@82d137ae
04/23/14 20:08:26 |
Jennifer Averett |
capture01: New non-interactive test for capture engine.
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
@ef8c00bc
06/27/14 11:10:15 |
Sebastian Huber |
termios: PR2153: New low-level device API
Add a new low-level device …
4.115
@9f228bea
06/24/14 08:00:06 |
Sebastian Huber |
smptests/smpmrsp01: Add and update test cases
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@8852594
07/01/14 10:02:24 |
Sebastian Huber |
sptests/spcontext01: Avoid NULL pointer access
4.115
@0b4ec4d
06/30/14 10:30:12 |
Sebastian Huber |
smptests/smpfatal08: Support RTEMS_PARAVIRT
4.115
@b42e148
06/24/14 07:53:11 |
Sebastian Huber |
smptests/smpmigration02: PR2183: Add test case
4.115
@a92989a
06/18/14 13:16:02 |
Sebastian Huber |
score: Fix thread deletion on SMP
Close the thread object in …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@bd56356b
06/18/14 08:54:04 |
Sebastian Huber |
smptests/smpwakeafter01: New test
4.115
@11947299
06/13/14 14:06:20 |
Sebastian Huber |
smptests: Avoid use of uninitialized data
4.115
@4962d24d
06/11/14 14:34:51 |
Sebastian Huber |
smptests/smpscheduler03: Test all SMP schedulers
4.115
@647859e
06/11/14 12:37:03 |
Sebastian Huber |
samples/pppd: Fix extra drivers initializer
4.115
@2a2a1695
06/10/14 09:42:19 |
Sebastian Huber |
smptest/smpfatal03: Update due to API changes
4.115
@f6fc6359
06/03/14 10:00:53 |
Sebastian Huber |
sptests/spsem03: New test
4.115
@1d799ad
06/03/14 08:24:55 |
Sebastian Huber |
rhealstone: Produce proper begin/end messages
4.115
@5abe5a8
06/02/14 14:15:15 |
Christian.Mauderer |
smptests/smpthreadlife01: Fix for debug enabled
4.115
@1ee0d5f
06/02/14 14:15:14 |
smptests/smpmrsp01: Fix scheduler ids
4.115
@9553e7a6
05/26/14 14:02:58 |
Sebastian Huber |
score: Use Resource Handler for MrsP semaphores
This enables proper …
4.115
@3e201139
05/23/14 08:00:33 |
Sebastian Huber |
score: Add Resource Handler
A resource is something that has at most …
4.115
@25f5730f
05/28/14 16:11:51 |
Sebastian Huber |
score: _Scheduler_Set_affinity()
Do not change the scheduler with …
4.115
@431bb85d
05/19/14 13:07:22 |
Chris Johns |
rtems-test-check: Ignore tests which require real ISR based clock tick …
4.115
@8fcafdd5
05/21/14 08:33:43 |
Sebastian Huber |
score: Multiprocessor Resource Sharing Protocol
Add basic support for …
4.115
@d134adeb
05/23/14 13:32:32 |
Sebastian Huber |
score: Fix race condition in SMP startup
Do not use the …
4.115
@4edf348c
05/22/14 07:31:13 |
Sebastian Huber |
score: PR2179: Fix initially locked PCP mutexes
Elevate the priority …
4.115
@3cbedb1
05/22/14 09:56:50 |
Chris Johns |
testsuite: Add a user keypress to start pppd.
Allow the test to run …
4.115
@eae0863
04/27/14 08:11:09 |
Chris Johns |
rtems: Fix sp2038 test.
Avoid using newlib's gmtime_r call which …
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@23b9d095
05/07/14 16:32:15 |
Sebastian Huber |
smptests/smp07: Fix test output
4.115
@8fa3422
05/07/14 16:30:36 |
Sebastian Huber |
smptests/smp05: Fix test name and output
4.115
@b97bc8bc
05/07/14 16:27:19 |
Sebastian Huber |
tests: Add locked_printf_plugin()
Add locked_vprintf(). Return an …
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@3324383c
05/05/14 14:47:30 |
Joel Sherrill |
testsuites: Remove BSP_SMALL_MEMORY
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a44fa5a7
04/21/14 14:08:48 |
Joel Sherrill |
utf8proc01: Honor BSP_SMALL_MEMORY
4.115
@faa4e4c0
04/21/14 14:08:34 |
Joel Sherrill |
flashdisk01: Honor BSP_SMALL_MEMORY
4.115
@2bea494
04/21/14 14:08:15 |
Joel Sherrill |
fsdosfsname01: Honor BSP_SMALL_MEMORY
4.115
@97ae79d7
04/21/14 14:07:57 |
Joel Sherrill |
fsdosfsformat01: Honor BSP_SMALL_MEMORY
4.115
@b3613c3a
04/16/14 10:34:07 |
Sebastian Huber |
smptests/smpload01: Reduce timeout value
Use events instead of …
4.115
@c5831a3f
04/09/14 13:07:54 |
Sebastian Huber |
score: Add clustered/partitioned scheduling
Clustered/partitioned …
4.115
@27270b0d
04/09/14 08:09:39 |
Sebastian Huber |
rtems: Add task get/set scheduler
4.115
@1b67535d
04/09/14 08:09:57 |
Sebastian Huber |
rtems: Add scheduler get processors
4.115
@b427a92
04/09/14 08:09:24 |
Sebastian Huber |
rtems: Add scheduler identification
4.115
@0712d17
04/08/14 09:14:27 |
Sebastian Huber |
score: Task get/set affinity
Make rtems_task_get_affinity() and …
4.115
@e1598a6
04/04/14 08:56:36 |
Sebastian Huber |
score: Static scheduler configuration
Do not allocate the scheduler …
4.115
@589bbcb
04/14/14 21:05:52 |
Joel Sherrill |
sp74.doc: Correct minor typos
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@4bc8d2e
04/10/14 08:58:27 |
Sebastian Huber |
rtems: Rename rtems_smp_get_processor_count()
Rename …
4.115
@263f4bec
04/07/14 12:50:37 |
Sebastian Huber |
score: Statically initialize IO manager
This simplifies the RTEMS …
4.115
@2d5424d2
04/09/14 07:40:43 |
Sebastian Huber |
sptests/sp37: Account for internal struct align
4.115
@c3cd7e7
04/09/14 13:26:17 |
Sebastian Huber |
smptests/smpschedule01: Rename in smpscheduler01
4.115
@eeb45b5
04/07/14 14:07:25 |
Sebastian Huber |
sptests/sp68: Fix configuration
4.115
@fef4293
04/07/14 13:59:09 |
Sebastian Huber |
psxtests/psxkey02: Test for proper error case
4.115
@316ba97
04/07/14 13:36:55 |
Sebastian Huber |
tmtests/tm21: Fix configuration
4.115
@781631e
04/07/14 12:50:34 |
Sebastian Huber |
sptests/spwatchdog: Fix for short enums
4.115
@e785fbaa
04/04/14 11:58:26 |
Sebastian Huber |
score: Delete _Thread_Ticks_per_timeslice
Use the Configuration instead.
4.115
@47445846
04/04/14 11:43:15 |
Sebastian Huber |
score: Delete _Thread_Maximum_extensions
4.115
@d507c037
04/03/14 17:55:43 |
Joel Sherrill |
Disable per task variables when SMP is enabled
Per task variables are …
4.115
@cae120e2
04/04/14 14:32:10 |
Sebastian Huber |
rhealstone/rhmlatency: Fix configuration
4.115
@24934e36
04/03/14 13:03:35 |
Sebastian Huber |
score: Add scheduler control to scheduler ops
Scheduler operations …
4.115
@af53e6cf
03/18/14 17:44:32 |
Jennifer Averett |
smpaffinity01: Use Priority Affinity SMP scheduler.
4.115
@d4e1ead
03/18/14 17:43:55 |
Jennifer Averett |
smppsxaffinity01: Use Priority Affinity SMP scheduler.
4.115
@cb283959
03/18/14 17:43:35 |
Jennifer Averett |
smppsxaffinity02: Use Priority Affinity SMP scheduler.
4.115
@1a6093d
04/03/14 10:52:33 |
Sebastian Huber |
samples/fileio: Fix configuration
4.115
@494c2e3
04/01/14 09:48:59 |
Sebastian Huber |
score: Move priority bit map to scheduler instance
Delete global …
4.115
@3f5f2ce
03/28/14 12:44:18 |
Sebastian Huber |
score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Issue a fatal error …
4.115
@3ccfd98b
04/01/14 07:21:05 |
Sebastian Huber |
libtests/newlib01: New test
4.115
@57db5f1
04/01/14 06:40:23 |
Sebastian Huber |
smptests/smpthreadlife01: Avoid bad profiling stat
4.115
@91e7b0c
03/27/14 08:04:47 |
Sebastian Huber |
score: PR2172: _Thread_queue_Extract()
Add …
4.115
@b9b014e
03/31/14 13:49:35 |
Sebastian Huber |
smptests/smpthreadlife01: Typo
4.115
@a881ff2
03/31/14 13:45:01 |
Sebastian Huber |
smptests/smpthreadlife01: Add test cases
4.115
@ab816bc
03/31/14 07:23:48 |
Sebastian Huber |
sptests/sptask_err04: Fix broken test
4.115
@03e89287
03/27/14 13:46:31 |
Sebastian Huber |
score: Delete CORE_mutex_Control::lock
The holder field is enough to …
4.115
@f0b4fd9
03/28/14 08:29:51 |
Sebastian Huber |
score: Do not reset resource count during restart
This fixes an …
4.115
@23fec9f0
03/27/14 13:16:12 |
Sebastian Huber |
score: PR2152: Use allocator mutex for objects
Use allocator mutex …
4.115
@1b1be254
03/25/14 09:54:49 |
Sebastian Huber |
score: Thread life cycle re-implementation
The thread deletion is now …
4.115
@391ad3e
03/17/14 14:03:22 |
Sebastian Huber |
score: Fix thread restart extensions context
Run the thread restart …
4.115
@5c731a83
03/17/14 09:12:14 |
Sebastian Huber |
score: Use thread action for thread restart
The thread restart is now …
4.115
@ecd8c8ad
03/28/14 10:58:20 |
Sebastian Huber |
tests/fatal: Fix test names
4.115
@d98217c
03/28/14 10:52:28 |
Sebastian Huber |
psxtests/psxconfig01: Fix for POSIX keys config
4.115
@2c83ac3
03/28/14 10:47:42 |
Sebastian Huber |
smptests/smpfatal03: Fix end of test output
4.115
@5a13ef9
03/28/14 10:34:16 |
Sebastian Huber |
sptests/sp44: Fix end of test output
4.115
@df367fad
03/28/14 18:05:57 |
bjornlarsson |
sptests: New tests split from sp09 screen 1 and screen 2.
Split sp09 …
4.115
@719c7e5
03/27/14 14:47:24 |
bjornlarsson |
sptask_err03: New test split from sp09 screen 3.
4.115
@4327a7b
03/26/14 18:22:43 |
bjornlarsson |
spevent_err03: New test split from sp09 screen 4.
4.115
@d6f65e40
03/26/14 14:56:43 |
bjornlarsson |
sptests: split sp09 screen 5,6 into spsem_err01, spsem_err02, and …
4.115
@a3707d89
03/25/14 18:48:30 |
bjornlarsson |
sptests: Split sp09 screens 7,8 into spmsg1_err01 and spmsgq_err02.
4.115
