@93306058
05/27/16 12:43:19 |
Sebastian Huber |
score: _CORE_mutex_Check_dispatch_for_seize()
Move the safety check …
5
@0e1d11f3
05/27/16 11:26:53 |
Sebastian Huber |
score: Add _Thread_queue_Context_set_MP_callout()
Add …
5
@dce48791
05/23/16 11:37:59 |
Sebastian Huber |
score: Add Status_Control for all APIs
Unify the status codes of the …
5
@d887c1b
05/25/16 12:28:34 |
Sebastian Huber |
posix: Fix sem_init() with too large initial value
Close #2721.
5
@39bcf741
05/25/16 12:23:48 |
Sebastian Huber |
Fix semaphore post overflow status
Close #2720.
5
@dbedcf9
05/26/16 19:40:34 |
Sebastian Huber |
testsuites: Fix locked_printf() test printer
5
@3039e18
05/26/16 05:51:44 |
Chris Johns |
testsuite: Fix networking samples to use the RTEMS printer.
5
@9ec7d492
05/25/16 06:37:28 |
Sebastian Huber |
posix: Fix pthread_spin_unlock() error status
Close #2719.
5
@631b3c8
05/23/16 09:40:18 |
Sebastian Huber |
score: Move thread queue MP callout to context
Drop the …
5
@addf1aa
05/23/16 05:29:49 |
Chris Johns |
testsuite: Fix printk format warnings.
5
@61ea345
05/23/16 05:24:43 |
Chris Johns |
testsuite: Fix printk formating warning.
5
@24d0ee57
05/20/16 08:39:50 |
Chris Johns |
cpukit, testsuite: Add rtems_printf and rtems_printer support.
This …
5
@b1860df5
05/24/16 13:39:07 |
Sebastian Huber |
psxtests/psxmsgq01: Fix typo
5
@4b623d65
05/24/16 05:40:18 |
Sebastian Huber |
score: Fix blocking _CORE_message_queue_Submit()
Close #2718.
5
@7088340
05/24/16 12:18:16 |
Sebastian Huber |
psxtests/psxmsgq01: Enable test case
5
@e266d13
05/20/16 13:10:27 |
Sebastian Huber |
Replace *_Get_interrupt_disable() with *_Get()
Uniformly use *_Get() …
5
@62c528e6
05/20/16 12:59:30 |
Sebastian Huber |
rtems: _Semaphore_Get_interrupt_disable()
Use _Objects_Get_local() …
5
@ceb0f659
05/17/16 14:03:46 |
Sebastian Huber |
score: Remove the Giant lock
Update #2555.
5
@c2f301b5
05/18/16 06:08:38 |
Sebastian Huber |
score: Rename _ISR_Flash() into _ISR_Local_flash()
This is a …
5
@24713163
05/18/16 06:06:54 |
Sebastian Huber |
score: Rename _ISR_Disable() and _ISR_Enable()
Rename _ISR_Disable() …
5
@4b04cb61
05/18/16 06:03:05 |
Sebastian Huber |
score: Rename _ISR_Disable_without_giant()
Rename …
5
@dab902d5
05/17/16 13:43:31 |
Sebastian Huber |
testsuites: Avoid Giant lock
Replace _Thread_Disable_dispatch() with …
5
@5eac9676
05/17/16 12:54:48 |
Sebastian Huber |
testsuites: Replace _Thread_Get()
Replace _Thread_Get() with …
5
@92f68830
05/17/16 12:48:46 |
Sebastian Huber |
sptests/spintrcritical22: Avoid _Objects_Get()
Use …
5
@33829ce
05/13/16 12:07:23 |
Sebastian Huber |
score: Avoid Giant lock for _Thread_Start()
Update #2555.
5
@9949d8a7
05/12/16 14:32:27 |
Sebastian Huber |
score: Add Thread_Change_life()
Add _Thread_Change_life_locked() as a …
5
@12a1228c
05/17/16 15:23:44 |
Sebastian Huber |
psxclassic01: Assume correct pthread_detach()
Update #2714.
5
@41ce30a
05/18/16 12:34:26 |
Sebastian Huber |
SMP: Add Mellor-Crummey and Scott (MCS) lock
Added only for …
5
@ae0f048
05/18/16 09:09:10 |
Sebastian Huber |
psxtests/psxualarm: Avoid output in signal handler
Avoid output in …
5
@3c20d28
05/17/16 11:39:15 |
Sebastian Huber |
posix: Fix return states of pthread_kill()
POSIX mandates that an …
5
@9d8ee11
05/17/16 07:47:53 |
Sebastian Huber |
psxtests/psxcancel: Add pthread_detach() tests
Update #2714.
5
@f014f84
05/17/16 07:41:34 |
Sebastian Huber |
psxtests/psxcancel: Add resource check
5
@adc819ef
05/17/16 05:36:27 |
Sebastian Huber |
sptests/spthreadlife01: Add self delete test case
5
@9fd7271
05/13/16 12:59:31 |
Sebastian Huber |
posix: Fix return status of pthread_cancel()
POSIX recommends ESRCH …
5
@1379d84
05/12/16 08:57:15 |
Sebastian Huber |
smptests/smpcapture02: Adjust for clock changes
Fix overall clock …
5
@bd12dda
05/11/16 09:54:49 |
Sebastian Huber |
score: Use thread state lock for current state
In addition protect …
5
@9276fde
05/11/16 15:52:13 |
Sebastian Huber |
score: Fix CORE mutex initialization
The priority inheritance and …
5
@876dde7a
05/03/16 07:19:59 |
Sebastian Huber |
score: Make _Objects_Information_table const
The …
5
@1d40d81b
05/03/16 05:38:19 |
Sebastian Huber |
rtems: Remove task variables
Update #2494.
Update #2555.
5
@e4fd35d
05/03/16 10:55:00 |
Sebastian Huber |
confdefs.h: Fix named object size estimate
Account for the …
5
@981eed2
04/29/16 10:09:32 |
Sebastian Huber |
score: Add dummy Strong APA scheduler
Start with a copy of the …
5
@500a8e9c
04/28/16 04:26:01 |
Sebastian Huber |
score: Delete RTEMS_STRICT_ORDER_MUTEX
Remove support for strict …
5
@f009ed0
04/27/16 14:36:04 |
Sebastian Huber |
rtems: Avoid Giant lock for semaphores
Update #2555.
5
@c8982e5
04/26/16 19:20:31 |
Sebastian Huber |
posix: Simplify message queues
The mq_open() function returns a …
5
@b466226
04/20/16 04:57:47 |
Sebastian Huber |
score: Add _Thread_queue_Is_empty()
5
@36cd27c
04/19/16 12:12:06 |
Sebastian Huber |
score: Simplify _Objects_Get_next()
Remove unused location parameter.
5
@f05eeb2
04/19/16 11:39:00 |
Sebastian Huber |
score: Simplify _Objects_Initialize_information()
Remove unused …
5
@48b04fc3
04/19/16 04:28:03 |
Sebastian Huber |
posix: Avoid Giant lock for mutexes
Delete _POSIX_Mutex_Get(). Use …
5
@90f1265e
04/18/16 04:23:27 |
Sebastian Huber |
score: Fix _CORE_semaphore_Flush()
Use proper CORE_semaphore_Status …
5
@bdf6cc2
04/20/16 12:00:44 |
Sebastian Huber |
sptests/spsysinit01: Fix warning
5
@4cf41fd
04/20/16 16:00:57 |
joel |
block[08|09|10]/init.c: Include <stdlib.h> to fix warning on exit()
5
@709f38a
04/13/16 04:48:58 |
Sebastian Huber |
score: Use chain iterator for user extensions
Add a lock and use a …
5
@8f6c295b
04/11/16 15:03:05 |
Sebastian Huber |
score: Add Chain_Iterator
Add a chain iterator for safe iteration of …
5
@e65c45c
03/22/16 22:13:30 |
joel |
Obsolete rtems_clock_get() directive.
This service was marked as …
5
@8228548
02/19/16 22:00:48 |
joel |
Add pthread_getconcurrency() and pthread_setconcurrency()
This is the …
5
@6efa349
04/14/16 06:56:53 |
Sebastian Huber |
posix: Run key destructors during thread restart
POSIX key …
5
@d7e68c96
04/06/16 11:50:16 |
Sebastian Huber |
malloc: Fix early realloc() allocation
5
@84f5c0a
04/04/16 07:42:15 |
Sebastian Huber |
score: Use red-black tree for active global objects
Use a red-black …
5
@84dc9df
04/04/16 04:17:36 |
Sebastian Huber |
score: Use red-black tree for active MP proxies
Update #2555.
5
@97312fcc
04/05/16 12:36:30 |
Sebastian Huber |
score: Delete Thread_Wait_information::id
This field was only by the …
5
@d4771e6
03/29/16 11:20:15 |
Sebastian Huber |
mptests: Fix message queue configuration
5
@a8ac273c
03/24/16 07:40:19 |
Sebastian Huber |
samples/base_mp: Check directive status
5
@1e1a91ed
03/23/16 09:01:31 |
Sebastian Huber |
score: Remove Thread_queue_Queue::operations field
Remove the …
5
@596bfe3b
03/21/16 00:43:23 |
joel |
mptests/*/*.c: Fix warnings
5
@b66394d
03/22/16 15:17:41 |
joel |
sp13/task1.c: Remove warning for misleading indentation
Fix a block …
5
@9e2acee
03/22/16 07:24:45 |
Sebastian Huber |
psxtests/psxobj01: Fix for RTEMS_DEBUG
5
@90960bd
03/21/16 14:01:57 |
Sebastian Huber |
rtems: Rework rate-monotonic scheduler
Use the default thread lock to …
5
@c904df5
03/18/16 06:25:23 |
Sebastian Huber |
score: Add _Objects_Get_by_name()
Replace …
5
@1f0e652a
03/18/16 14:31:28 |
Sebastian Huber |
sptests/sptls02: Use GNU++11
This avoids a problem with the feature …
5
@474b9be
03/15/16 14:42:57 |
Sebastian Huber |
score: Use allocator lock in _Objects_Get_next()
Use the object …
5
@18ff889
03/14/16 09:11:38 |
Sebastian Huber |
score: Use ISR lock for IO driver registration
Create implementation …
5
@354064b
03/07/16 14:24:19 |
Sebastian Huber |
libtests/syscall01: Explicitly request close
This makes the test more …
5
@03b900d
02/18/16 07:36:26 |
Sebastian Huber |
score: Replace watchdog handler implementation
Use a red-black tree …
5
@b3a4c48e
02/17/16 13:27:09 |
Sebastian Huber |
score: Add _SMP_Online_processors
5
@eead8f7
03/02/16 14:28:29 |
Sebastian Huber |
smptests/smpmrsp01: Fix test context
5
@f831eff
03/02/16 07:07:58 |
Sebastian Huber |
tmtests/tmtimer01: New test
Test run performed on T4240 running at …
5
@1db9567
03/01/16 14:00:43 |
Sebastian Huber |
sptests/spsysinit01: Fix for RTEMS_DEBUG
Update #2408.
5
@9d1f3943
02/25/16 08:02:43 |
Sebastian Huber |
malloc: Add _Malloc_System_state()
Replace …
5
@5d478af
02/22/16 08:40:16 |
Sebastian Huber |
psxtests/psxualarm: Add test cases
Update #2344.
5
@452f6ba9
02/22/16 08:15:45 |
Sebastian Huber |
psxtests/psxalarm01: Add adjtime() test case
Update #2606.
5
@5774b752
02/22/16 05:55:27 |
Sebastian Huber |
sptests/sp65: Fix test names
5
@10f28914
02/17/16 10:33:27 |
Sebastian Huber |
smptests/smpwakeafter01: Add scheduler config
Update #2554.
5
@3bc12a8f
01/26/16 10:16:56 |
Sebastian Huber |
Delete unused API extensions
5
@4210114
01/26/16 10:13:45 |
Sebastian Huber |
Use linker set for POSIX User Threads init
Update #2408.
5
@1ff8eca
01/26/16 10:10:43 |
Sebastian Huber |
Use linker set for Classic User Tasks init
Update #2408.
5
@8ca372e
01/26/16 09:11:48 |
Sebastian Huber |
Use linker set for MPCI initialization
Update #2408.
5
@ca4602e
01/25/16 21:03:00 |
Sebastian Huber |
Use linker set for libio initialization
Update #2408.
5
@3d36164f
01/25/16 20:18:41 |
Sebastian Huber |
Use linker set for root file system initialization
Update #2408.
5
@2605a489
12/15/15 08:32:55 |
Sebastian Huber |
Optional POSIX Keys initialization
Update #2408.
5
@190169fe
12/10/15 14:30:41 |
Sebastian Huber |
Optional CPU Set Handler initialization
Update #2408.
5
@4eee8781
12/14/15 15:40:28 |
Sebastian Huber |
Optional POSIX Spinlock initialization
Update #2408.
5
@76a8328
12/14/15 15:39:10 |
Sebastian Huber |
Optional POSIX RWLock initialization
Update #2408.
5
@e4e7f14
12/14/15 15:37:34 |
Sebastian Huber |
Optional POSIX Barrier initialization
Update #2408.
5
@6c678557
12/14/15 15:36:21 |
Sebastian Huber |
Optional POSIX Timer initialization
Update #2408.
5
@2189b3e
12/14/15 15:34:50 |
Sebastian Huber |
Optional POSIX Semaphore initialization
Update #2408.
5
@3015ed64
12/14/15 15:33:39 |
Sebastian Huber |
Optional POSIX Message Queue initialization
Update #2408.
5
@9871f5dc
12/14/15 15:31:44 |
Sebastian Huber |
Optional POSIX Mutex initialization
Update #2408.
5
@f4fee477
12/14/15 15:29:19 |
Sebastian Huber |
Optional POSIX Condition Variable initialization
Update #2408.
5
@cef5675
12/14/15 10:47:47 |
Sebastian Huber |
Optional POSIX Cleanup initialization
Update #2408.
5
@ef1a985f
12/11/15 09:47:22 |
Sebastian Huber |
Optional POSIX Threads initialization
Update #2408.
5
