50 |
Sebastian Huber |
jffs2: Move into separate library
In case the zlib compression was …
4.115
@cba07fc
05/19/15 12:40:17 |
alexander.krutwig |
sptests/spcontext01: Test deferred FP context
4.115
@7cd2484
05/12/15 12:32:47 |
alexander.krutwig |
timecounter: Use in RTEMS
Replace timestamp implementation with …
4.115
@31be416
04/20/15 09:08:22 |
alexander.krutwig |
timecounter: Port to RTEMS
New test sptests/timecounter01.
Update #2271.
4.115
@33e30f39
05/12/15 08:15:21 |
Sebastian Huber |
smptests/smpscheduler03: Restructure
Restructure to avoid large …
4.115
@20b423c6
05/11/15 13:02:51 |
Sebastian Huber |
psxualarm: Avoid endless signal handling
Increase the ualarm timer …
4.115
@d8752860
05/11/15 12:56:12 |
Sebastian Huber |
score: Add static initializers for thread queues
4.115
@80f376d
05/06/15 12:25:09 |
Sebastian Huber |
score: Remove Giant lock in rtems_clock_tick()
Update #2307.
4.115
@900d337f
05/05/15 11:05:54 |
Sebastian Huber |
score: Rework _Thread_Change_priority()
Move the writes to …
4.115
@cc366ec
04/24/15 10:02:20 |
Sebastian Huber |
score: New thread queue implementation
Use thread wait flags for …
4.115
@568af83
04/21/15 08:17:13 |
Sebastian Huber |
score: Add Thread_queue_Operations
Replace the …
4.115
@08fe84b
04/22/15 08:06:05 |
Sebastian Huber |
score: Generalize _Event_Timeout()
Add a thread wait timeout code. …
4.115
@b7cff7fe
04/26/15 13:22:20 |
Sebastian Huber |
score: Reduce thread wait states
Merge THREAD_WAIT_STATE_SATISFIED, …
4.115
@a382010c
04/10/15 13:31:31 |
Sebastian Huber |
score: New timer server implementation
Use mostly the standard …
4.115
@1ccbd052
04/15/15 08:53:29 |
Sebastian Huber |
score: Add Watchdog_Iterator
Rewrite the _Watchdog_Insert(), …
4.115
@2903090
04/15/15 09:26:46 |
Sebastian Huber |
score: Add header to _Watchdog_Remove()
Add watchdog header parameter …
4.115
@22788bc
04/23/15 11:01:05 |
Sebastian Huber |
score: _Thread_queue_Extract()
Remove thread queue parameter from …
4.115
@b1b5ddf0
05/15/15 11:17:16 |
Sebastian Huber |
smptests/smpcache01: Restructure
Restructure to avoid large maximum …
4.115
@be0366b
05/10/15 19:30:26 |
Sebastian Huber |
score: Fix scheduler helping protocol
Account for priority changes of …
4.115
@5b9dfff5
05/06/15 14:39:12 |
alexander.krutwig |
sptests/spcontext01: Check FPU task combinations
4.115
@40d24d5
04/26/15 18:26:50 |
Sebastian Huber |
sptests/spstkalloc02: Fix namespace issue
Avoid collision with …
4.115
@694f155
04/22/15 14:10:24 |
Joel Sherrill |
sp13/system.h: Account for all message buffers
There may be a way to …
4.115
@9f10911
04/22/15 19:29:21 |
Sebastian Huber |
score: Delete Thread_queue_Control::state
Use a parameter for …
4.115
@36413201
04/22/15 07:22:27 |
cederman |
smptests/smpcache01: Enable interrupts before waiting for other CPUs
4.115
@1041de1
04/20/15 07:45:10 |
Sebastian Huber |
score: Add _Thread_Get_interrupt_disable()
Remove _Thread_Acquire() …
4.115
@1981b469
04/19/15 08:27:08 |
Sebastian Huber |
score: Add _ISR_lock_ISR_disable/enable()
4.115
@26c142e5
04/17/15 10:05:16 |
Sebastian Huber |
score: Refactor SMP cache manager support
4.115
@491434cd
04/15/15 19:39:56 |
Joel Sherrill |
sp13: Document message buffer usage and adjust configuration
4.115
@b8cdc38b
04/17/15 08:46:02 |
Sebastian Huber |
sptests/sp52: Reduce clock tick interval
This helps on slow simulators.
4.115
@a211a732
04/16/15 20:24:59 |
Sebastian Huber |
score: Fix _TOD_Set_with_timestamp()
Update the current time before …
4.115
@ab69324
04/16/15 18:29:29 |
Sebastian Huber |
sptests/sp68: Avoid use of internal variables
4.115
@e98df4d
04/16/15 09:23:29 |
Sebastian Huber |
score: Add _ISR_lock_Flash()
4.115
@b1debed0
04/14/15 20:00:57 |
Joel Sherrill |
spcpuset01: Reduce output to reduce run-time
4.115
@351858d
04/14/15 19:07:35 |
Joel Sherrill |
sp13: Update configuration to account for messages on fourth message queue
4.115
@fc0756e
04/14/15 15:01:05 |
Joel Sherrill |
Add test assertion for allocator mutex being unlocked
The Allocator …
4.115
@54cf0e34
04/10/15 14:19:48 |
Sebastian Huber |
score: Add Watchdog_Header
This type is intended to encapsulate all …
4.115
@edcf89b
03/27/15 20:08:21 |
Sebastian Huber |
rtems: Atomically suspend/resume tasks
4.115
@f820f22c
04/08/15 05:46:10 |
Sebastian Huber |
fstests/fsfseeko01: Fix for long == off_t
Close #2317.
4.115
@7824d15
03/31/15 22:45:06 |
Joel Sherrill |
disable-intrcritical-tests.tcfg: New file
This file contains the list …
4.115
@2da28d2
03/31/15 13:14:28 |
alexander.krutwig |
psxtmtests: Use timeout in more distant future
Adds future …
4.115
@15031660
03/31/15 13:14:27 |
alexander.krutwig |
fstests: Increase stack size for symlink loop test
4.115
@260cfe0
03/31/15 13:14:26 |
alexander.krutwig |
fstests/fssymlink: Typo
4.115
@7790fec1
03/31/15 06:04:35 |
Chris Johns |
testsuites: dl02 needs an FPU init task.
4.115
@e7e86ba
03/25/15 08:50:59 |
Sebastian Huber |
smpmigration01: Delete timing dependent assert
The cycles per runner …
4.115
@4f10ed6
03/24/15 12:42:08 |
Sebastian Huber |
smptests/smpfatal08: Workaround for QorIQ BSPs
4.115
@2e9c3d5
03/17/15 15:28:50 |
Sebastian Huber |
score: Add thread priority change handler
Since the thread current …
4.115
@dd23125
03/22/15 14:43:23 |
Joel Sherrill |
testsuites/sptests/sp54/init.c: Add cast to avoid warning
4.115
@d05d31f
03/22/15 14:43:07 |
Joel Sherrill |
samples/minimum/init.c: Add cast to avoid warning
4.115
@5da717a
03/20/15 22:56:56 |
Joel Sherrill |
sptls03/init.c: Make type and constants uint32_t to avoid overflow warnings
4.115
@dc8ab440
03/21/15 19:45:10 |
Joel Sherrill |
sptls01/init.c: Use larger data types for values
4.115
@73a2caf
03/20/15 15:50:13 |
Joel Sherrill |
sptests/spwatchdog/init.c: Avoid integer overflow
4.115
@2fe0f16d
03/20/15 15:49:06 |
Joel Sherrill |
sptests/spedfsched02: Reduce stack space usage to fix on smaller targets
4.115
@c6ef870
03/20/15 15:48:32 |
Joel Sherrill |
sptests/spatomic01/init.c: Avoid integer overflow
4.115
@70757114
03/20/15 15:47:59 |
Joel Sherrill |
sptests/sp34/changepri.c: Correct printf() warning
4.115
@6c1aff66
03/20/15 15:47:41 |
Joel Sherrill |
sptests/sp33/init.c: Correct printf() warning
4.115
@6849e53
03/21/15 19:43:47 |
Joel Sherrill |
sptests/sp20: Reduce memory requirements
This was checked on …
4.115
@2be0342
03/20/15 15:47:14 |
Joel Sherrill |
sptests/sp13/system.h: Fine tune message buffer configuration to avoid …
4.115
@52a34a7
03/20/15 15:46:18 |
Joel Sherrill |
sptests/sp12/pritask.c: Correct printf() warning
4.115
@ab90136b
03/20/15 15:45:55 |
Joel Sherrill |
psxconfig01/init.c: Correct pointer/integer size warning
4.115
@278da87
03/20/15 15:45:28 |
Joel Sherrill |
psxtests/psx15/init.c: Correct printf() warning
4.115
@59efbdd4
03/22/15 19:59:52 |
Joel Sherrill |
malloctest/init.c: Fix use uninitialized warning
4.115
@e0437fe
03/20/15 15:38:44 |
Joel Sherrill |
testsuites/psxtests/psxsignal03/init.c: Fix line wrap
4.115
@f061f2f
03/19/15 17:29:17 |
Joel Sherrill |
testsuites/testdata: Add sets to disable all jffs2 and mrfs tests
4.115
@a6524b9
03/22/15 13:31:59 |
Sebastian Huber |
score: Simplify debug code and use _Assert()
4.115
@40a24661
03/21/15 19:14:45 |
Sebastian Huber |
sptests/spintrcritical23: Fix warnings
4.115
@d4edbdbc
03/20/15 13:09:26 |
Sebastian Huber |
Replace www.rtems.com with www.rtems.org
4.115
@6a941e3
03/17/15 15:24:44 |
Sebastian Huber |
score: Fix _Thread_Change_priority()
Atomically update the current …
4.115
@72d3f1a6
03/15/15 15:31:01 |
Joel Sherrill |
spcbssched03/tasks_periodic.c: Fixed now used before set warning
4.115
@3c69c467
03/14/15 16:08:01 |
Joel Sherrill |
sptests misc: Update to not use deprecated methods
4.115
@e334edd
03/14/15 15:52:24 |
Joel Sherrill |
tests misc: Disable deprecated method usage warning when intentional
4.115
@979bda9
03/14/15 15:48:00 |
Joel Sherrill |
tm07: Split some code into new spnotepad02.
Use of deprecated …
4.115
