@87c8d8ab
05/23/12 14:45:01 |
Ralf Corsepius |
Revert "libtests/math*: Avoid generated files"
This reverts commit …
4.115
@0c2d8ec
05/23/12 14:44:33 |
Ralf Corsepius |
Revert "libtests/complex: Avoid generated files"
4.115
@6a5bd1c
05/22/12 08:49:21 |
Sebastian Huber |
Use C pre-processor instead of …
4.115
@a80a108
05/21/12 14:42:28 |
Sebastian Huber |
Use C pre-processor instead …
4.115
@e7cf654
05/18/12 09:20:54 |
Ralf Corsepius |
Add missing )
4.115
@6963854d
05/18/12 05:47:52 |
Ralf Corsepius |
Remove references to configure.in.
4.115
@cf65bb00
05/18/12 05:37:45 |
Ralf Corsepius |
Remove obsolete reference to posix bsp.
4.115
@bbb69abb
05/18/12 05:24:47 |
Ralf Corsepius |
Remove stray dnl.
4.115
@50262970
05/16/12 10:09:56 |
Sebastian Huber |
libcsupport: Adjust malloc_walk() prototype
The header file …
4.115
@da154e14
05/14/12 14:55:41 |
Sebastian Huber |
Filesystem: Move operations to mount table entry
The scope of the …
4.115
@df01da67
05/14/12 11:16:31 |
Sebastian Huber |
Filesystem: Use ioctl_command_t
4.115
@3c462734
05/14/12 10:13:04 |
Sebastian Huber |
libblock: Fix purge device tree traversal
4.115
@6c2de60
05/11/12 19:12:11 |
Joel Sherrill |
psxtests - Eliminate missing prototype warnings
4.115
@4c86e3d
05/11/12 17:20:47 |
Joel Sherrill |
libtmtests - Eliminate missing prototype warnings
4.115
@a03d4453
05/11/12 14:25:49 |
Joel Sherrill |
tmoverhd - Eliminate warnings
4.115
@991a3cc1
05/11/12 14:15:40 |
Joel Sherrill |
psxtmtests - Eliminate missing prototype warnings
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@b16b0aa9
05/11/12 11:19:45 |
Sebastian Huber |
fstests/fsrdwr: Add block read/write test case
4.115
@a26ea56d
05/11/12 11:19:14 |
Sebastian Huber |
fstests/fsrdwr: Add truncate to zero test case
4.115
@be366508
05/11/12 11:23:11 |
Sebastian Huber |
fstests/fsrdwr: Fix assertions
4.115
@25f814c
05/11/12 11:22:48 |
Sebastian Huber |
fstests/fsrdwr: Avoid copy and paste
4.115
@86ef0df
05/09/12 12:33:51 |
Sebastian Huber |
dosfs: Remove fat_file_datasync()
The fat_file_datasync() read every …
4.115
@d61b0a5
05/07/12 14:15:57 |
Sebastian Huber |
Filesystem: PR1871: Fix O_APPEND
4.115
@30d4124
05/07/12 14:30:37 |
Sebastian Huber |
Filesystem: PR1398: Fix lseek() mechanic
According to POSIX the …
4.115
@c100ba13
05/08/12 21:39:30 |
Joel Sherrill |
spqreslib - Make global data extern in system.h
Global data was …
4.115
@f53aa8d
05/03/12 16:43:29 |
Gedare Bloom |
rbtree: API changes. Remove rbtree control node from RBTree_Next.
The …
4.115
@865bffd1
05/07/12 21:57:35 |
Joel Sherrill |
tm30 - Fix warning for Init needed prototype
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@333a312
05/04/12 20:14:34 |
Joel Sherrill |
samples/base_mp - Makefile.am did not set LINK_OBJS
LINK_OBJS =
4.115
@48e02af
05/04/12 19:58:21 |
Joel Sherrill |
mptests - Makefile.am did not set LINK_OBJS
LINK_OBJS =
instead of
4.115
@5a4bb75
04/26/12 12:28:52 |
Sebastian Huber |
Filesystem: Remove per file descriptor semaphore
The per file …
4.115
@0caef32f
05/04/12 06:55:07 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@fdc39c4
05/04/12 06:54:42 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@9f4e8fb
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@70f37198
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@2376237
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@4dec352
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@84b01905
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@67cad33e
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@27a345b
05/04/12 06:54:41 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@820d82ed
05/04/12 06:54:40 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@6a5e19cc
05/04/12 06:54:40 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@5f38f20d
05/04/12 07:29:07 |
Ralf Corsepius |
Remove.
4.115
@9f6ea32
05/03/12 15:03:34 |
Joel Sherrill |
psxaio01/psxaio02 - Formatting corrections
The file header was moved …
4.115
@604405d8
05/03/12 14:41:38 |
Joel Sherrill |
sp07/buffered_io.c add missing copyright
Date and ownership …
4.115
@c36ebbd
04/24/12 21:08:51 |
Joel Sherrill |
smp08 screen replacement
4.115
@fb78f91
04/23/12 13:10:04 |
Gedare Bloom |
PR1908: consolidate libqos code and fix installed header location
4.115
@5c51ba1
04/16/12 08:38:31 |
Sebastian Huber |
rbheap: API changes and documentation
4.115
@1c2b94a
04/16/12 03:12:08 |
Petr Benes |
PR1908: QoS library for CBS scheduler
Add the lipqos and sptest.
4.115
@c050143
04/16/12 03:06:34 |
Petr Benes |
Since the CBS scheduler is …
4.115
@8c6608bd
04/13/12 07:10:12 |
Sebastian Huber |
rbtree: PR2046: Replace rtems_rbtree_unique
4.115
@e752630
04/10/12 09:19:39 |
Sebastian Huber |
rbheap: New files
In the Red-Black Tree Heap the administration data …
4.115
@dc62a48c
04/10/12 08:25:14 |
Sebastian Huber |
rbtree: PR1995: API change
New functions
o …
4.115
@58f6655
04/03/12 14:15:34 |
Sebastian Huber |
networking: socket to/from file descriptor
o Move …
4.115
@890358f
03/30/12 00:41:34 |
Gedare Bloom |
PR1994: RBTree Compare Result Change
Change the meaning of the …
4.115
@e53aae2
03/26/12 20:42:38 |
Gedare Bloom |
confdefs: Add declaration for unlimited objects.
Adds to confdefs a …
4.115
@4ee0fa87
03/26/12 10:54:36 |
Sebastian Huber |
libtests/block06: Increase stack size
4.115
@23ed785
03/09/12 13:46:40 |
Sebastian Huber |
PR2040: libtests/flashdisk01: New test
4.115
@113944fa
02/28/12 14:37:31 |
Sebastian Huber |
fstests/fsbdpart01: New test
4.115
@01211720
03/05/12 14:06:02 |
Sebastian Huber |
libblock: Add generic IMFS block device nodes
New functions
o …
4.115
@796967c
02/28/12 16:19:49 |
Sebastian Huber |
libblock: Change bdbuf API
The functions
o rtems_bdbuf_get(),
o …
4.115
@c649976
02/28/12 12:28:42 |
Sebastian Huber |
libblock: New block IO control support functions
4.115
@c5392ef9
03/01/12 10:51:34 |
Sebastian Huber |
IMFS: Add make generic node support
Generic nodes are an alternative …
4.115
@e00cca9b
02/21/12 14:52:55 |
Sebastian Huber |
IMFS: Do not check for unsupported types
Allow creation of nodes with …
4.115
@3ba4f828
03/02/12 09:18:10 |
Sebastian Huber |
Filesystem: Read-only file system checks
o Make sure EROFS is …
4.115
@3b7c123
03/13/12 10:33:51 |
Sebastian Huber |
Filesystem: Reference counting for locations
o A new data structure …
4.115
@a52be5ec
03/04/12 13:48:10 |
Gedare Bloom |
PR2034: sprbtree01: predecessor/successor imprecision
The tests for …
4.115
@ac165341
03/02/12 17:16:33 |
Ralf Corsepius |
2011-03-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@e6a675e
03/02/12 13:51:10 |
Ralf Corsepius |
4.115
@9294f8f
02/23/12 08:55:44 |
Sebastian Huber |
psxtests: Fix typo in psxstat
4.115
@56f1fbe
02/22/12 08:16:07 |
Ralf Corsepius |
2012-02-22 Ralf Corsépius <ralf.corsepius@…>
4.115
@99aebcb
02/22/12 08:14:37 |
Ralf Corsepius |
4.115
@77998753
02/17/12 15:54:23 |
Sebastian Huber |
Use alternative API
Replaced Allocate_majority_of_workspace() with …
4.115
@23c6f93a
02/09/12 09:55:25 |
Sebastian Huber |
Increase stack size for symbolic link loop test
4.115
@28860ec0
02/08/12 14:57:04 |
Sebastian Huber |
Fixed warnings and minor bugs
o Due to the usual integer propagation …
4.115
@5d443559
02/02/12 22:57:42 |
Joel Sherrill |
PR 1991/cpukit - attr.c (really mode code) warning rework
This PR was …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@3b057ea
12/14/11 13:19:52 |
Sebastian Huber |
Typo.
4.115
@46231e1
12/14/11 13:18:01 |
Sebastian Huber |
2011-12-14 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@f55595e
12/14/11 12:58:21 |
Sebastian Huber |
4.115
@03cc73a
12/13/11 14:33:42 |
Sebastian Huber |
2011-12-13 Sebastian Huber <sebastian.huber@…>
4.115
@b3dbca3
12/13/11 12:11:10 |
Ralf Corsepius |
2011-12-13 Ralf Corsépius <ralf.corsepius@…>
* math/init.c, …
4.115
@9c2d082b
12/13/11 10:49:25 |
Ralf Corsepius |
4.115
@5f818ec1
12/13/11 10:49:13 |
Sebastian Huber |
4.115
@23e0b66
12/13/11 10:40:46 |
Ralf Corsepius |
4.115
@257d8fd
12/13/11 10:13:24 |
Ralf Corsepius |
4.115
@73699608
12/13/11 10:02:36 |
Sebastian Huber |
4.115
@849d4bbc
12/13/11 10:02:30 |
Ralf Corsepius |
* sp31/task1.c: …
4.115
@ee22b25
12/13/11 09:54:51 |
Ralf Corsepius |
* tm30/init.c: …
4.115
@260fa3f
12/13/11 09:40:08 |
Ralf Corsepius |
* psx07/init.c: …
4.115
@4534ba3
12/13/11 09:36:01 |
Ralf Corsepius |
4.115
@4b274633
12/13/11 06:52:09 |
Ralf Corsepius |
* configure.ac: …
4.115
@c444d1e
12/13/11 04:37:56 |
Ralf Corsepius |
2011-12-11 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@b1345b2
12/12/11 15:18:18 |
Sebastian Huber |
2011-12-12 Sebastian Huber <sebastian.huber@…>
4.115
@14d4397
12/11/11 07:38:02 |
Ralf Corsepius |
4.115
@1415194
12/11/11 06:50:42 |
Ralf Corsepius |
* Makefile.am: …
4.115
@436ef33
12/11/11 06:49:22 |
Ralf Corsepius |
4.115
@c7dc99ef
12/09/11 16:44:15 |
Sebastian Huber |
2011-12-09 Sebastian Huber <sebastian.huber@…>
4.115
@b6c5fe0
12/09/11 16:27:11 |
Sebastian Huber |
4.115
@06d28d6
12/09/11 05:57:06 |
Ralf Corsepius |
2011-12-09 Ralf Corsépius <ralf.corsepius@…>
4.115
